Author Topic: Best 1:72 Fokker Dr.I?  (Read 4141 times)
WarrenD
Re: Best 1:72 Fokker Dr.I?
« Reply #15 on: November 24, 2014, 09:10:19 AM »
Hmmmmmmm (Strokes chin, and raises little finger to mouth and emits evil laugh) :o
Offline Fokker boy
« Reply #16 on: November 24, 2014, 10:01:36 AM »
Yep, I wondered if it would have a noticeable effect (knocking the struts out of vertical alignment), but is was so minor no one ever saw a problem. I guesstimate the wing as roughly 1/32 inch too narrow, so this fix worked a charm, and is what I'll do to all the others I build.
Kevin
WarrenD
« Reply #17 on: November 24, 2014, 11:00:06 AM »
Did you have problems with the landing gear?
Offline Fokker boy
« Reply #18 on: November 25, 2014, 12:30:31 AM »
Nope, they fit good also. If I recall correctly, the struts for the landing gear mount to the fuselage, not the wing, so they were not affected.
Kevin
WarrenD
« Reply #19 on: November 25, 2014, 09:57:15 AM »
No, it wasn't a lower wing issue. Friends and reviewers posted that the "wing" that houses the axle was not wide enough.
Offline Fokker boy
« Reply #20 on: November 26, 2014, 02:23:28 AM »
I don't recall such a problem on mine. I'll check the next kit (when I receive one), and see what's what.
Kevin
WarrenD
« Reply #21 on: November 26, 2014, 09:27:19 AM »
Thanks!
