Author Topic: Using Heat Shrink Tubing Instead of a Brass Collar on Turnbuckles  (Read 6107 times)
Re: Using Heat Shrink Tubing Instead of a Brass Collar on Turnbuckles
« Reply #15 on: January 26, 2015, 05:34:40 PM »
Thanks very much boggie, I will check it out.
« Reply #16 on: January 27, 2015, 03:55:06 PM »
i think it would be great to use in conjunction with brass tube or gaspathch as well. say you have a turnbuckle mounted to a wing in the past you had to run the mono thru the tb and back thru a 1mm length of brass tube and pull tight to make the wrap that holds the cable end in a loop. get me.
« Reply #17 on: January 27, 2015, 05:26:43 PM »
I get you Albie!   ;)
I used polymide tubing in conjunction with brass tube on my Pfalz.
VB
Offline NinetythirdLiberator
« Reply #18 on: January 28, 2015, 03:03:00 PM »
Von Buckles...THAT'S what I'm talking about.  That looks sweet.  ;) ;)
Dan
Offline Berman
« Reply #19 on: January 29, 2015, 02:57:15 AM »
  I once experimented with some small diameter electrical grade heat shrink tubing. It was possible to use a fine sewing needle to expand the entire inside diameter to make it easier to pass through the monofilament.  Perhaps this might also work with the Vention Medical tubing although I am unsure what  micro sized tapered instrument would fit into a .010 diameter tube for the purpose of stretching it. Maybe a piece of .015 inch diameter music wire with a finely ground tip.
« Last Edit: January 29, 2015, 04:09:15 AM by berman »
