Author Topic: WNW 1:32 Wingnut Wings AMC DH.2 ( DH.2 7849, A Flight, 29 Sqn, September 1916)  (Read 12284 times)
Absolut stunning work and paint, James.
  James,
Good God man where have you been hiding! I'm completely blown away by your DH-2 my friend. She's a perfect showplace for your awesomely high levels of skill and craftsmanship. WELL DONE !!!
Offline FarEast
Yesterday was a bit of a stop, go, stop, go kind of day.
I decided to paint the prop and rudder, however things didn't go to plan!
First off my idea of layering Aviattic decals and then removing with thinner the top coat failed miserably and I was lucky enough to save the work I had done previously on it. Back to the drawing board on that one!
I think I will just go CDL and then a coat of PC10 and tinted lacquer over the top then applying thee worn weathering effect from there, but I decided to put it to one side and concentrate on the 4 blade propeller.
Now some of you fine and very talented gentlemen have been using coloured pencils to make laminated props and they look the business, absolutely incredible finishes, so I decided to see if I could replicate this technique...........
7 hours later - NO I BLOODY CAN'T!
So its back to playing to my strengths - MASKING TAPE!'
Having removed all traces of my first 8 attempts I coated the propeller with Mr. Finished thinned and applied through the airbrush (You need to clean it out immediately with lacquer thinner or Tamiya Airbrush cleaner or it will kill your brush!) The reason I use it is because it has great leveling properties and also helps Tamiya paints bond to the propeller better.
Now I normally mess around and make masks and I had a few left over from a previous batch I made and nope they were not the right size, so rather than mess around stretching and pulling the .psd file I decided to use the very pliable 1mm mask that I use for the rib taping.
It's pretty straight forward and apart from the first line of tape I used 1 continuous length for the others and anchored it down on the blade tips.
After checking that all the tape was firmly affixed, especially in the center where not only do they need to be perfectly parallel but have a tendency to pull up in the corners when you move on to the next blade, I sprayed a fine coat of Tamiya Nato Brown and then using a tooth pick pushed down the tape in the area again.
3 coats later and a beer it was time to remove the mask.
It always reminds me of chocolate! But the lines are way to sharp so after hand painting any corrections that might be needed I applied several more very thin coats of Tamiya Deck Tan. Now as long as you follow the lines you can really soften up some of the lamination lines and this will give the effects of different woods used and will really help when you apply the oil paint.
Next up was the oil paint, I use a Japanese brand with a touch of Uschi van der Rosten's excellent Blitz Dry and it really does what it says on the bottle - with two bladed props its not an issue but with a four blade prop I found it was drying before I could get to the 3rd blade to create the wood grain.
So with this done and not wanting to risk messing up the wood grain and all on top of the days failed attempts it was late and I decided to call it a night and go at it again this morning, that way the oils would be VERY dry!
My daughters alarm awoke me at 5am this morning, so before walking the dog I applied several thin coats of Tamiya Clear Yellow, this really gives a warmth to the finish of the wood and also a slightly satin finish. I forgot to take a photo so here is a picture of some bread rolls I made this morning while waiting for paint to dry :D
After the clear coat was dried I applied a very thin coat of a Japanese product that is very similar to Klear - I'm not sure if the formula is the same but it pretty much does what others have described Klear doing. This layer I applied by bursh and followed the wood grain, after that I applied several more very thin layers using the airbrush and masked up the prop using the excellent and very helpful HGW masks.
First I tried the Brass Tip finish but I really didn't like the way it looked in comparison to the rest of the machine so removed it with lacquer thinner and went with Tamiya XF-66 that pretty much coats everything on this aircraft.
Slowly and carefully I removed the masking tape and took a huge sigh of relief.
Now one of thee other issues is that Wingnut Wings is very vague about the propeller used on the DH.2 so after 2 hours of searching on the web and 20 cups of coffee later I found out that some of the DH.2's were fitted with DMD.Ltd propellers and some kind gent had even posted a picture of his - so on with the decals and another very fine coat of varnish!
DONE! now where is that rudder?
Superb prop, James!  Truly exquisite!  By the way, your photography is da bomb.
Offline Pgtaylorart
Your DH.2 is coming along very nicely! I gotta get in gear on mine, you're pulling far ahead! (not that it's a race... ;D)
George
Offline Verbeek
Great work, I love the way how you build this beauty.
Out of all the things I have lost, I miss my mind the most.
Beautiful job with the propeller James, well worth all the effort.
Offline FarEast
Thank you coyotemagic, I really appreciate your kind words!
I have 3 tools in my Arsenal:
My phone camera, believe it or not majority of the photos including ones on a white background are taken with this and if its a small piece like the prop I use a few sheets of A4 paper as a backdrop!
When I have time though I break out my Nikon and Sigma Macro Lens and Flash unit
and finally the Tamiya Photo tent, I had these all before getting in to scale models as I used to write product reviews for magazines and needed to take photos of the products.
Very nice! Where did you get the thin tape?
Tape is called Micron masking tape, its pretty good and strong so you can pull it about some. However its not as good as the new Tamiya flexi tape.
Size 1 is 0.5mm and size 5 is 1.7mm
George
Thank you George, is there a build log anywhere for yours would love to see it!
Actually I'm almost done! I just need to paint the fin on the rudder and then assemble and rig the rear end! :D
Many thanks guys and all the others that took the time to post, I really appreciate your comments and it motivates me to push that little harder for perfection.
Here is one last shot - Propeller installed! :D
Offline Pgtaylorart
James,
Here's my DH.2 build log:
http://forum.ww1aircraftmodels.com/index.php?topic=5960.0
Cheers!
George
Offline Ssasho0
    • Scale Models Club Bulgaria
welcome ot the best forum :)
I really like what you are doing with the DH.2 and will use this buildlog as a starting point for Aviattic decal usage
best regards,
Sasho
Think globally, act locally!
Offline Dave in Dubai
  • Beyond the blue horizon
Yeup,
The prop looks very like the originals that Bob Gardener was selling on Aeroclocks several years ago.
Sadly he no longer deals in these any more, but his volumes on propeller production are very well researched and written if ever you get the chance to read them?
You have got my creative thoughts lit up again to continue the DH-2 as flown by E Pashley from 24 Squadron as the next project.
Keep up the great work James!
Best wishes,
Dave :)
Offline FarEast
Yeup,
Best wishes,
Dave :)
Dave, do you happen to have any images of the DMD logos?
I may well have James,
But I don't have access to the books here in Dubai.
Standby and I will get in touch with Bob and see if he can help me out....
Offline Umlaufmotor
Yepp, I love your paintwork, @FarEast  ;)
Really a great job.
And really a very nice way to display the model images.
Offline FarEast
I think this is very apt!
https://youtu.be/Od6hY_50Dh0
So today I started in earnest on the tail plane and rudder rigging.
Now having spent the most of the morning looking at all the images of replica DH.2's and also the Windsock data files I realised that the eyelets on the mold needed to go!
Fresh blade, 0.3mm drill bit and some Gaspatch turnbuckles and additional eyelets later and the tail boom was ready.
After drilling out and attaching eyelets and turnbuckles I cemented the main parts together and started anchoring the rudder & tailplane to the boom.
Once it was firmly secured it was time to start rigging the rear box section.
I have to say the manual sent me boss eyed!
« Last Edit: August 20, 2015, 12:14:59 AM by FarEast »
