Author Topic: RAF RE8, Airfix, 1:72 - an effort to put it right!  (Read 52557 times)
Re: RAF RE8, Airfix, 1:72 - an effort to put it right!
« Reply #75 on: April 22, 2016, 07:03:43 PM »
Looks great once primed, Ian. :D
« Reply #76 on: April 22, 2016, 08:28:35 PM »
Very well done as the primer coat shows. The stitching looks awesome.
« Last Edit: April 23, 2016, 05:31:18 AM by RAGIII »
« Reply #77 on: April 23, 2016, 04:06:59 AM »
Wow, looks like in Museum Ian.
« Reply #78 on: April 23, 2016, 07:22:00 AM »
Thanks everyone for the positive feedback...I'm not sure it's quite THAT good, but I'm certainly happy with it, and glad you all like it!
The first thing I did today was as a result of yesterday's post. I decided after seeing the pics that the carb fairing was too big, so I trimmed about 1mm off the rear and thinned the whole thing down a bit. I think it looks much better now.
 I wasn't quite sure how I wanted to proceed today, but decided to get some paint on the fuselage, rather than wait for the wings to be finished and then paint it all at once. First I attached the wing root stubs, then put some grey on the nose (Model Master Neutral Grey). When that was dry, I did the underside with Misterkit RFC CDL. I love those paints, they spray so easily...I just hope I don't have any problems masking it later.....
 There will be more grey to do later, when I add the cover panels to the sides of the engine bay and the bottom of the fuel tank/front cabane strut.
 In between the painting I decided to do some work on the engine. I added the exhaust manifolds, did a little detail painting, and made up the air scoop out of an old beer can. I still need to add the internal baffles to that, but they will be done later. I lso cleaned up the kit exhausts - the horizontal part needed shortening slightly and was then rounded off to give a more circular cross-section, the upright will be shortened when it's all together so I don't cut it too short, but it has been flattened out to give  more ovoid cross section.
That's it for today, time for a beer. Thanks for looking in.
« Last Edit: July 12, 2017, 01:48:32 AM by IanB »
« Reply #79 on: April 23, 2016, 08:28:13 AM »
Great work on the painting Ian and the engine is looking really good.
« Reply #80 on: April 23, 2016, 08:02:38 PM »
Excellent progress Ian! The Misterkit paints are great to work with. Too bad they are so hard to get here in the States!
« Reply #81 on: April 23, 2016, 10:00:21 PM »
The RE8 continues to impress, Ian!  The engine is coming along very
well and the metal air scoop is a brilliant addition. I really like the
Misterkit paints as well...nice smooth paintwork, by the way.
Looking forward to the next updates, my friend.
« Reply #82 on: April 25, 2016, 06:45:15 AM »
Thanks Des, Rick, & Ernie!
 Unfortunately after further trial fitting I've decided the air scoop is too wide, so I'll have to do it again....I also managed to drop the engine today and knocked all the exhaust stubs off! Oh, well, that was just waiting to happen I suppose.....
 I got it all masked and painted yesterday, and managed to drop it while masking. The result of that was to make my first job today, after unmasking, refitting the cockpit internals that dropped out..... :-[ At least with the masking on they couldn't get lost!
So, after that awkward task was completed I got on with some detail painting on the fuselage: fuel tank straps and caps, leather reinforcement around the control cable cutouts, cockpit surround, etc. Then I fitted the engine and added the panels along its sides. The prop was just loosely fitted to help with engine alignment.
the final job today was to build the Scarff ring and test fit that. It looks as though a little fettling will be required....
That's it for today, when the filler on the engine panels is dry tomorrow I'll clean those up and paint them. Then I need to remake that air scoop......
Thanks for looking!
« Last Edit: July 12, 2017, 01:54:50 AM by IanB »
« Reply #83 on: April 25, 2016, 07:05:52 AM »
Coming along very nicely Ian despite your little accidents, it's looking really good with the engine sitting in position and the prop trial fitted.
« Reply #84 on: April 25, 2016, 09:24:57 AM »
That is a great work around the kit.
Cheers Martin
WarrenD
« Reply #85 on: April 25, 2016, 11:30:38 AM »
I detest accidents like that, what a bummer. However, as Des said, you're coming along wonderfully.
« Reply #86 on: April 25, 2016, 05:33:14 PM »
These accidents happen, Ian. The key is how you react to them and you have done brilliantly to restore things. Were that to have been me it would have put things under a dark, dark cloud and led to the model being put aside for at least six months!
Great work.
« Reply #87 on: April 25, 2016, 11:31:05 PM »
Great recovery from your mishaps and the paint work looks great! Looking forward to your next update.
« Reply #88 on: April 26, 2016, 06:57:24 AM »
Thanks all!
 I should have properly test fitted the Scarff ring before painting, instead of just checking that the opening was correct, as it turned out the fuselage was slightly too narrow at the top. This meant Mr Dissolved Putty had to be called in to the rescue after I made sure that the top decking was actually flat. It has now been fitted and just needs a little more tidying up, then I'll respray that area when I do the wings.
 Of course I managed to knock the map table out again, this time I really thought I'd lost it....I'd given up looking and sat down to start making another one. When I pulled down my desk magnifier I couldn't believe what I found....
 There it is, sitting on top of the glass down at the bottom! How on earth it got there I have no clue as I was using the magnifier while working!
 For my last job today I decided to remake the cowl air scoop, but using .005" plastic sheet instead of the beer can. It was much easier to work with and trim by very small amounts to get it to fit correctly, and I'm very happy with it now. I'll paint it tomorrow....
 Just a little more work needed on the side cowlings too, then that area is sorted.
Thanks for watching!
« Last Edit: July 12, 2017, 02:14:10 AM by IanB »
Offline BigBlue
« Reply #89 on: April 26, 2016, 01:39:56 PM »
Looks great, Ian.  Nice find with the map table!
