Author Topic: Roland C.II Wingnut Wings  (Read 20613 times)
Re: Roland C.II Wingnut Wings
« Reply #15 on: December 08, 2014, 07:30:56 AM »
Hmmm... IPA means India Pale Ale in my book, which, in fact tends to reactivate me to a certain extent (but once the two bottle threshold is exceeded, the opposite effect quickly sets in). However, you probably meant something different.
Yes, sorry IPA = IsoPropyl Alcohol in this context
has to be the strong stuff (91%)
Start with a drop of paint from the jar off a toothpick into a plastic palette cup. Add a small drop of IPA. If it is too thin at first, wait 30 seconds :) Add IPA as needed to the paint while you work to keep it the consistency you like...even if it dries out completely in the cup you can resurrect it with IPA and it will still flow beautifully and stick just fine...
Offline eindecker
    • Models In Scale
« Reply #16 on: December 11, 2014, 11:54:19 AM »
Finished the cockpit tonight. Taking the entire kit and tool box home this weekend. Will be able to set up my workbench and do the rest there. iPhone 6 photos, with room light, so sorry if they are kinda wonky.
Michael Scott
« Reply #17 on: December 11, 2014, 11:57:32 AM »
Excellent!
« Reply #18 on: December 11, 2014, 01:56:40 PM »
Absolutely brilliant cockpit, Eindecker!  Looking forward to following this one.
Offline KitRookie37
« Reply #19 on: December 11, 2014, 03:43:47 PM »
Hello to all,
Charming home... Excellent !! Congratulations !!
Best regards.
Alain.
Use the force, Luke.
« Reply #20 on: December 11, 2014, 08:27:18 PM »
Wounderful Cockpit.
« Reply #21 on: December 12, 2014, 01:56:42 AM »
Beautifully  done interior! I am definitely looking forward to your continued progress!
Offline eindecker
    • Models In Scale
« Reply #22 on: February 03, 2015, 07:45:25 AM »
I am getting more build time. I am about ready to close the fuselage after painting and mounting the header tank. I drilled a .35mm hole in the filler neck to accept my version of the pressure relief tube. The tube will be made from "Larva Lace", a plastic stretchy tube made for tying trout flies, reinforced with a small diameter copper wire so it will take and hold a curve later on.
I highlighted the interior tapes with a heavier gray pastel so they would be a bit more obvious once the fuselage is closed. I also added a little extra to the port fuselage wall in the observer's compartment to tie the instruments better together.
Considering the way in which the main subassemblies are designed, I'm thinking of painting and preparing the wings and tail sections separately before bringing them all together. I'm close to the painting stage and will be considering how to pre-shade and mottle the fuselage and wings so that the overall blue will be more interesting and reflect some use in the field.
Michael Scott
« Reply #23 on: February 03, 2015, 01:55:57 PM »
I somehow missed this update. Your interior looks Awesome!
Offline BigBlue
« Reply #24 on: February 03, 2015, 02:17:44 PM »
Wow, I'm just getting caught up... looks great!
« Reply #25 on: February 03, 2015, 10:13:55 PM »
Wonderful work on the cockpit, Eindecker...your brush
painting puts my airbrushing to shame.  Really well done!
« Reply #26 on: February 04, 2015, 05:54:59 AM »
Very beautiful work Eindecker.
« Reply #27 on: February 04, 2015, 10:49:48 AM »
Shaping up very nicely so far ! :)
Offline eindecker
    • Models In Scale
« Reply #28 on: February 04, 2015, 11:08:37 AM »
Thanks, everyone. I got the header tank prepared and installed, then closed the fuselage. Had a small gap next to the lower wing root, but should be easily dealt with. I like it that the four windows allow more of the interior to be seen.
Michael Scott
Offline eindecker
    • Models In Scale
« Reply #29 on: February 08, 2015, 10:32:03 AM »
Update. Fuselage closed. Seams dealt with. About done with the fuselage assembly. Will be working on the wings, undercarriage, tail and guns separately, then bringing them all together.
Michael Scott
