Author Topic: Wingnut Wings DH.2 1/32  (Read 30330 times)
Offline Oeli
Re: Wingnut Wings DH.2 1/32
« Reply #150 on: December 05, 2015, 07:33:50 PM »
Hi George,
sorry, what is a boom?  :o
And then I indeed glad I have the elastic line from "Uschi"! ;)
Jörg
Offline Pgtaylorart
« Reply #151 on: December 05, 2015, 09:30:23 PM »
Jörg,
The boom is the section on a pusher airplane that connects the front of the airplane to the rear. "Boom" is a long rod or pole. The rods and struts that are braced with wire as shown in the photo. :)
George
Offline Oeli
« Reply #152 on: December 05, 2015, 10:39:09 PM »
Thank you so much George, now everything is clear.
Have a nice weekend!  :D
« Reply #153 on: December 06, 2015, 08:29:47 AM »
Great work on the DH2 George!
I also had a bit of trouble with a slight misalignment of the tail due to a twist on the boom assembly. It happened after the glue had set on the rudder & elevator assembly. EZ Line was used for the rigging. I ended up routing a stronger line of invisible thread from the tail through to the elevator control horn by the cockpit, pulling just the right amount of tension to align the tail, then securing the line with drops of cyano at the wing pulley and control horn.
Offline Pgtaylorart
« Reply #154 on: December 06, 2015, 08:43:30 AM »
Thanks, Gary!
I'm hearing a lot of stories about the boom. I really appreciate all the advice. Now I'm going to take every bit of precaution to line everything up properly and hopefully not twist it out of shape with the rigging!
George
Offline Rob
« Reply #155 on: December 06, 2015, 10:12:25 AM »
I agree that the elastic line should prevent twisting the boom out of shape. It's also more forgiving when you bump it with tools or fingers ;D
Have fun!,
Rob
« Reply #156 on: December 06, 2015, 11:47:07 AM »
Beautiful work on the paint finish George  :)
« Reply #157 on: December 06, 2015, 11:58:15 AM »
George, are you using the kit booms or are you replacing them with brass tube?
Offline Pgtaylorart
« Reply #158 on: December 06, 2015, 12:14:13 PM »
Thanks, Rob and Terri! :)
Des, I am using the kit booms, but after hearing about all the issues, it might be a good idea to replace it with brass. It would be a very easy job to knock together with a bit of solder in the right places. If I have too much trouble, I'll switch it out.
George
« Reply #159 on: December 06, 2015, 09:32:45 PM »
Great progress on the DH, George.  As for the rigging, I think I tend
to go with Przemo, especially with this amount of lines.  I am edging
closer to building one of these beasties so I am following your excellent
example closely.  Really beautiful work, my friend.
Offline Pgtaylorart
« Reply #160 on: December 07, 2015, 02:18:39 AM »
Thanks Ernie!
Offline pietro
  • What?! Are you kidding?!
« Reply #161 on: January 24, 2016, 05:44:41 AM »
George, this is absolutely stunning work! Your wings look great! As for the booms, I went with brass tubing on that scratch-built 1/28. I love your treatment on the metal panels.
Pietro
« Reply #162 on: January 24, 2016, 08:23:20 AM »
Moving along nicely !!
WarrenD
« Reply #163 on: January 24, 2016, 09:14:35 AM »
Nice work George. Sounds like you're making good progress.
