Author Topic: Pfalz DIII a WW  (Read 11503 times)
Re: Pfalz DIII a WW
« Reply #15 on: February 02, 2016, 12:30:37 AM »
First I must say your interior is looking great! Beautiful work!. I am not sure if I understand your question about the decals. Are you using Lozenge? If so is it Aviattic or kit? If Aviattic is it the 5 color joined? or the Cookie cutter?. The short answer is that cuts on any of these should be vertical along ribs. No diagonal joins were used on the Pfalz DIIIa. IHTH,
Offline moustique
Re: Pfalz DIII a WW
« Reply #16 on: February 02, 2016, 01:05:00 AM »
thank Rick
even if you haven't understand my question
you give me the good answer ;)
I use the décals 'kit and I see there was a cut line on the notice and this line is vertical
thank for your answer and comments
Re: Pfalz DIII a WW
« Reply #17 on: February 02, 2016, 05:47:54 AM »
Great work on the interior, Moustique!
Offline moustique
Re: Pfalz DIII a WW
« Reply #18 on: February 04, 2016, 05:06:49 PM »
thank Bud
I have paint the interior with XF76 tamiya and give a little wash with panel line brown
Quote
finally I buy eyelets from Bob's Buckles
Quote
Quote
Quote
and then I paint the upper wing
at first in XF16 then preshade in black
and the final color is that preconise in wingnut wings notice
2 parts xf16 and 1 part x19
here is the result
Quote
Quote
Re: Pfalz DIII a WW
« Reply #19 on: February 05, 2016, 05:47:37 AM »
Very beautiful work and painting.
Re: Pfalz DIII a WW
« Reply #20 on: February 05, 2016, 06:29:23 AM »
Excellent job with the wing painting and shading, the interior work is extremely well done also.
Offline moustique
Re: Pfalz DIII a WW
« Reply #21 on: February 08, 2016, 06:38:09 PM »
thank you Martin
thank you Des
I was a little disapointed cause I had a problem and I don't know why
here is my painted wings
Quote
after decalling and with a clear mat here is the result
Quote
Quote
it became very dark WHY??
I use the same products that I use on my hansa  klear before decalling and mat varnish by tamiya
what do you think about that
Re: Pfalz DIII a WW
« Reply #22 on: February 09, 2016, 01:46:03 AM »
Perhaps it is the glossy finish and fresh look of the decals? At any rate terrific progress,. I am sure you will sort things out to your satisfaction.
Offline moustique
Re: Pfalz DIII a WW
« Reply #23 on: February 09, 2016, 05:09:00 PM »
I don't know Rick ant thank to your comment
I really appreciate
before finding a solution fot my wing a little update
first I cut  the spring  to teplace them by the parts of taurus model
Quote
Quote
is the only add to the engine the rest is strictly from the box with a little wash
Quote
Quote
Quote
Quote
Quote
Quote
Quote
Re: Pfalz DIII a WW
« Reply #24 on: February 09, 2016, 10:10:34 PM »
Great work and painting.
Re: Pfalz DIII a WW
« Reply #25 on: February 10, 2016, 02:45:09 AM »
Gorgeous engine, Moustique!
Offline dtomko
Re: Pfalz DIII a WW
« Reply #26 on: February 10, 2016, 03:24:38 AM »
Beautiful work on the engine.  I'm not sure why Tamiya overcoat would darken the shading.  Still looks great, though.
Drew
Re: Pfalz DIII a WW
« Reply #27 on: February 10, 2016, 06:17:28 AM »
I agree with Bud! If you are leaving the engine covers on the springs are the one thing that will be noticed.
Offline moustique
Re: Pfalz DIII a WW
« Reply #28 on: February 10, 2016, 07:38:12 AM »
[/quote]
[/quote]
sorry Rick but I'm not sure to understand what you would stay  (sorry for my pour english)
thank you all for your comments always appreciate
Re: Pfalz DIII a WW
« Reply #29 on: February 10, 2016, 08:44:26 AM »
[/quote]
[/quote]
I was saying that it is good that you detailed the springs as they are very noticeable even with the engine covers on. Excellent work on your engine  :D
« Last Edit: February 10, 2016, 10:12:31 PM by RAGIII »
