Author Topic: RAF RE8, Airfix, 1:72 - an effort to put it right!  (Read 52694 times)
Re: RAF RE8, Airfix, 1:72 - an effort to put it right!
« Reply #30 on: April 05, 2016, 03:15:05 AM »
This will undoubtably prove interesting.old man did a similar project a few years ago I have to look for a link.
« Reply #31 on: April 05, 2016, 06:50:33 AM »
Thanks all,
 I remember Ole Man's build, haven't seen him around for a while......I'll look it up. Not much done today, I've been concentrating on putting together the perspex for an under-the-coffee-table display box!  8)
 I did, however, print out a copy of a cropped version of one of TVAL's pics of their instrument panel, and white glued it to a piece of plastic card for use as the panel. It doesn't compete with a proper decal, but it's a lot better than a painted one!
« Last Edit: April 09, 2016, 10:51:08 AM by IanB »
« Reply #32 on: April 05, 2016, 10:16:41 AM »
Great aditional work Ian.
Offline Squiffy
« Reply #33 on: April 05, 2016, 11:25:19 PM »
There's certainly some drastic surgery going on with this one!
« Reply #34 on: April 09, 2016, 10:53:13 AM »
Thanks folks
 A little more progress on the interior....
 Ideally I would have entirely removed the area where the lower wing joins the fuselage, but with the surgery done in that area I think the fuselage sides would be too weak, so I've just thinned it down. This does mean that there is a step up, instead of down, from the observer's floor to the "fabric" under the pilot's cockpit, but I'll live with that.
I can now make a start on the fuselage cross members and some of the smaller detail items....
« Last Edit: July 05, 2017, 05:45:15 AM by IanB »
« Reply #35 on: April 09, 2016, 11:09:19 AM »
You are doing a fantastic job with the fuselage interior Ian.
« Reply #36 on: April 09, 2016, 01:23:02 PM »
Gorgeous interior, Ian!
« Reply #37 on: April 09, 2016, 07:09:08 PM »
Plus one Amigo! Hard to believe that interior is in the OLD Airfix kit! What a difference you are making!
Offline TobyCoulson
« Reply #38 on: April 09, 2016, 07:59:57 PM »
Fantastic work on what can best be described as the only 1/72 RE8 available. One day someone will make a decent one but you are doing a magnificent job on this old clunker.
Offline Thumbs up
« Reply #39 on: April 09, 2016, 08:55:31 PM »
Choroszy do a rather decent  RE8 It has  about 80 pieces.
Offline TobyCoulson
« Reply #40 on: April 09, 2016, 09:27:00 PM »
Thanks. Wasn't aware there was another in that scale.
« Reply #41 on: April 09, 2016, 10:53:39 PM »
The interior looks terrific, Ian!  Really well done, my friend.
« Reply #42 on: April 12, 2016, 07:31:33 AM »
Thanks all, much appreciated!
 Nearly done on the interior now. I just have to finish off the observer's stool and then add that, and a couple of linkages to the control column and it can all be closed up.
Here's where it sits at the moment..
 The Barracudacast Resin seat is truly incredible, along with the Eduard PE belts it makes a huge difference!
Thanks for looking in
« Last Edit: July 05, 2017, 05:50:48 AM by IanB »
« Reply #43 on: April 12, 2016, 08:15:07 AM »
You are doing a great job with this build Ian, the fuselage interior is excellent.
« Reply #44 on: April 12, 2016, 08:38:43 AM »
Your cockpit is looking stunning. The seat and belt add a lot. The overall ook is perfect for the scale and could be mistaken for 1/48th or larger!
