Author Topic: Maurice Farman MF7 Longhorn 1/72  (Read 26304 times)
Re: Maurice Farman MF7 Longhorn 1/72
« Reply #60 on: November 30, 2014, 12:07:10 AM »
Impressive! Thanks for the wheel detail, that will be useful.
« Reply #61 on: November 30, 2014, 01:39:16 AM »
An outstanding update! Your wheel technique is awesome. The rigging is just gorgeous!
« Reply #62 on: November 30, 2014, 02:43:13 AM »
Beautiful work LM! The delicate construction features are so well portrayed on the Model, the rigging is perfect, and the overall effect is very impressive. The finished project will be truly spectacular!
Offline Dirigible-Al
« Reply #63 on: November 30, 2014, 03:40:16 AM »
This is a real joy to follow LM
Alan.
« Reply #64 on: December 01, 2014, 05:22:38 AM »
Stunning work LM.
« Reply #65 on: December 01, 2014, 06:44:20 AM »
You have performed an awesome job on the rigging, and in 1:72 scale makes it even more impressive. Thank you for your tutorial on making the wheels, simple but very effective and will be usefull to a lot of scratch builders, your wheels turned out great. This model is really starting to look the part now, you have done an incredible job with it.
« Reply #66 on: December 01, 2014, 10:16:23 PM »
Fantastic. I am very much impressed! What a great modelling, LM.
« Reply #67 on: December 01, 2014, 10:59:51 PM »
It gets better all the time LM!  Outstanding work. ;D
Offline Old Man
« Reply #68 on: December 02, 2014, 01:30:10 PM »
This is a masterpiece, Sir.
Truly wonderful work.
« Reply #69 on: December 05, 2014, 03:54:23 PM »
very nice longhorn lonemodeller , looks much bigger.
Offline IFF1418
« Reply #70 on: December 05, 2014, 07:35:29 PM »
Hello LM,
I have the greatest respect for what you have accomplished. High class scratch building and great craftmanship!
Kind regards
Patrick
« Reply #71 on: December 06, 2014, 03:06:38 AM »
Truly sensational work, LM.  This is a very ambitious scratch build and you've done a masterful job of it.
WarrenD
« Reply #72 on: December 06, 2014, 11:06:20 PM »
LM, I can only add to the positive comments made already, what wonderful work. I'd like to know how you rigged your booms. I have a 1/72nd DH2 and a Fee in the stash, and the rigging of the booms has me scared.  :o
Great work sir!
« Reply #73 on: December 06, 2014, 11:30:46 PM »
Just amazing, LM!   Wonderful talents you are showing. :D
« Reply #74 on: December 17, 2014, 07:16:59 AM »
Dear Warren,
I am not sure that I can help much with your boom rigging problem except to say that I use rolled copper wire and superglue to rig my models. The wire is rigid so there is no problem with sagging, and I use dividers to measure each line separately. I usually cut the wire slightly over-length and offer the wire to the correct position on the model. Then using the standard Mk 1 eyeball I estimate the amount of wire to be removed - and repeat if necessary. It is surprising how experience hones accuracy. I use the end of a craft knife blade or a sharpened wood tooth-pick to place a tiny drop of glue on the model at both ends of where the wire is to be fixed, and then place the wire into position. The glue usually bonds the wire instantly. Getting the wires to sit into the corners of the booms (as per the real thing) is almost impossible so I allow the tiniest of overlap on to the boom or strut and if necessary touch in with paint afterwards - it can rarely be seen with the naked eye, although it is visible with a magnifying glass or eye loupe (which is what I use). Nobody who has seen my models has ever noticed the joints so far so they must be reasonably good. The disadvantage of using a tooth-pick is that the glue accumulates on the end, necessitating frequent re-sharpening and therefore shortening of the tooth-pick so I do not use them very often - knife blades are easy to clean but the size of the glue drop is more difficult to control. Again with practice this can be largely overcome however. I think that the key is to try out the technique on some test samples and surprise yourself how easy it really is. I have made a number of pushers now and find that rigging booms is actually no more difficult than rigging other parts of the airframe. Just be systematic and leave the inter-boom bracing and anti-drag wires until the remainder of the rigging is complete, then there is less likelihood of damage.
