Under Construction
RAF BE.2c (1/72, Airfix)
Pages:
9
10
11
12
Topic: RAF BE.2c (1/72, Airfix) (Read 43047 times)
lone modeller
Re: RAF BE.2c (1/72, Airfix)
Reply #135 on:
August 21, 2016, 03:34:35 AM »
Sorting out all of those wires was worthwhile. The rigging looks excellent - the model will be even better when complete.
PrzemoL
Reply #136 on:
August 21, 2016, 07:31:34 AM »
The rigging of the wings is completed. I have almost forgotten to include those flying wires in the outer bays which go to the mid span. Luckily, the lines could still be added by gluing them just between the starting points of the double lines and the strut bases.
I have started filling the holes on the upper wing upper side using the acrylic paint pigment. It has to dry and then I will sand it flush, then probably reapply it and so on until the result is satisfactory.
I have also added the Pitot probe on the port outer strut.
Last Edit: January 23, 2018, 09:14:43 PM by PrzemoL
Des
Reply #137 on:
August 21, 2016, 07:37:07 AM »
Very impressive work with the rigging Przemol, your BE.2c is really looking the part now.
IanB
Reply #138 on:
August 21, 2016, 09:45:12 AM »
Beautiful work Prez, she's going to be a beauty!
coyotemagic
Reply #139 on:
August 21, 2016, 10:13:51 AM »
Brilliant work with the rigging, Przemo, and that pitot tube is a very fine touch!
Reply #140 on:
August 21, 2016, 01:44:44 PM »
Quote from: coyotemagic on August 21, 2016, 10:13:51 AM
I agree with BUd but I will add for me, if only my 1/32nd builds came out this beautiful!
WarrenD
Guest
Reply #141 on:
August 22, 2016, 02:58:04 AM »
Just simply beautiful Prze, just beautiful.
Now, as I've asked you before, and I just asked Ian on his build, regarding the clean up"
When you say "paint pigment", are you saying this is the "goop" of the settled paint?
PrzemoL
Reply #142 on:
August 22, 2016, 03:09:37 AM »
Thank you gentlemen for your kind words.
Warren, my English is not so good to understand the word goop, but what I meant was the sedimented pigment (dense paint) gathered at the bottom of a paint container which I pick up with the end of the toothpick without stirring it. It is still liquidish enough to pour down and fill the hole but simultaneously thick enough to fill the space. Usually I have to repeat the treatment three or four times but I prefer it more than a putty which is hard to put into such a small diameter hole.
Last Edit: September 20, 2016, 05:49:56 AM by PrzemoL
WarrenD
Guest
Reply #143 on:
August 22, 2016, 03:39:26 AM »
Prze, your English is 100% better than my Polish, and in this case you were spot on, that's
exactly
what I thought you meant by "goop". It's a great idea as I don't see myself being able to put putty in such a small hole.
Last Edit: August 22, 2016, 03:44:21 AM by WarrenD
ondra
Reply #144 on:
August 22, 2016, 03:59:33 AM »
Hi Przemol, first of all my hats off to you for your skills, what you are showing here is really spectacular!
Regarding to filling the holes - may be an extra thin CA glue like Alteco D would do the job. It cures very fast and is thin enough to apply in holes with very small diameter. I use to full satisfaction on my 1/144 builds.
Ondra
Reply #145 on:
August 22, 2016, 04:14:15 AM »
Przemol.
Thanks for the info on how you fill the holes! Much easier to sand than CA I would think! I will have to try this on my SE!
PrzemoL
Reply #146 on:
August 22, 2016, 04:27:55 AM »
Ondra, thanks for the hint on CA. I usually use it as a filler, but as Rick has pointed out, paint pigment is much easier to sand in this instance.
ondra
Reply #147 on:
August 22, 2016, 04:34:25 AM »
Fair point, this method will be more comfortable for sanding.
Reply #148 on:
August 22, 2016, 03:21:12 PM »
Hello Przemol,
thank you for showing this stunning build, I have always to look if it is 1:32 or 1:72. You are a very skilled man.
Borsos
Reply #149 on:
August 22, 2016, 04:27:05 PM »
Incredible. Such a wonderful Be 2c! A truly great model of this important aircraft.
Borsos
Pages:
9
10
11
12
Under Construction
