Author Topic: DFW C.V Late (1/32, Wingnut Wings) - 1.EW  (Read 5877 times)
Offline hadzi
Re: DFW C.V Late (1/32, Wingnut Wings) - 1.EW
« Reply #15 on: December 14, 2015, 06:26:13 AM »
SUPER Przemek!!!
Online PrzemoL
« Reply #16 on: December 14, 2015, 07:05:27 AM »
Thanks, Jurek! I am glad you like it.
Truly extraordinary all around, my old friend!  How did you handle the wheels?  Did you remove the tires to paint them?  They turned out spectacular as did the rest of the model.
Bud, sorry, I have missed your question.
Yes, I managed to remove the thin black tyres, painted the wheels, put the dark grey tyres on and added some wash. In the matter of fact, the tyres went off quite easily, putting the others on was a little bit more difficult, but it can be done by gentle rolling them on, bit after bit.
Offline LukasTheLight
  • Addicted to Wingnuts...
« Reply #17 on: December 14, 2015, 04:54:49 PM »
Hello!!!
Prze!!! How the did you build her so fast? :D :D Nonetheless results are stunning!!! ;) Fantastic work!!!
Cheerio
Lukas
Lukas
Offline KrzysiekK
« Reply #18 on: December 14, 2015, 05:27:17 PM »
Wow! Spectacular project!
Tedious work in each step of assembly :) Przemek, pls let me know how have you done the prop as it seems as just taken from production line..
regards
K
Online PrzemoL
« Reply #19 on: December 14, 2015, 06:39:31 PM »
Thanks, Lukas and Krzysiek.
Lukas, 9 weeks for a WNW two-seater is not too fast.
Krzysiek, the propeller was done by my usual method. First - a base coat of light beige colour. Then I prepare the masks with layers patterns - this I do on a sheet of paper with "pressed" outline of the blade side and the pattern itself drawn basing on a photo of the prop. Then I have to mirror-image it, I attach the masking tape on the opposite side and thus I can cut with scissors the masks with paper at the back. The paper can be removed and the mask is ready. After masking I spray a coat of darker colour - beige mixed with brown. After removal of masks the pattern may require some retouch. Finally a few thin layers of clear orange.
« Last Edit: December 15, 2015, 09:11:28 PM by PrzemoL »
« Reply #20 on: December 14, 2015, 06:54:48 PM »
Well, It could be that Im too slow  ;D nevermind, great work all the way ;) I wouldn't expect anything less anyway ;)
Lukas
p.s. It seems to me that you just started it yesterday... maybe thats why I find it so quick ;)
Lukas
Offline stefanbuss
« Reply #21 on: December 14, 2015, 10:00:15 PM »
Absolutely delightful. I think this is your best model, ever.
S.
Offline Russell
« Reply #22 on: December 14, 2015, 11:22:34 PM »
Very impressive indeed. Well done!
I like the contrast between the wings & the fuselage as well.
Russell
Offline Suffolk Lad
« Reply #23 on: December 15, 2015, 03:46:18 AM »
Absolutely superb result PrzemoL.
Wheels, Prop, Engine, shading and overall finish are truly superb, your skills are of the highest order.
Something to aspire toward to for sure  :)
Regards - Tug
« Reply #24 on: December 15, 2015, 06:10:49 AM »
Marvelous, as usual of your work and so quickly done, I'm envious.
Online PrzemoL
« Reply #25 on: December 16, 2015, 06:01:03 PM »
Many thanks for the kind comments on this DFW. I am very much flattered.
« Reply #26 on: December 18, 2015, 03:59:34 PM »
beautiful
Offline jeroen_R90S
« Reply #27 on: December 18, 2015, 05:12:18 PM »
What a beauty! Thanks also for explaining the propellor masking, meant to ask that, too :-)
Online PrzemoL
« Reply #28 on: December 21, 2015, 08:31:13 PM »
Thank you, Albatros and Jeroen, I am glad you like it, too.
