Author Topic: RFC/RAF Aircraft Maintenance and Repair Depot Rang-du-Fliers  (Read 5412 times)
Offline Hannover
« on: October 17, 2015, 09:10:29 PM »
On a global WW1 forum there is long running thread on the machinery used during 1914 - 18. This forum is predominately a land conflict centric community and to date there has been very little about the 1914 – 18 war in the air.
Recently one of the posters has been researching the IWM archives and come across some RFC related photos that I have never seen before so I thought they may be of interest and I would re-post them here.
Firstly all photos are Copyright IWM and images are reproduced strictly for non-commercial research and private study purposes as permitted under the Copyright, Designs and Patents Act 1988, as amended and revised.
I have also just copied the original posters comments for each photo. Obviously they are written for a different audience!
The town of Rang-du-Fliers in the Nord-Pas-de-Calais region of Northern France, was the location of a RFC/RAF Aerodrome and also a large aircraft maintenance and repair depot.
The first photograph shows intense activity at the RFC/RAF aircraft maintenance and repair depot, with aircraft mechanics stripping damaged aircraft for their valuable spare parts.
RAF aircraft mechanics working on wrecked aircraft fuselages at the RAF maintenance and repair depot at Rang-du-Fliers in July 1918, damaged aircraft were either repaired or stripped for their valuable spare parts.
A salvaged Royal Aircraft Factory SE5a aircraft ' C1902 ' fuselage is brought by trailer to the RAF's maintenance and repair depot at Rang-du-Fliers, where it will either be repaired or stripped for it's spare parts.
SE5a ' C1902 ' was from 32 Squadron, and flown by Lt. F. J. Connelly.
Apparently, it made a heavy landing after a flight on 9th July, 1918, and after inspection was considered too badly damaged for repair, was struck off, and salvaged for it's spare parts.
That report, ties in with the photograph in post 4064, which is dated 12th July, 1918.
An extremely interesting aircraft turntable, in use at the RAF Aerodrome and maintenance and repair depot at Rang-du-Fliers in Northern France.
This aircraft turntable, on which is mounted a Sopwith Camel, can rotate the aircraft through 360 degrees, and is used to check, adjust and re-set the aircraft's navigation compass utilizing the compass points marked around the large dial painted on the ground .
This photograph is dated 12th July, 1918.
Part of the important work carried out at RAF Rang-du-Fliers, was the salvaging, repair and restoration of aero engines taken from damaged or destroyed aircraft.
This photograph, shows RAF mechanics removing the aero engine from a damaged aircraft's fuselage using a block and tackle hoist gantry, the same type of hoist as that used by Army Service Corps mobile vehicle repair units. Having raised the heavy aero engine using the block and tackle hoist, it could then be lowered down onto the wheeled trolley already in position under the hoist, and wheeled to the engine repair shop. Whenever possible, the aero engines were repaired, restored and returned back into service.
This photograph, was taken in July, 1918.
It was extremely important that RFC/RAF aircraft mechanics were skilled in the removal, repair and restoration of all types of aircraft engines, and again, in this photograph taken in the Summer of 1918 at the then RAF Aerodrome and aircraft maintenance and repair depot at Rang-du-Fliers, we see RAF mechanics removing the typically smaller ' Rotary ' aircraft engine from a wrecked aircraft fuselage, so that rotary aero engine can be evaluated, and if at all possible repaired, restored and returned back into service as soon as possible.
Also of note, is the specially designed ' tub ' with the cut-out sides, designed to keep the rotary engine in place when lowered onto it.
Again, showing the wide range of skills RAF mechanics were required to have when working on the various types of aircraft encountered at the RAF maintenance and repair depot at Rang-du-Fliers, in the following 2 photographs, we see a Rolls-Royce 'Eagle ' aero engine which had previously been removed from a damaged aircraft, then fully repaired and restored, and is now being tested while mounted on a special wheeled engine test carriage.
Following successful testing, the restored aero engine would have been placed back into service.
The massive size of the 900 lb V-12 Rolls-Royce ' Eagle ' engine, being in stark contrast to the rotary engine shown in post #4079.
The Roll-Royce ' Eagle ' aero engine was the first aero engine to be developed and manufactured by Rolls-Royce, and was based on their highly successful ' Silver Ghost ' motorcar engine, with the Eagle's engine modified to a V-12 configuration.
The first Rolls-Royce ' Eagle ' engine ran on a test bed at their Derby works in February 1915, with the Eagle's first flight taking place in December 1915 fitted in a Handley Page 0/100 bomber.
The Eagle's V-12 piston, liquid cooled engine, was by 1918 producing 360 hp @ 1800 rpm, with a fuel consumption of 24 gallons per hour.
The RR Eagle aero engine had a dry weight of 900 lbs, was 72.6 inches long, 42.6 inches wide, with a height of 46.4 inches.
Attempting to turn the propeller to start the ' Eagle ' engine.
« Last Edit: October 17, 2015, 09:29:55 PM by Hannover »
Re: RFC/RAF Aircraft Maintenance and Repair Depot Rang-du-Fliers
« Reply #1 on: October 17, 2015, 09:15:45 PM »
Wow!  Great stuff.  Thanks for sharing these photos Hannover.
Offline Pgtaylorart
« Reply #2 on: October 17, 2015, 11:10:07 PM »
A great set of photos and descriptions! Thanks for sharing these. May I ask which forum they are from, Hannover?
George
Offline Hannover
« Reply #3 on: October 17, 2015, 11:27:03 PM »
George
Hi George,
The Great War Forum http://1914-1918.invisionzone.com/forums/index.php?act=idx
You may have to be a member to see posts. The thread they cone from is this one http://1914-1918.invisionzone.com/forums/index.php?showtopic=173218
Its a fascinating thread and currently is nearly 200 pages long.
HTH   P
« Reply #4 on: October 17, 2015, 11:27:39 PM »
Thanks for posting these; some really good photos of purpose built accessories such as the engine carts and the support "tub". Anyone doing a diorama or just adding a piece of equipment to their displayed models will find lots of great ideas here! 8)
« Reply #5 on: October 18, 2015, 12:51:20 AM »
Great photos, Hannover, thanks for posting them.
Offline Pgtaylorart
« Reply #6 on: October 18, 2015, 06:00:56 AM »
I just registered to The Great War forum. A lot of interesting stuff there!
George
« Reply #7 on: October 18, 2015, 06:17:59 AM »
Thanks very much Hannover for posting these wonderful photos, they give a great insight to what it was like back then.
Offline szymon
« Reply #8 on: October 18, 2015, 09:57:01 PM »
Thanks Hannover, great stuff, very inspiring. I already has one model  created based on these photos, may be next :)
Simon
« Last Edit: October 25, 2015, 04:21:43 AM by szymon »
Offline Hannover
« Reply #9 on: October 19, 2015, 12:04:35 AM »
Two interesting details from the last photograph in my original post (marked by arrows ) - an RAF guard with a shouldered rifle, and also what appears to be a German P.O.W., walking with his hands behind his back. Presumably, the armed guard is escorting the P.O.W(s). We know that German P.O.Ws were put to work at British depots and bases.
Copyright IWM This image is reproduced strictly for non-commercial research and private study purposes as permitted under the Copyright, Designs and Patents Act 1988, as amended and revised.
« Reply #10 on: October 20, 2015, 09:21:40 PM »
Thank you very much for this input, Hannover. A very nice collection of interesting photos. The very first was already quite familiar for me, and I have just recollected I saw it before in WNW website under Archive Photos section for their DH.9 kit. But the rest are new for me.
Offline Hannover
« Reply #11 on: October 21, 2015, 05:43:14 PM »
The repaired/restored Rolls-Royce 250 hp ' Eagle ' engines have been fitted back into the wingless fuselages of several DH 4's, and now 2-man teams of airman are preparing to rotate the propellers to start the engines for testing. Once the engines have been successfully tested and approved, the aircraft's restoration will be fully completed and the aircraft returned back into service as soon as possible.
Note the Airman's tents in the background, located on the perimeter of the airfield.
Copyright IWM These images is reproduced strictly for non-commercial research and private study purposes as permitted under the Copyright, Designs and Patents Act 1988, as amended and revised.
« Reply #12 on: October 21, 2015, 06:25:14 PM »
Thank you again for these wonderful photos, maybe all the ground crew doing their daily duties will encourage the figure sculptors to create many ground crew maintenance figures so we can create dioramas similar to the photos here.
Offline Hannover
« Reply #13 on: October 22, 2015, 05:19:33 PM »
For some reason, a DH 4 returning from a test flight failed to make a safe runway landing, and instead crash landed on the roof of one of the airfield's hangers. Fortunately, it appears that the crew were able to make it out.
Offline Hannover
« Reply #14 on: October 22, 2015, 05:22:09 PM »
Looking somewhat like a scene from 'Those Magnificent Men in their Flying Machines', an RAF Pilot/Captain at the Rang-du-Fliers Aerodrome is using a 4-draw telescope fitted to a bicycle wheel mounted on the tripod supporting the bicycle's front fork.
The un-named Pilot/Captain is still wearing his original Army Captain's cuff rank jacket complete with his pilot's wings, and interestingly, also his Military Cross ribbon.
Also of note, is his leather flying-helmet, and the 'Maternity' style officer's jacket complete with Sam Browne belt being worn by the officer on his left.
In the left background, is a wheeled portable oil/lubrication pump cart.
This interesting photograph is dated 12th July, 1918.
