Author Topic: RAF BE.2c (1/72, Airfix)  (Read 42594 times)
Re: RAF BE.2c (1/72, Airfix)
« Reply #30 on: May 05, 2016, 03:51:35 AM »
The fuselage is closed, the missing bits in front cockpit (cables, pipes, rigging) added.
I have cut the pieces of the centre section from the cabane struts and inserted them into the upper wing slots leaving sockets for the struts, the joints filled and sanded.
There is still a bit of front cockpit coaming at its aft to be added - another modification in the Robinson's aircraft.
« Reply #31 on: May 05, 2016, 04:39:39 AM »
Wow! Some really fine and detailed work, Przemo! Your attention to detail is fantastic... Wonderful how you produce every detail of Robinson's aircraft too...
Marc.
« Reply #32 on: May 05, 2016, 01:00:47 PM »
Excellent work, Przemo, but that is a given.  Great idea on the cabanes.  That will
make a nice secure base for the top wing.  Terrific update, my friend.
Offline BigBlue
« Reply #33 on: May 05, 2016, 01:17:59 PM »
So true!
« Reply #34 on: May 06, 2016, 04:29:13 AM »
Prez,
My sincere apologies but I do not visit this part of the site often and I had missed this until now. There is only one word that gets anywhere near to describing this work: beautiful. And that leaves a book unwritten…..
As usual you are providing us all with a masterclass in how to improve what is a basically sound model and in God's Own Scale which is all the more interesting. Looking at the photos I could easily have thought that this was 1/32.
A simple request: please do not get so easily distracted with other non- WW1 subjects - your build threads are always worth following closely and I have missed them recently - including this one!
« Reply #35 on: May 06, 2016, 08:21:12 AM »
Your build continues to impress as always! Beautiful work!
« Reply #36 on: May 06, 2016, 10:57:42 AM »
Excellent work to date Przemol.
Offline xmald
« Reply #37 on: May 10, 2016, 06:26:20 AM »
Looking great Przemek! It`s really hard to believe that it`s 1/72nd! The details are great!!!
Best regards
Filip
« Reply #38 on: May 10, 2016, 01:53:37 PM »
very nice prez. gonna have to get one of these for fun
« Reply #39 on: May 10, 2016, 08:07:44 PM »
Prze-Tastic work!
Keep going  ;)
vB
« Reply #40 on: May 17, 2016, 08:19:38 AM »
Thank you, everybody.
And, Stephen, I promise not to get distracted too often from WW1 related subjects. :-)
And meanwhile, the work on BE.2c continues...
The missing rear rim of the front cockpit I wrote about earlier was scratch built, glued and the surrondings filled, sanded and polished.
I have found out, that the sockets for the interplane struts on the underside of upper wings are too large and they (like the strut pins) have strange elliptic shape in plan view - transverse to the strut aerofoil cross-section. This would lead to nasty gaps around the strut mounting points after the assembly, hard to fill as I like to mount the struts and wings after airbrushing. Besides the landing and flying wires would end too far from the strut connection points. So I cut off the ellipse pieces going too far sideways
and glued them inside the sockets leaving only acceptable rectangular holes ready to fit the remaining rectangular pins. Needless to say that filling and sanding was required all around here.
Also the sockets for underwing skids protecting the wing tips from damage were far too large - filled, sanded and drilled again with a smaller diameter.
Then some work on the RAF 1a engine started. What kit provides is quite decent. Still I decided to add the missing spark plugs (already there, made from wire bits), later the electric cables will follow. I also wish to add the valve push rods and valve rockers - these bits will come after painting and assembly only. I have also drilled the exhausts outlets. This is how it looks when dry-fit.
More to come...
« Reply #41 on: May 17, 2016, 12:07:42 PM »
very nice engine in this little tiny kit.
« Reply #42 on: May 18, 2016, 02:42:41 AM »
Truly remarkable work, Przemo, but no less than I've come to expect from your talented hands!
« Reply #43 on: May 18, 2016, 02:59:00 AM »
Thanks, Bud and Albatros.
Edgar, the cockpit interior would surely profit a lot from a PE set. The engine not so much. Also the horns on the control surfaces and those at the fuselage sides could be done in PE. A resin replacement for the engine is not absolutely necessary but it would surely be better than the plastic injection one in the kit.
« Reply #44 on: May 18, 2016, 03:50:10 AM »
Excellent update Prez - I am really surprised at the detail provided on the engine - even in plastic and mass produced too. It would almost seem worthwhile buying a kit just for the engine - especially the way that you have added the extra details. This is going to be another of your gems when it is finished.
