Author Topic: WNW AMC DH2 24 Sqn. Major Lanoe Hawker VC  (Read 60353 times)
Re: WNW AMC DH2 24 Sqn. Major Lanoe Hawker VC
« Reply #30 on: November 04, 2014, 01:50:09 PM »
Well Lance I am a Little Late to the party but I am Looking forward to your build as much as the others. ( My only wish would be that you were tackling the Roden kit to show me the way with mine  ;D ) As for that Camel, I am certain it will come as a Dual/Duelist release with the DR1 before Christmas  ::)
Offline stefanbuss
« Reply #31 on: November 04, 2014, 06:24:34 PM »
Quote
Haha.
Lance,
Whatever a/c you decide to build in the end, it will be interesting to watch. And you are absolutely right - research is sometimes more fun than the build itself.
Stefan
« Reply #32 on: November 06, 2014, 04:00:06 AM »
Hi Lance:
Isn't it something when the facts get in the way of modeling.  I swear they did that to confuse the modeler.  Anyway, I will be watching as you go through this build especially your take on the motor.  I agree, another all PC10 A/C, although having such a small fuselage, it really isn't all PC10 escpecailly with the CDL wings for contrast.  Looking forward to see how this shapes up and your comments regarding the build.
« Reply #33 on: November 06, 2014, 05:22:38 AM »
   Thanks Terri, Rick, Stefan and Mark. I think I've got the choice of markings pretty well made, I will go with 6011 from the same Squadron, but B Flight with the blue trim. It has grey on the metal portions of the nacelle, PC10 on the fabric and upper flying surfaces with CDL lowers.
   The wood portions are presently drying so the cockpit should be at the assembly stage very soon. I'm hoping that the engine and gun arrive very soon, as I don't want to get "stalled".
Offline KitRookie37
« Reply #34 on: November 07, 2014, 04:15:36 PM »
Hello to all,
I got this box too so I'll follow you in this build.
Best regards.
Alain.
Use the force, Luke.
Offline frame
« Reply #35 on: November 08, 2014, 05:11:56 AM »
Very good choice, great model, one of my favorite aircraft.
I wish you all success and will follow with great interest.
Best regards
Hristo
« Reply #36 on: November 08, 2014, 08:35:47 AM »
Great to see a pusher being built. The rigging is relatively straightforward on this one, especially when compared with some other machines. In any event you will make an excellent job of it and I am really looking forward to following this build.
Offline eindecker
    • Models In Scale
« Reply #37 on: November 08, 2014, 03:11:47 PM »
You have my interest too. I have a half-completed Eduard 1:48 DH-2 in a box somewhere. My problem with that kit was getting the struts right and top wing on. Haven't given up, but if it is not recoverable I mY use it as a rigging test bed for the Wingnuts Wings kit. Iconic, historical aircraft and I need to complete one. Will be following your build with keen interest.
Michael Scott
« Reply #38 on: November 08, 2014, 11:41:55 PM »
    Thanks All. Your interest and encouragement is very much appreciated. It's going along well, albeit slowly, and given the parts that are still in the mail system somewhere between here and Central Europe, and Greece, that's OK! I'll try for some photos today or tomorrow, the cockpit is coming together but still has a way to go to completion. I keep discovering the odd "thing" that needs to be added or improved; one step forward and a quick two backwards as is my usual pattern! ??? :-\
Offline TomR1981
« Reply #39 on: November 10, 2014, 02:30:37 AM »
Looking forward to seeing you work your magic on this Lance. I'll build this kit myself one day, when I do I'll certainly know where to come for inspiration.
Tom
« Reply #40 on: November 11, 2014, 10:03:16 AM »
Thank You Tom, although I'm just as likely to put a curse on this as magic. The rigging, which I normally enjoy, scares the hell out of me! :o :-\
« Reply #41 on: November 11, 2014, 10:58:47 AM »
    Finally, a real update with some work completed. So far, so good with no real problems or disasters. The Kit appears well engineered and goes together well however a lot of forethought and planning went into the sequence for cockpit assembly to ensure all got included. I believe I'm ready to close her up however will sleep on it and take a fresh inventory in the morning.
    The wood was done with a 50/50 light wood base mix of Tamiya Wooden Deck tan and Desert Yellow with a Burnt Sienna Winsor Newton Oil grain treatment and Tamiya Clear Orange overcoat. I find it too dark and next time (this is my first real attempt using oil paints on the woodwork) I'll try Clear Yellow as the varnish overcoat. Before starting the internal bracing I replaced the spring portions of the Elevator Trim Control with scratch copper springs. Here's a before and after view, the anchors for the wires were tiny (#83 drill bit in photo) and too delicate to support tensioned mono, so EZ Line to the rescue!
   Here's the replacement springs before painting. (I thought I'd prove that I too have a giant match, a compliment to Bo!)
......and the nacelle frame internal bracing.
  The instruments were framed with a mix of HGW and Aeroclub Bezils, given several coats of future for glass faces, and all copper lines on the frames painted with Mr. Metal Color Copper. I also added three more lines to the mix using copper wire, left in it's natural colour.
.........and a shot of the kit supplied Pulseometers, a really nice little touch on WNW's part!
    The belts are HGW with some dry Pigment for wear and tear........ The wicker seat is very well done and worked well with a final wash of dark brown oil paint.
    Last, I removed the Lewis from it's mount in preparation for the Gaspatch version which will hopefully arrive very soon along with the Taurus engine. I added the cable to the height adjustment mechanism, it's barely visible in these photos. (to the left of the support in the first photo)
   and finally here's a posed shot of where she's going next. It's a surprisingly small subject which is also apparent when viewing the photos.
    Thus far a pleasure to work on, great quality as we've come to expect from an excellent Company!
« Last Edit: November 11, 2014, 11:12:53 AM by lcarroll »
Offline petrov27
« Reply #42 on: November 11, 2014, 11:07:41 AM »
Looking real fine there - lots of good stuff going on in that pit!
-Patrick
« Reply #43 on: November 11, 2014, 11:10:24 AM »
Nice work Lance!  The office looks great so far. ;D. This will be a fascinating build to follow.
« Reply #44 on: November 11, 2014, 11:11:53 AM »
Great start Lance!
