Under Construction
Bristol M.1C Blue Max 1/48
Topic: Bristol M.1C Blue Max 1/48 (Read 3151 times)
Dric
Jr. Member
November 24, 2014, 10:43:40 PM »
Hello all
There is now a lot of time (I'm a slow builder) I began to build the Bristol M.1C from Blue Max
I posted some progress in an other forum that seem to be out of activity now. So, please forgive me for all the people who may already saw a part of this wip.
My first concern was about the internal structure. I keep a part of the white metal structure and add some plastic profiles
I scratch some internal parts too (oil and gas tank, plus the amunition box that finaly I don't use, as the deco I would like to realise is for an unarmed aircraft)
Next I decide to open the lateral hatches, and found that the plastic, if trimmed, becamme verry fragile. So I made a new part with brass and copper. For my facility, I cut the wings and recreate a new cockpit roof in a formed copper sheet.
Tiem was comming to add some details and repair to the fuselage. I recreate the ribs with copper wire, put some old photoetch on tail.
I equally recreate the ribs on wings with plastic rods.
It was time to push the details for the cockpit
And try to put everything together
I was not satisfied with my first attempt for the hatches attachements. I made new one with brass sheet and tube soldered together.
I was in pain with the paint of my brass front part (it's still a mystery for me why paint resist on it whereas I can paint the cockpit roof without problem). Finaly before assembling I glued a fine plastic sheet over the brass. From the good point of view it allowed me to catch up on a bit small diameter of my original piece.
For changing I take some moment for the wings, and put a lot of masking tape for realising rib tapes with Surfacer
I go back to brass construction with the realization of the landing gear. I use brass tube and sheet (what a marvelous matter)
cut cut cut
punch punch punch
drill drill drill
Finallyl the landing gear take form with the help of a small wood jig and a small amount of solder.
Thanks for taking the time to read this long post
Dric
bobs_buckles
Freedom isn't free.
Re: Bristol M.1C Blue Max 1/48
November 24, 2014, 11:10:10 PM »
One word....... Stunning!
Thanks for sharing
vB
uncletony
November 24, 2014, 11:38:26 PM »
This kit seems to attract some great builders! Great stuff, Dric.
As for the paint not sticking to the brass -- did you use an etching primer?
Youtube Channel
mgunns
November 24, 2014, 11:54:18 PM »
Hello Dric:
You are doing a great job here. Your soldering and Brass work is first rate. The added ribbing to the wings and fuselage, again first rate. This is turning out be one outstanding build. Like Bo wrote, this is attracting some great builders.
Umlaufmotor
November 25, 2014, 12:29:50 AM »
Really awesome.
I'll keep an eye on
Servus
Bertl
November 25, 2014, 02:07:03 AM »
You have made outstanding progress on this one! Beautiful and well executed additions and details!
coyotemagic
Reply #6 on:
November 25, 2014, 02:54:12 AM »
Truly phenomenal work, Cedric! An absolute masterpiece in the making.
Dric
Jr. Member
Reply #7 on:
November 25, 2014, 07:11:56 PM »
Thanks a lot for your comments.
@ Bo
I tried various solution after preparing the surface with a fiberglass pen. From Gunze metal primer, to enamel and specific phosphorous primer. Each time the paint remain fragile.
I have now bought a primer as the one used by railroad modellers plus a specific bath for cleaining brass. I will try it next time.
Maybe have you another solution ?
Dric
radio
Reply #8 on:
November 25, 2014, 08:44:35 PM »
Stunning work Dric.
Des
Reply #9 on:
November 25, 2014, 09:00:06 PM »
Very meticulous attention to detail Dric, an awesome build so far.
Nigel Jackson
Reply #10 on:
November 25, 2014, 09:22:57 PM »
Wow, Dric this is such an interesting and quality build. Thank you for sharing it with us.
Love the self
Reply #11 on:
November 25, 2014, 11:04:01 PM »
Will be following along with interest ....
Under Construction
