Author Topic: Wingnut Wings Sopwith Snipe - Major W. Barker  (Read 34286 times)
Re: Wingnut Wings Sopwith Snipe - Major W. Barker
« Reply #120 on: September 08, 2015, 09:55:14 PM »
Rick and Stefan, thanks for taking a look and for the votes of confidence! Like many little steps in the process the Post Shading concept was acquired from this Forum.............your Amigo, Bud, got me started on it a few years back! As many have remarked here, sharing is one of the big rewards of participation here! :) :) :)
« Reply #121 on: September 08, 2015, 11:45:57 PM »
Gorgeous job of the post shading, Lance!  Thank you for
the information regarding the tools you use...they really
do a convincing job when in your hand!  The Snipe is
looking absolutely superb, so strut away, my friend! ;D
« Reply #122 on: September 08, 2015, 11:51:36 PM »
Thanks Ernie, I have the cabanes on but may not be able to get back to her until tomorrow, real life beckons once again..........
Offline Pgtaylorart
« Reply #123 on: September 09, 2015, 12:51:23 AM »
Thank you again for the info, Lance! You are right about sharing on this forum. I have learned more in the last year since I've been on this forum than I have for years and years before I joined!
George
Offline jknaus
« Reply #124 on: September 12, 2015, 02:30:44 AM »
Beautiful work Lance. Will have to bookmark the weathering lessons. Thanks :)
James
« Reply #125 on: September 12, 2015, 03:09:07 AM »
James
Dittos, will do same, nice work.
« Reply #126 on: September 12, 2015, 06:03:16 AM »
    Thanks James and Ed. It's a slow go these days, I had hoped to have another update earlier then this, now I'm still a day or so behind!
« Reply #127 on: September 15, 2015, 03:07:18 AM »
    Finally ready for another update before I get too far along, Chris is really progressing on his Late "Silver Bullet" version and cracking the whip to keep me going!
   The cabane struts were installed with the help of a simple template/jig to ensure proper attachment and alignment of the upper wing. Once the positioning was satisfactory ultra thin CA was run into the bottom strut locations. The very positive fitting and alignment of the cabanes eliminated the requirement for  a full "Biplane Jig" on this one. They were then rigged with Modelkasten stretchable rigging thread to prevent sagging as the various other struts and lines exert force on the assembly.
......and the results
    The aileron inspection windows were added, such a perfect fit that no glue was required. The dust was removed after the photo was examined!
    I then installed the windshield and the fuel system venturi, the latter which I have since re-installed three times due to insertion of fumble finger frolics into my work pattern!!
    The interplane rigging was installed on the bottom surface, aileron control wire and turnbuckles added, and the cross bracing in the center section added. I used Maxima Chameleon 0.12 mm mono for the rigging, first time I've used it and I love the stuff, Thanks Chris! The aileron control wire is steel guitar string. The fuselage oil staining and grime added where required and the cockpit leather coaming and center section overhead cross member were given a bit of wear and grunge using Winsor Oil Lampblack. Once the upper wing was attached to the cabanes the inner bay interplane struts were attached. They'll be cross rigged next before the process gets repeated on the outer bays.
    A little grime on the coaming and hand hold.......
  ......a few shots of the center section work, the hole on the right forward cabane mounting will be patched and cosmetically restored later, just another brief insertion of the builder's head into his lower body cavity, nuff said about that little episode!!
......a few shots of the oil staining, thanks to Jamo's excellent photos of the TVAL Replica Snipe in our Forum.
    And next all the little lines start to get tied to their various anchor points to hold it all together.
  It's a typically spectacular Wingnut Wings Kit but I'm finding it a real challenge. Most problems have been very much self induced, maybe I'm just rusty or age is starting to impact on my results. Could be getting real close to a shift into 1:24 Scale! :P :-\
« Last Edit: September 15, 2015, 03:11:51 AM by lcarroll »
« Reply #128 on: September 15, 2015, 05:54:32 AM »
Your Snipe is looking greater and greater Lance. We wants one, we wants one, too :-)
« Reply #129 on: September 15, 2015, 06:53:01 AM »
Outstanding work, Lance!  She's shaping up beautifully.  I love the jig.
Offline Suffolk Lad
« Reply #130 on: September 15, 2015, 07:02:19 AM »
Hello Lance,
Just been catching up with this build with interest as a Snipe is in the stash awaiting it's turn.
Just like to say that despite the 'accident' with the hairspray I think the effect after weathering is very realistic and quite 'different' - a 'mistake' definitely worth remembering to try to emulate for the future.  Also I really do like your CDL result with the darkened ribs - again all 'grist for the mill' and something also noted for attempting.
Looking forwards to seeing the rest all come together in coming days
Regards - Tug
« Reply #131 on: September 15, 2015, 07:31:51 AM »
This is looking spectacular Lance, each step I the building progress just gets better and better. The oil staining looks very realistic as does the paint chipping, you are doing an excellent job with the rigging, overall a very stunning looking model.
Offline jknaus
« Reply #132 on: September 15, 2015, 08:27:49 AM »
More awesome ideas. I'll have to make a jig up when I'm building now that I see how easy and useful it is. I think next pay I will have to get another Snipe and another set of decals and start mine all over.
 :D
James
« Reply #133 on: September 15, 2015, 11:15:10 AM »
Many thanks to Bud, Prze, Des, and James, I much appreciate your feedback and supportive comments! Tug, I'm not sure I'd repeat the "rushed hairspray trick" again, although the effect is growing on me.
« Reply #134 on: September 15, 2015, 12:53:51 PM »
Another terrific update! It is really coming together, and in a Fantastic fashion! Your rigging is top notch!
