Author Topic: Wingnuts Hannover  (Read 14800 times)
Re: Wingnuts Hannover
« Reply #30 on: April 07, 2016, 08:16:06 PM »
Lovely smooooth paintwork, Guy  ;)
Excellent.
vB
Hear, hear...colourful indeed, Guy!
Offline Dave in Dubai
  • Beyond the blue horizon
« Reply #31 on: April 07, 2016, 08:54:14 PM »
Looking ready for the colouring in Guy.
I agree that the Tamiya primer paints seem to get the best results. Absolutely smooth flawless finish, and they dry very quickly.
« Reply #32 on: April 07, 2016, 09:15:48 PM »
Thanks Bob, Ernie & Dave,
I'm glad you noticed the smooth finish, because that's what I was striving for  :D I've got a confession though - the yellow is a Tamiya 'rattle can'. I've always found yellow a hard colour to paint with so I thought I'd give this a go. I'm glad I did as it made it a very straightforward job with a lovely smooth, glossy finish. The fuselage is Tamiya light blue lightened with white and diluted with Tamiya Laquer thinners. I think this is my best option for painting to date. It gives a slightly slower drying time so as not to clog the airbrush which can happen (to me at least) with protracted use. It also seems to give the smoothest finish.
Although lately I am experiencing 'spotting' with my airbrush. Little blobs spattering out along with the finer spray. Any ideas? Paint not thin enough, pressure to high? I can't seem to stop it regardless of paint type. My airbrush has been thoroughly cleaned so I'm running out of ideas. It doesn't always do it...
Offline stefanbuss
« Reply #33 on: April 07, 2016, 09:20:47 PM »
That's getting even more interesting. Pale blue and yello? Nice...
« Reply #34 on: April 07, 2016, 11:10:54 PM »
Guy,
 You may need to change the Teflon seals.
Which airbrush do you use?
vB ;)
« Reply #35 on: April 08, 2016, 01:37:47 AM »
Excellent.
vB
Yep, super smooth paint work, Guy!  Looks like an early US Navy aircraft.
« Reply #36 on: April 08, 2016, 05:31:21 AM »
Thanks Bud,
Guy,
vB ;)
Hi Bob, I've got an Iwata Custom Micro B. But I think I've finally found the problem, I went over it with a fine tooth comb and found that the blades of the tip were slightly bent (must have dropped it). If I use it without the tip it sprays fine! Phew. I'll probably need to get a new tip I reckon though  :P
I've just had an experimental paint session in an effort to recreate an uneven, dappled finish. I decided to go with the salt technique which I haven't tried before. This required a leap of faith to try it out with my lovely shiny, smooth yellow wing!
I'm sure it's old hat for everyone here, but here's what I tried:
1. Moisten the surface with warm water (the airbrush seemed to work ok with this).
2. Sprinkle on the salt - I used a standard salt grinder with coarse salt, then a final sprinkle with fine.
3. Mist on some more water.
4. Dry gently with a hairdryer.
5. Lightly spray a well thinned coat of a subtly different shade to the base.
6. Dry again with the hairdryer.
7. The salt then just brushes off and finish with a wipe down.
Quite pleased with the initial results, but bear in mind there are more processes to come and the overcoat is a Matt finish so looks slightly odd at the moment!
« Reply #37 on: April 08, 2016, 05:44:52 AM »
It comes up very beautiful, Guy.
« Reply #38 on: April 08, 2016, 06:29:07 AM »
The salt technique turned out quite nicely! Certainly has the look of distressed dope. Something to think about on my next DR1. Like all of the others have said, very colorful bird!
« Reply #39 on: April 08, 2016, 06:50:17 AM »
Thanks Martin and Rick...
Couldn't resist finishing the job with the fuselage...
I'm pleased with the effect, but think I could have gone further. I'm worried about it disappearing altogether under a filter and a layer of varnish...
« Reply #40 on: April 08, 2016, 08:16:18 AM »
Thanks for the tutorial on the salt tecnique Guy, the results are excellent.
« Reply #41 on: April 08, 2016, 11:51:03 AM »
  Guy,
I'm quite impressed with your results weathering with salt. I've used similar techniques to weather WWII aircraft many times in the past but I've got admit I'd never thought of using this on WWI aircraft before now. Thank you sharing this technique my old friend.
Offline BigBlue
« Reply #42 on: April 08, 2016, 11:56:21 AM »
That looks great Guy.
I have experimented with this technique, but have yet to employ it on an actual build due to a recurring issue with white staining in my clear coat from salt residue.  I mostly shoot Tamiya acrylic paints, and have tried a variety of top coats (Alclad Aqua & lacquers, Tamiya X-22 and XF-86, and Vallejo's acrylic matte coat.  Occasional white spots in all, despite a thorough washing with warm soap and water after removing the salt.  Unlike you, I thin my Tamiya with isopropyl alcohol, so perhaps that is part of the problem?  Either way, your results are terrific.
Your build continues to impress.
Offline rhwinter
« Reply #43 on: April 08, 2016, 04:17:55 PM »
LIKE!
« Reply #44 on: April 08, 2016, 04:50:05 PM »
Thanks Des, Greg, Chris & Richard,
All advice & comments most welcome!
Now you tell me Chris... :o
Thanks for the heads up though, I'll have to experiment on this I reckon, would be galling to mess it up at the final hurdle!
