Author Topic: Airfix 1/72 Handley Page 0/400  (Read 8358 times)
Re: Airfix 1/72 Handley Page 0/400
« Reply #30 on: February 14, 2016, 10:54:34 AM »
Nicely done Stephen!
 I can assure you that the "state-of-the-art" (Aeroclub) jig I use does have its limitations, not the least of which is sharp edges which remove paint/decals very easily. Sometimes less is definitely more! Having said that, I believe John at Aeroclub has released an improved version since. I still only use that jig when absolutely necessary!
« Reply #31 on: February 14, 2016, 11:13:28 AM »
Ian,
   You are absolutely correct. I really like my Aero Club Jig however I have learned (the hard lesson way!) to use some soft insulation to prevent damage to decals and/or paint.
« Reply #32 on: February 14, 2016, 12:39:33 PM »
Hi Stephen, this step-by-step story is most inspiring. Piling up those books to push the model into shape shows us that there are a lot of ways to achieve an end goal when progressing a model along. There are a lot of modellers I know who would give up on a project that hit a difficult snag, but your build is a great example of commitment and getting the job done.
Offline Trackpad
« Reply #33 on: February 14, 2016, 01:02:36 PM »
Excellent work, Stephen. I can recall building this kit more years ago than I care to remember, but mine was nothing like your work. I look forward to seeing additional photos.  8)
Cheers!
« Reply #34 on: February 15, 2016, 12:41:22 AM »
It looks very good Stephen.
« Reply #35 on: February 23, 2016, 06:49:03 AM »
Evening All,
Here is my last instalment of the construction thread for this model.
The undercarriage is the last major sub-assembly on this model and was as complicated as any other assembly. First I had to clean the bad mould joints: the tyres needed similar treatment. Assembly of the undercarriage was fiddly but having got this far it was not a major problem. Proper aligned was the key while it dried out. I added the wind pumps to the sides of the fuselage, fuel pipes, engine platforms (and their supporting wires), ailerons and all of the control surface horns after the undercarriage units wherein place as I did not fancy replacing them when they were knocked off as they would have been had I followed the assembly sequence in the instructions. The final details were then added: propellors, pitot tube, crew entry hatch, gun pillars and guns, forward gun ring, windscreens and the tail skid, etc. The tail skid had two springs, one on each side, which I simulated with a ring of stretched sprue. I added a crew ladder and two maintenance ladders to my model just for effect - they were made from thin strip.
I have posted more pictures in the competed models section.
Thanks for looking.
« Reply #36 on: February 24, 2016, 04:17:48 AM »
You have build a very fine model.
« Reply #37 on: February 24, 2016, 04:33:10 AM »
Thank you Martin.
« Reply #38 on: February 24, 2016, 07:28:31 AM »
Stephen,
Following your build and watching this old kit turn into an outstanding model has been a real pleasure!
