Author Topic: Short 184, Aeroclub, 1:72  (Read 42290 times)
Re: Short 184, Aeroclub, 1:72
« Reply #105 on: August 30, 2015, 07:23:46 AM »
Thanks all, for your comments, they are much appreciated! Not much further to report, I've been working on the torpedo and the aileron corrections. I'll update when I have something worth showing!
« Reply #106 on: September 03, 2015, 12:27:15 PM »
A small progress update:
I got some primer on the lower wings where I've corrected the ailerons and I'm happy with those so painting will proceed there.... ditto the torpedo - a little filler needed in one small spot but other than that I'm more than happy with it.
Looking for something to do today so I fitted the tail float and rigged it with stainless wire...
Next up is to fit and rig the torpedo.....
« Last Edit: July 02, 2017, 11:14:27 AM by IanB »
« Reply #107 on: September 03, 2015, 12:53:30 PM »
You have done a great job Ian with the tail float.
« Reply #108 on: September 03, 2015, 01:48:57 PM »
  Ian,
As always my old friend exceptional works come from your bench. Keep up the progress.
« Reply #109 on: September 03, 2015, 05:18:35 PM »
Looks mighty fine!
« Reply #110 on: September 03, 2015, 07:57:57 PM »
Very beautiful work, Ian.
« Reply #111 on: September 05, 2015, 05:49:36 AM »
Brilliant work, Ian!  She's shaping up beautifully.
« Reply #112 on: September 05, 2015, 08:27:02 AM »
That is one very impressive model. Excellent update, looking forward to more.
« Reply #113 on: September 05, 2015, 11:57:42 AM »
Nice work on the tail float and rigging! Beautiful model to date and I am looking forward to your next update.
« Reply #114 on: September 05, 2015, 12:53:06 PM »
Thanks to all for your comments, they are very much appreciated!
Today I got the fins fitted and a coat of basic steel on the torpedo, along with repainting the lower wings. Pics to follow.....
« Reply #115 on: September 16, 2015, 11:28:39 AM »
 I've been taking a few steps backwards this past week. Not deliberately, but I just seemed to get clumsy! I knocked 3 of the torpedo's fins off, and then managed to clip the tail float, resulting in it coming loose and popping the rigging out....  that has now all been fixed and I've managed to progress a little further.
  I decided to add the tail feathers before the torpedo, but then I noticed that I hadn't corrected the fin, so that had to be done. The actual aircraft has quite large gaps between the fabric on the fin and the fuselage, so the mounting slot in the fuselage was filled, the "peg" on the fin removed, and the fin itself sanded along the bottom to represent the curve of the fabric. The bottom of the fin was then drilled and plastic rod "pegs" fitted to mount the fin to the fuselage. The cut out at the front of the horizontal stabiliser was also filled before it was fitted. A little touch-up is needed along the top of the fuselage where the corrections were made but other than that it's done and I'm much happier with it now.
I then decided to make a trestle for the tail out of HO scale 4x6, and 2x4 - close enough for me!
and here is how it'll go together on display....
Thanks for looking in!
« Last Edit: July 04, 2017, 12:52:15 AM by IanB »
« Reply #116 on: September 16, 2015, 11:46:10 AM »
Very nice work on the trestle Ian, and the fin and tail plane look really good.
« Reply #117 on: September 16, 2015, 07:25:36 PM »
That is a nice update, Ian.
« Reply #118 on: September 16, 2015, 07:58:11 PM »
Two steps forward, one step back. But the progress is there! Nice update, indeed.
« Reply #119 on: September 16, 2015, 10:47:43 PM »
You have done a great job recovering from your mishaps and the results are looking outstanding!
