Author Topic: Airfix "Harry Tate"  (Read 10668 times)
Re: Airfix "Harry Tate"
« Reply #30 on: August 23, 2015, 10:30:13 AM »
...and correct the rear fuselage, and the wingtips,  and the cockpit openings.....etc. etc....   ;-)
Offline Beto
« Reply #31 on: August 23, 2015, 11:27:22 AM »
Eduard offers PE control horns and turnbuckles (not sure if that term is correct for flat RAF wires) in 1/72
Offline Squiffy
« Reply #33 on: August 24, 2015, 06:31:01 AM »
But you have to draw the line somewhere...  :-\
Footstep added. This was a left over PE part from some other kit. Home-made Scarff ring fitted. This may yet be replaced...
Engine cylinder banks in place and holes drilled in the nose.
Highlighted spars and what have you.
« Reply #34 on: August 24, 2015, 07:27:19 AM »
Really starting to take shape now Squiffy, your attention to the cockpit detail stands out beautifully and was well worth the effort.
Offline Old Man
« Reply #35 on: August 24, 2015, 08:23:40 AM »
Nice to see another one of these being given some treatment, Sir.
I did one myself a while back:
http://forum.ww1aircraftmodels.com/index.php?topic=3398.msg57487#msg57487
« Reply #36 on: August 24, 2015, 09:28:54 AM »
The model comes very nice together.
« Reply #37 on: August 24, 2015, 01:35:11 PM »
Looking good Squiffy! Indeed you do have to draw the line somewhere - the problem is, where? Especially with this kit!
Offline Squiffy
« Reply #38 on: August 31, 2015, 02:21:49 AM »
A few more small parts added.
I made an Aldis sight from 1mm plastic rod and mounted it on brass wire brackets. The Vickers gun is now fitted and is also mounted on brass wire brackets.
I'm not at all happy with that Scarff ring - it'll have to come off.  >:(
The struts have been thinned in readiness for the big push to get the top plane fitted.
« Reply #39 on: August 31, 2015, 04:03:19 AM »
LOOKING GREAT! Your added details are really making a difference!
« Reply #40 on: August 31, 2015, 09:29:41 AM »
It gets better and better with each step you take, well done.
« Reply #41 on: August 31, 2015, 08:24:54 PM »
Very good progress, Squiffy.
« Reply #42 on: September 01, 2015, 06:35:43 PM »
Very nice work, Squiffy!
Offline Culi
« Reply #43 on: September 02, 2015, 05:01:22 AM »
Great job so far. I am following
The process meters...  therefore so much models are stuck between start and finish
Offline Squiffy
« Reply #44 on: September 02, 2015, 06:04:18 PM »
I have made significant progress on this old kite. Unfortunately I forgot to take pictures...
King posts made from plasticard and fitted to the upper planes. The Scarff ring that I made from plasticard was removed, widened, thinned down and re-fitted. The other parts of the gun mount were made from brass wire, plastic rod and nylon stocking.
The exhausts have been fitted. Mounting the exhausts directly onto the engine, as per the kit instructions, left the tops below the level of the upper plane so I made short headers, from plastic rod, to stand the manifolds away from the cylinder heads.
Most of the rigging is now in place, as is the landing gear. The kit landing struts were retained and modified but the axle was thrown away and new parts made from plasticard and brass wire.
« Last Edit: September 03, 2015, 07:23:14 AM by Squiffy »
