Author Topic: Roland C.II Wingnut Wings 1/32  (Read 10129 times)
WarrenD
Re: Roland C.II Wingnut Wings 1/32
« Reply #45 on: December 29, 2014, 05:13:32 AM »
Backing sheet from . . . . ?
My apologies to Michel and other list members for taking Michel's wonderful build thread off topic. I'll start a new thread for this so as not to disrupt.
Offline gruson
« Reply #46 on: December 29, 2014, 09:55:23 PM »
Warren, It's the Oramask 810   ;)
Beginning of the weathering with oils...Black, white and Burnt Umber.
And just for the fun: assembling without glue
Soon ;D
Je suis Charlie
« Reply #47 on: December 29, 2014, 11:52:17 PM »
You work wonders with an airbrush.
Michael Scarborough
« Reply #48 on: December 30, 2014, 12:19:00 AM »
Michel (Angelo),
Really superb and inspirational work.
Can you share a little bit about the use of the oils, s.v.p. This really interests me and I'm sure the others. I apologize if these seem like a lot of elementary questions but this technique is new to me and I want to understand it.
Would you say that you are using the oils like a canvas painter would use a glaze? Are you applying them with a brush?  How much are you thinning them?  Do you have any photos of a specific spot before and after the oils are applied?
Thanks very much.
Cheers from NYC,
Michael
Michael Scarborough
« Reply #49 on: December 30, 2014, 12:28:04 AM »
Michel.....I just went back to your Brisfit build and found this:
Weathering make with oil paints, four colours were used : white, Naples yellow, “Ombres brûlées” and black. They are applied with a brush, without dilution and as spread out as possible.
Oil paints suit perfectly because you can work on it with no rush, you can mix it and dose the level of opaqueness. Black is applied first on the least subjected to light areas, having naturally defined subjectively the position of the sun.
Any more thoughts on the technique? This is super.
Thanks!
Michael
Offline sodium
  • SPA48 chante et combat
« Reply #50 on: December 30, 2014, 06:57:53 AM »
Hello michel
I had a dream to be able painting a kit like you ... 8)
bravo, with Bristol Fighter, 2 magnific lessons
philippe
WarrenD
« Reply #51 on: December 30, 2014, 09:00:33 AM »
Beautiful work Michel!
Offline gruson
« Reply #52 on: January 02, 2015, 03:41:54 AM »
Thank's  ;)
The propeller dry and it will be finished!
Soon for the model completed.
Happy new year  8)
Je suis Charlie
Offline KitRookie37
« Reply #53 on: January 02, 2015, 04:02:14 AM »
Hello to all,
Yeah !!! A great one !
Friendly.
Alain.
Use the force, Luke.
Offline eindecker
    • Models In Scale
« Reply #54 on: January 02, 2015, 04:59:35 AM »
Very nicely done Roland. I am partial to models that attempt to show the effects of what I sometimes call "WAD" (wear, abuse, damage) and yours is another fine example. I am appreciating, and using, more and more oils to achieve better effects in this area. I learned what is sometimes called the "dot filter" effect when building armor models. I use four or five different colors of oil paints applied in very small dots with a toothpick in random spots over the surface I will be working with. I use sometimes odd colors such as blue, red, white, yellow, black, etc. that don't have counterparts in the basic paint color scheme. Somehow these usually combine to create realistic tonal and color effects anyway.
I will then use a wide, chisel shaped brush with short bristles, dampened (slightly) with turpenoid or other oil thinner, and blend the colors, brushing in a logical direction, such as along the airflow lines on wings and vertically along fuselage components, etc. until I get a varied, multi-hued effect that looks good to me. I'm sure there is some artistic, color basis for this, but I don't know what that might be. I like to visualize where the light might be coming from on a subject and go for lighter and darker areas accordingly.
I think oils have a wide application in modeling, especially in weather beaten, abused and ageing WWI aircraft.
Michael Scott
« Reply #55 on: January 02, 2015, 09:20:11 PM »
Inspiring work, Michel. Wow!
« Reply #56 on: January 03, 2015, 03:02:39 AM »
What a beauty, Michel!  I love how you executed this unique scheme.
« Reply #57 on: January 03, 2015, 03:03:57 AM »
It is a very superb work Michel!
Offline stefanbuss
« Reply #58 on: January 05, 2015, 08:27:17 PM »
Your photos with a light grey background are much better (and easier to the eye). Please don't use a black background any longer. Your models are such beauties, they deserve to be seen with a better surrounding!
Stefan
