Author Topic: Wingnut Wings 1:32 Albatros B.II Early  (Read 46420 times)
Re: Wingnut Wings 1:32 Albatros B.II Early
« Reply #135 on: February 28, 2016, 06:50:30 AM »
Looking absolutely superb James, you are doing an incredible job with this model.
« Reply #136 on: February 28, 2016, 07:06:06 AM »
Brilliant work, James!  The shading is just right.
« Reply #137 on: February 28, 2016, 09:16:04 PM »
I agree with Bud. JUST RIGHT!
Offline FarEast
« Reply #138 on: March 10, 2016, 04:16:30 PM »
So I have been working on the top wings as well as decals on the rear horizontal stabilizer.
Now I had a bit of an accident, no idea how it happened but I it looked like a chemical burn – not very happy especially after the whole piece was finished. So after stripping it of its decals and paint, I filled it in with Tamiya putty and then sanded it back in to shape.
I’m wondering if it was caused by Tamiya Airbrush cleaner that might have dripped on the work surface. Who knows!
So with the wings, I went about the normal process of Flat white base then this time I went off the beaten track – I’m pissed because I have lost the images after a PC brain fart.
I gave the base coat a coat of XF22 gloss and then laid down the decals that should have been on the tops of the wings. These again I locked in with Tamiya XF22 and left to cure.
From here I masked the wings so that the ribs and sub structure were exposed and painted airbrushed several coats over the decal so there were solid lines of white. I then applied several thin coats of flat white.
Again once the paint had cured I went about masking the wings off as normal and then applying the post shading with Tamiya Smoke, then using thinned flat white blend the smoke in with the white.
This creates the shadowing of the wing structure but also now we have the ‘Cross Pattée’ visible through the wing, again itwas all locked in with Tamiya XF22 and ready for the Aviattic rib tape and linen.
« Last Edit: March 11, 2016, 11:32:17 AM by FarEast »
« Reply #139 on: March 10, 2016, 04:18:31 PM »
Gorgeous!
« Reply #140 on: March 10, 2016, 05:28:06 PM »
Nice job James,
Your rib masking puts mine to shame  :(
« Reply #141 on: March 10, 2016, 05:32:48 PM »
Very nicely done James.
« Reply #142 on: March 11, 2016, 04:01:53 AM »
Great update.
« Reply #143 on: March 11, 2016, 10:20:36 AM »
Beautiful work on the wings, James.  Your shading is exquisite.
Great build log, my friend. :D
Offline FarEast
« Reply #144 on: March 11, 2016, 11:36:12 AM »
Thank you guys, I found another of the photos so scroll up and you can see the masking for making the solid white lines over the decal.
I had about 30 more showing each small step and I planned to do a tutorial, really unhappy about that.
Offline Dave in Dubai
  • Beyond the blue horizon
« Reply #145 on: March 11, 2016, 10:29:03 PM »
Good save on the elevator damage James.
It is very easily done and tends to happen when everything is going perfectly and then the unexpected happens.
Keep up the good work.
Dave :)
Offline FarEast
« Reply #146 on: March 25, 2016, 10:54:00 AM »
It's been a while since I made an update - I've been waiting on a few things to come and they finally arrived on the weekend.
Building up the wheel struts was very straight forward and I knew to drill all the points for anchors and turnbuckles before assembly and painting after the Fokker E.I build a while back.
So I spent a little time on the smaller pieces like the 'Elephant exhaust' I textured it with primer dabbing it on with an old brush and then applied the painted effects.
The prop is not yet finished - currently that is the base - Deck tan, oils applied for grain and then translucent orange and locked in with varnish - I will then use my masks to apply the laminated affect with a darker shade of brown.
I also used the last scraps of the Aviattic linen to cover the wheels with which really gave them a nice finish.
One last job was to place all the turnbuckles on the wings - a nice easy job to say that the locations are already marked, although it did require the removal of several of the anchor points already in the mold.
« Reply #147 on: March 25, 2016, 12:05:05 PM »
She's coming together beautifully James, looking forward to the next updates.
« Reply #148 on: March 25, 2016, 06:33:53 PM »
Absolutely beautiful work James! Everything is looking fantastic!
Offline FarEast
« Reply #149 on: March 26, 2016, 06:49:57 AM »
Many thanks Des, things slowed down due to a bit of 1:1 scale work as well :D
Many thanks sir! Although I never show the 'F%#@ Ups' I had actually finished the prop, lamination lines and decals all done and it was looking fantastic - put the final coat of clear on and started to clean up the work bench. While cleaning the air brush some cleaner must have flicked off of the brush or splattered and landed on the prop (God knows how as the drying stand is on a shelf above my work bench and well out of the way!) Sadly it streked the prop and killed the decal :(
So I had to strip the prop and start again, thankfully I have the another set of decals for the other Albatros I intend to build that uses the alternative prop!
