Author Topic: WNW Fokker D.VII (OAW) Willhelm Leusch  (Read 21895 times)
Re: WNW Fokker D.VII (OAW) Willhelm Leusch
« Reply #15 on: February 01, 2016, 08:27:00 AM »
 Adam,
Outstanding engine and cockpit my friend.
« Reply #16 on: February 01, 2016, 08:47:12 AM »
Adam,
Great to see you back on this one! Your cockpit looks outstanding as does the engine!
« Reply #17 on: February 01, 2016, 09:22:39 AM »
Adam,
Another ditto !!
Offline moustique
« Reply #18 on: February 03, 2016, 03:02:12 AM »
your build is terrific
I take a ticket to follow this ;)
« Reply #19 on: February 05, 2016, 05:58:52 AM »
Great work Adam.
Offline Adam
« Reply #20 on: March 11, 2016, 12:36:20 AM »
Thank you my friends for the good word.  :)
I decided to make small upgrade of the engine.  ;)
To set the levers of valves had to be cut timing gear.  :o
Then I made holes for the  axles .
Then I made holes in the levers.
Timing system was reassembled again.  ;D
The levers are ready for installation.
Whole timing gear has been mounted to the engine.
Now they have been installed valve springs.
Now is the time for the spark plugs.
Then came time for the installation of wiring.
Above you can see small tragedy,  :'(  the two spark plugs have chosen the freedom.  :-X
The engine is almost ready.
That nothing more is not lost, I did such a case. The inspiration was this image taken from Wngnuth.
And now I can safely proceed to further work on my model.  ;D
Adam.
« Reply #21 on: March 11, 2016, 01:44:11 AM »
 :o Bloody marvelous, Adam!
« Reply #22 on: March 11, 2016, 03:30:22 AM »
what a phantastic build, Adam, congratulations! I especially like the engine.
« Reply #23 on: March 11, 2016, 03:36:56 AM »
   I'll double that comment! Very impressive work on the engine, Adam, you have a really spectacular Build going here.
« Reply #24 on: March 11, 2016, 03:59:12 AM »
Exellent work to the engine Adam.
Offline moustique
« Reply #25 on: March 13, 2016, 04:07:31 AM »
very good work
this engine is fabulous
Offline iwik
« Reply #26 on: March 14, 2016, 06:59:36 PM »
Hi!
Excellent!
iwik
« Reply #27 on: March 14, 2016, 08:23:49 PM »
A very impressive looking engine Adam, you have done a superb job.
« Reply #28 on: March 14, 2016, 11:58:34 PM »
Plus one Amigo!
« Reply #29 on: March 31, 2016, 12:01:31 AM »
Adam, may I ask you what kind of red wiring you used for your engine that still makes me envious every time I look at it?
Borsos
