Author Topic: Roland C.II, Airfix 1:72, corrected! (I hope!)  (Read 18759 times)
Re: Roland C.II, Airfix 1:72, corrected! (I hope!)
« Reply #30 on: February 28, 2016, 09:00:58 PM »
Excellent build log Ian! Your work in the small scale is
really tremendous.  Excellent tips on improving a kit,
useful in any scale.  I'm Looking forward to next installments.
Well done, my friend!
« Reply #31 on: February 28, 2016, 09:14:00 PM »
Ian,
Looks even better after painting! Nice start on the control column.
« Reply #32 on: February 29, 2016, 02:00:15 AM »
Thanks all!
Toby, the plans are from the Datafile.
« Reply #33 on: February 29, 2016, 10:57:14 AM »
Very fine and great work Ian.
« Reply #34 on: March 01, 2016, 08:21:02 AM »
The next "milestone" was reached today!
  I spent yesterday making up a couple of seats and doing some other small bits and pieces including the rudder pedals and control wheel. I cut the seat bases from plastic card and held them together in a pair of pliers for sanding so that they would be identical. I then measured the length and height required for the rear of the pilot's seat and cut a piece of paper to size. That was then folded in half and the shape of half the seat drawn on, then cut out. I used that template to cut a piece from a beer can to form the seat back. The same template was cut down and used for the observer's seat. They were then given a little "body" with some milliput.
I painted them this morning, added PE seatbelts and glued them, along with the flight controls, in place.
The engine was then given a little more detail, in the form of some detail painting and the water pipe along the right side, and the oil tank was sanded out of plastic stock, painted, and installed.
 The engine was then glued in place. That completed the interior...fortunately I started thinking about the exhaust, and noticed that I would have to remove a little more plastic from the rear right of the engine fairing area. The engine was removed and this was done, and then thinned, before reinstalling the engine.
That's probably the last that will be seen of most of that detailing as the final task today was to close it up!
So tomorrow I can fill the seams and start on correcting the tail profile. Then there are some inspection panels and a couple of vents to add around the nose.....
Thanks for looking in!
« Last Edit: July 12, 2017, 12:05:48 PM by IanB »
« Reply #35 on: March 01, 2016, 08:26:54 AM »
Great work with the seats Ian, these are always difficult items to get right especially in your small scale, and the engine turned out looking really good, it is a pity all that work in detailing the interior will virtually all disappear now the the fuselage is closed up.
« Reply #36 on: March 01, 2016, 09:11:28 AM »
Ian,
A very impressive interior in this scale! Nice work on the seats.
« Reply #37 on: March 01, 2016, 09:47:49 AM »
Great work to interior and to the engine, Ian.
« Reply #38 on: March 03, 2016, 11:41:53 AM »
Thanks all!
 A lot of filling and sanding over the last day or so to get the fuselage profile correct and take care of the seams. I then attached the lower wing...about 1mm further aft than the kit would have it.....
 Evidently a lot more filling and sanding to do, so today was spent on that. The lower wing joints were faired in, and the curvature of the underside was added with putty and then sanded down. A couple of repetitions and all appears ok, so now it's all prepared for primer.
The inner ring of the observer's gun mount was also added and the joints cleaned up.
Tomorrow the first primer coat will go on and I'll see what needs doing next.....
« Last Edit: July 12, 2017, 12:14:12 PM by IanB »
« Reply #39 on: March 03, 2016, 11:48:55 AM »
Great work with the fitment of the lower wing Ian.
« Reply #40 on: March 03, 2016, 12:43:21 PM »
you are doing a great job ian, i am enjoying your corrections.
« Reply #41 on: March 03, 2016, 08:49:22 PM »
An excellent build log, Ian, my friend.  Really interesting!  Your
corrections show your attention to detail.  Great stuff!
Offline boggie
« Reply #42 on: March 03, 2016, 09:22:46 PM »
Your attention to detail is most inspiring Ian.
This is a very enjoyable build to follow.
More please  :)
Offline Cajun
« Reply #43 on: March 03, 2016, 10:12:51 PM »
Really really nice!!!!
« Reply #44 on: March 04, 2016, 12:16:14 AM »
Just adding another well done on the corrections. All of the filling, sanding, added plastic bits, etc. are truly making a difference!
