Author Topic: Wingnut Wings 1:32 Albatros B.II Early  (Read 46384 times)
Offline FarEast
Re: Wingnut Wings 1:32 Albatros B.II Early
« Reply #60 on: January 04, 2016, 08:33:39 AM »
Looks great and man, you work fast. Shouldn't the wood grain follow the line of flight though? It's that way with other Albatros aircraft, my assumption is it is the same with the B.II (reason being the ply was three ply and bends easier/is stronger in one direction...)
Hey Bo, The photos I'm going with have all the panels on the side of the fuselage running in this way, however some of the panels on the top were not as it looks like they were replacement panels applied in the field B.II 167/14 has a beautiful shot of the top panels showing off different colours and grains. B.II 173/15 has a few on the side of the fuselage running against the line of flight as does 436/16 that has a close up of the cockpit area and the panel I replicated.
I have a feeling that when these left the factory all the wood followed the flight line but as soon as they started to see action the fitters used what they could to keep them flying. It's an incredibly interesting aircraft.
That's good enough for me! I admit I haven't studied the B.II that closely, just the scouts really.
Carry on then!
You had me scrambling for reference photos with my heart in my mouth though Bo!
« Reply #61 on: January 04, 2016, 10:11:43 AM »
erk, sorry 'bout that; I figured you would want me to point it out if I thought it was questionable now (while you could still fix it)  rather than later...
« Reply #62 on: January 04, 2016, 05:43:38 PM »
Beautiful work on the pre painting decaling work and the usage of the Uschi wood decals!
« Reply #63 on: January 04, 2016, 05:59:45 PM »
I really like the pre-painting and the decals, they are are great wood colour.
« Reply #64 on: January 04, 2016, 07:53:44 PM »
Spectacular work on this Albatros, James. Will be a thread to follow when I start mine.
Offline FarEast
« Reply #65 on: January 04, 2016, 08:26:14 PM »
I've  totally lost track of the days and found that I had gained an extra days holiday! :D  :o
So as it was a fine day and my son wanted to play at the park with friends (Its just across the road and I can see it from my work bench) I decided to do just that, see it from my work bench!
Righty o! I have been asked how I go about making my decals so here it is:
I made a digital version of the templates first using photoshop which are then printed on to Tamiya masking sheets. These are great as they aren't so tacky and don't pull the decal off the backing sheets. Although care should still be taken.
I then use an array of tools to cut them out.
Then very carefully peel off the mask to reveal the decal underneath.
So with the decals cut it was time to apply them.
So with them all set it was time to look them in place with Tamiya X22. Once this was done I added the dark wood trims and the serial numbers and then it was time to give it an oil wash. This gives the wood such richness and more depth, creating a warmth in the effect as well as adding yet another layer of realism.
As you can see from the finish it makes the wood much more richer and vibrant.
Offline Pgtaylorart
« Reply #66 on: January 04, 2016, 08:32:26 PM »
Awesome, James! :D
George
Offline rhwinter
« Reply #67 on: January 04, 2016, 09:39:55 PM »
I love it!
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #68 on: January 04, 2016, 09:42:15 PM »
wonderfull result so far!
How are the original wood decals compared to Uschi's ones?
best regards,
Sasho
Think globally, act locally!
Offline FarEast
« Reply #69 on: January 04, 2016, 09:57:29 PM »
best regards,
Sasho
Thank you Sasho, to be honest I did not like them - they are very thick compared to other Wing nut decals. Also the fact that you are basically locked into one overall appearance if you use them didn't attract me either (I like uniquely different aircraft as you can see from my other builds)
In my own limited opinion I think more experienced modelers will be somewhat frustrated with them, while modelers taking the first step in wooden effects will appreciate them.
Offline Ssasho0
« Reply #70 on: January 04, 2016, 10:17:02 PM »
...... (I like uniquely different aircraft as you can see from my other builds) ....
Exactly my thoughts! I'm definately building one of those soonish.....relatively and was thinking of going the Oils-over-acrylics way, but Uschi's decals are awesome too!
Offline FarEast
« Reply #71 on: January 04, 2016, 10:51:06 PM »
Btw also if you use the kit decals you will loose all the small details on the fuselage such as the nail and rivet marks due to the thickness of them.
Offline miamiangler
« Reply #72 on: January 04, 2016, 11:16:14 PM »
Great work !
Offline TobyCoulson
« Reply #73 on: January 05, 2016, 03:29:01 AM »
An ispiration to me would be an understatement for all of your work and this is no exception
Online Umlaufmotor
« Reply #74 on: January 05, 2016, 04:37:50 AM »
Excellent work and first-class result.
The wooden fuselage acts absolutely convincing.
