Author Topic: Mirrors  (Read 2756 times)
Offline stefanbuss
Mirrors
« on: June 14, 2016, 05:21:56 PM »
Friends,
any ideas on how to do the reflective part of an aircraft's rearview mirror?
S.
Re: Mirrors
« Reply #1 on: June 14, 2016, 07:37:48 PM »
Hello Stefan,
I always use Aluminium Foil tape like this: https://www.conrad.de/de/aluminium-klebeband-3m-silber-l-x-b-55-m-x-50-mm-acryl-inhalt-1-rolle-n-547262.html
You can also buy it sometimes at Aldi. Works superb and is Ultra thin. I also use it for Zylinders on Planes or on trucks.
Offline jknaus
Re: Mirrors
« Reply #2 on: June 14, 2016, 11:27:01 PM »
I agree with the tin foil. Great for straps and clamps as well.
James
Offline Suffolk Lad
Re: Mirrors
« Reply #3 on: June 15, 2016, 03:28:09 AM »
Hi Stefan
Like Manni - I have used the similar 'chromium' self adhesive tape available at some cycle shops. On my last jet build I used self adhesive vinyl sheet - it makes for very convincing oleos. Ebay was the source  ;)
Hope I'm not 'teaching granny to suck eggs' but if you need a circular mirror and don't have the means to cut a tiny disc accurately a piece of brass tube with the end sharpened to a fine edge will work well.
Regards - Tug
Offline nmroberto
Re: Mirrors
« Reply #4 on: June 15, 2016, 05:32:56 AM »
Or use Bare Metal Foil  ultra chrome.  Really looks good. One sheet would last years if you're only doing mirrors.
Robert
Online lcarroll
Re: Mirrors
« Reply #5 on: June 15, 2016, 06:00:47 AM »
    I use a Testors version called "Ultra Bright Krome Foil". It works well and also for clamps etc. as James pointed out.
Re: Mirrors
« Reply #6 on: June 23, 2016, 12:47:58 PM »
bare metal foil has that self adhesive foil in different types chrome works nice for mirrors
Re: Mirrors
« Reply #7 on: August 13, 2016, 09:23:47 AM »
I am currently foiling a B-29 over at Aeroscale.
http://aeroscale.kitmaker.net/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=244807
On it I use both Bare Metal Foil and kitchen foil.  Although both provide a metal shine, if you want to pump it up, you can polish the foil with aluminum polish from a car parts store.  After using the polish you can have a truly reflective surface.
Gaz
