Author Topic: RAF SE5a (1/72, Roden)  (Read 25807 times)
Online IanB
Re: RAF SE5a (1/72, Roden)
« Reply #30 on: September 12, 2012, 11:38:03 PM »
Absolutely gorgeous paintwork on the undersides Prez, as usual!
« Reply #31 on: September 15, 2012, 03:16:51 AM »
Thank you, gentlemen. You are far too kind with me.
Bud, I have first painted and shaded CDL undersurfaces, then drew the outline of the wings and tailplane on the paper to use them as templates to prepare masks (from Tamiya masking tape) by drawing the proper lines a little bit inside the outlines to cater for the "return" of PC10. Then with the masks on the model I airbrushed PC10.
As for the inspection panels, I have just painted them. There will be some more touches like the pulleys imitation (I still have to decide if I will use some decals or just paint them. The original kit decals are unfortunately useless, since they have white background.
In the meantime some more steps were taken - shading of PC10 and some decals. I still have to enliven the upper side inspection panels (shading, wash) and shade the decals. I also had to remove the rudder, the kit decals are too small so I will have to paint it.
WarrenD
« Reply #32 on: September 16, 2012, 05:36:46 AM »
PrzemoL, I am curious to know (and you may have already stated it elsewhere and I've missed it), but how did you accomplish the painting/shading of the wing's ribs on both top and bottom? Could you, or would you mind explaining your method for this please?
Thanks!
« Reply #33 on: September 16, 2012, 05:56:50 AM »
Warren,thanks for your interest. No secrets here.
Bottom: preshading with black permanent pen along the ribs, airbrushed CDL, airbrushed shading along the ribs with a mix of clear and brown (about 10:1).
Top: airbrushed PC10, then Aizu 0.4mm tape stripes over the ribs, then airbrushed shading with a mix of clear and black (also about 10:1)
WarrenD
« Reply #34 on: September 16, 2012, 11:39:50 PM »
Thanks PrzemoL!  I'm always interested in finding out the techniques different people use so I can try them out. I like the results of your technique as it's subtle, understanted, etc. I sometimes feel pre-shading, etc. is over done at times, but hey . . . . it's art, right?  ???
I'll have to look Aizu tape. Taping ribs (and riblets) in 1/72 is tedious work.
« Reply #35 on: September 17, 2012, 04:45:25 AM »
Excellent work. Thanks for the tips!!
« Reply #36 on: September 17, 2012, 12:02:31 PM »
great work przemol you always were the master of 1/72.
Offline Rob Hart
« Reply #37 on: September 17, 2012, 11:12:49 PM »
As usual, the quality of your craftsmanship is superb.
« Reply #38 on: September 19, 2012, 08:39:48 PM »
Warren, I do not fully agree with modelling being art. Not wishing to open a can of worms, I just wish to express my though that scale modelling may use art techniques but should always tend to imitate the reality as well as possible.
Even with Aizu tape it is tedious. Here I spent some 2 hours cutting the strips, weakening the adhesive and attaching them to the model surface only to airbrush for some 15 minutes. But Aizu makes life easier, it is true. I recommend this tape to everybody.
« Reply #39 on: September 21, 2012, 02:07:39 AM »
My favourite stage of any biplane build - a monoplane  ;)
The inspection panels were finally made by painting and decaling of black circles later covered with a coat of clear gloss. There is also some shading around the tapes forming the triangles.
Offline Adam
« Reply #40 on: September 21, 2012, 02:56:01 AM »
Beautifully  painting.
One wing is good, two wings looks better, three wings is superb. Make three  ;D
Adam.
« Reply #41 on: September 21, 2012, 07:37:09 AM »
Very sharp!!!
« Reply #42 on: September 21, 2012, 10:04:55 AM »
superb paintwork Przemol!
Offline Whiteknuckles
« Reply #43 on: September 21, 2012, 11:11:43 AM »
Some very nice work indeed Przemol - you make her look good as a mono ;)
Eternal Apprentice
« Reply #44 on: September 21, 2012, 01:18:40 PM »
Absolutely awesome paintwork, Prez.  Looks like a WNW SE ('cept it's a Hisso).
