Under Construction
LVG C. VI Wingnut Wings
Pages:
3
Topic: LVG C. VI Wingnut Wings (Read 7335 times)
Dol
Jr. Member
Re: LVG C. VI Wingnut Wings
Reply #30 on:
January 11, 2015, 02:38:13 AM »
Hi,
I'm working on the fuselage. After the woodgrain decals, I varnish it. Unfortunately I have had some troubles with my airbrush
So I had to sand and varnish and sand and varnish...... No matter it's OK now, not perfect but OK. However I wonder whether the varnish isn't too much matt. What do you think ? (perhaps it's difficult to consider on a picture). As I'm working on the fuselage I've already stuck the different decals and I've made some weathering. I'm not sure to do the different stages in the best order. Generally the weathering is the last thing you do when the building and painting is over. And there is still work to be done
Jean-Luc
coyotemagic
Reply #31 on:
January 11, 2015, 02:56:11 AM »
Jean-Luc, I think the varnish and weathering are perfect. All of the wear is right where it belongs. I think one last coat of semi-gloss after all is complete will bring out the luster nicely.
Last Edit: January 11, 2015, 07:16:45 AM by coyotemagic
Ian from Doncaster
Reply #32 on:
January 11, 2015, 07:07:21 AM »
I think this fuselage is just right, Jean-Luc. Will be a stunning model when complete.
KitRookie37
Sr. Member
Reply #33 on:
January 11, 2015, 07:25:55 AM »
hello to all,
Very nice wood grain effect.
Best regards.
Alain.
Use the force, Luke.
IFF1418
Reply #34 on:
January 11, 2015, 08:00:29 PM »
Hello Dol,
Now this is a wonderful build. I like your wood grain, the engine will be gorgeous and your fuselage exterior tremendously good. A very clean and exquisit build!
Kind regards
Patrick
Reply #35 on:
January 11, 2015, 11:43:53 PM »
Your fuselage is looking Awesome!
Dol
Jr. Member
Reply #36 on:
January 16, 2015, 05:43:21 AM »
A very small update with the leather around the cockpit. It's too smooth on the model so I 've carved it a little bit. Afterwards it is painted with artist acrylics ""burnt umber" and "burt sienna". The seam is painted.
Currently I'm working on the engine. So many springs to built it's quiet irritating
Last Edit: January 16, 2015, 06:14:56 AM by Dol
lcarroll
Reply #37 on:
January 16, 2015, 05:55:16 AM »
Jean-Luc,
Very impressive improvement on the leather work, well done!
Umlaufmotor
Reply #38 on:
January 16, 2015, 07:00:43 AM »
The leather rim is very nice - I like it very much.
You're right, Jean-Luc - he is too smooth on the model. Very good idea to make this rim a little bit wavy.
Des
Reply #39 on:
January 16, 2015, 07:13:53 AM »
Very nicely done with the fuselage wood grain and the leather cockpit padding is brilliant.
jknaus
Reply #40 on:
January 16, 2015, 07:32:52 AM »
Gorgeous. I agree with Des on the leather. Awesome.
James
coyotemagic
Reply #41 on:
January 16, 2015, 08:39:08 AM »
Beautiful!
Reply #42 on:
January 16, 2015, 02:18:41 PM »
The change in the leather work is perfect!
stefanbuss
Reply #43 on:
January 16, 2015, 04:16:28 PM »
The leather coaming is very impressive - and a nice improvement from the original. Well done.
Stefan
Pages:
3
Under Construction
