Author Topic: Flashback Aviatik D.I Berg (resurfacing after 9 years)  (Read 18700 times)
Offline cduckworth
    • My WW1 Models
Re: Flashback Aviatik D.I Berg (resurfacing after 9 years)
« Reply #30 on: June 09, 2012, 07:30:30 AM »
Another view of the Berg
"Look alive. Here comes a buzzard."  Pogo
Offline Flyjunkie
  • wherever You go, there You are...
« Reply #31 on: June 09, 2012, 07:32:48 AM »
Dean:
I used a brown Micron 05 #1 Archival ink pen for the brown dots and Berol Prismacolor PC909 Grass Green for the green ones.  Sharpen the green pencil and dip in water to make to dots.
I sprayed the fuselage with a mix of Tamiya desert yellow, white and yellow for the base color and then applied the dots.  After the ink and water color was dry I sprayed a coat of Poly Scale Satin Finish over the entire airframe.  Now to find some crosses with white outlines for the top wing and tail.  I have three 'T' decals that are close so I can modify them for the sides, top and bottom.
Charlie
Thanks Charlie... I was gonna suggest either Prismacolor or Chartpak AD markers for this project.. both are top notch Professional markers, far better then the typical Sharpie markers and come in a fantastic selection of colors.. The Chartpak AD markers have the added benefit of having changeable Tips...
This Camo Job is looking Sweet!! and Now i know I can digg out my vast collection of art markers and do such a Camo  job myself.... ;)
Looking Good sir,, Looking GOOD!!!
DEAN ~~~ 8) 8)
"..Buy the Ticket, Take the Ride.." ~~ Hunter S. Thompson
« Reply #32 on: June 09, 2012, 08:37:01 AM »
  Charlie,
Now that's outstanding my friend. Cudo's for an unusual camouflage scheme and a highly impressive one at that.
« Reply #33 on: June 09, 2012, 02:25:24 PM »
i went and got some markers at the art supply store and tryed it out with the above scheme 284.13 and it looks great. i wanted to do this scheme for a long time but coudnt figure a good way to put those a/h dots on. i'll post a pic to show you when its done. thanks man.
Offline Whiteknuckles
« Reply #34 on: June 09, 2012, 06:55:35 PM »
Wonderful Charlie - these camo schemes look like fun and you've done a great job.
Eternal Apprentice
« Reply #35 on: June 09, 2012, 07:21:02 PM »
Two eyes firmly fixed on the outcome of this one  :o
BVB
Offline cduckworth
    • My WW1 Models
« Reply #36 on: June 10, 2012, 05:00:08 AM »
Mrs is in Washington, DC for a few days so have had time to work a little more on the Berg.  Landing gear added after adding .-15 brass wire to the ends where they would glue on the fuselage.  White band unmasked and sprayed Tamiya gloss to keep down the finger prints and get me something slippery to add the 'T's on the sides, top and bottom.   I don't know if you noticed in the earlier photo of the top wing but I had to cut down the length of the crosses as they were too wide for the wing.  This morning I cut the white areas off some spare decals and added them over the black ends to complete the white outline.  The tail cross is a little wide for a Berg (I borrowed it from an Albatros set) but it's close enough.  I may reduce the white outline with some brown and green paint at a later stage.
Need to add the details to the engine, side MG and figure out how I'm going to do the struts.  I have the large wing struts but the ones from the fuselage to the top wing are missing from the parts.  Thinking to add some strength to the model I'll make the vertical struts out of brass stock and place down in the fuselage as deep as I can and then file a deep pin on the top and use 5 minute epoxy to set the wing.  I won't make any additional posts until the model is more along in construction.
Rigging will be EZ line.
Any questions let me know.
Charlie
« Last Edit: June 10, 2012, 05:16:36 AM by cduckworth »
« Reply #37 on: June 10, 2012, 07:18:03 AM »
Thats a fine looking bird!!!
« Reply #38 on: June 10, 2012, 01:38:02 PM »
What he said!! ;)
Eternal Apprentice
« Reply #39 on: June 10, 2012, 02:11:50 PM »
definately very nice.
Offline michael
« Reply #40 on: June 10, 2012, 06:48:35 PM »
that is simply stunning work, i take my hat off to you Charlie  :)
michael
Offline Pete Nottingham
« Reply #41 on: June 10, 2012, 08:33:43 PM »
Very, very nice Charlie, stunning camo scheme.
Pete.
« Reply #42 on: June 11, 2012, 01:25:02 AM »
  Charlie,
Outstanding update my friend. The Berg truly is shaping up to be one beautiful little bird and one awesome project. Eagerly awaiting the next excellent update.
Offline cduckworth
    • My WW1 Models
« Reply #43 on: June 12, 2012, 01:28:21 AM »
Yesterday got the top wing added, engine changes made and MG added.   After messing with the position of the top wing for 45 minutes I realized Flashback located the struts between the fuselage and wing in the wrong position.  This have the front struts a rake to the back in lieu of being vertical.  Why don't we see this before using the 5 minute epoxy glue?  Was able to move the wing to the right position (at least closer) and reglued everything.  On closer inspection on the earlier FB Berg I built I noticed it had the same issues with the wing position (at least when I compared it to the Datafile general arrangement drawings).  Exhaust pipes from the engine are cut from soft steel wire (I initially use Evergreen rod but it looked too small in diameter).  The MG is from the end of a broken drill bit (so that's why I save them...?).   I thought I could use the 'T' decal from the Blue Rider A-H set but the style just wasn't close enough to this a/c.  Next installment will be rigging and final decal work and finishing the cockpit (which will be like building a ship in a bottle because the donor kit was already closed up...).
Charlie
« Reply #44 on: June 12, 2012, 01:42:37 AM »
  Charlie,
Excellent save on the top wing my friend . I'm looking forward to seeing in her full glory all rigged and  decaled. You mentioned an earlier Berg could you post some photos of it for us? Or is she the one from earlier in your thread? You never can have enough of these beautiful A-H kites.
