Author Topic: Salmson 2-A2 24th Aero Squadron USAS - 1/32 WnW  (Read 41894 times)
Re: Salmson 2-A2 24th Aero Squadron USAS - 1/32 WnW
« Reply #105 on: November 02, 2014, 07:50:22 AM »
You have done a great job with the undercarriage Chris, the painting and weathering is superb.
« Reply #106 on: November 02, 2014, 08:03:09 AM »
Super work Cris.
« Reply #107 on: November 02, 2014, 09:40:55 AM »
Looks real!  Great job Chris. ;D
Offline BigBlue
« Reply #108 on: November 02, 2014, 10:58:22 AM »
Really lovely, Chris.
« Reply #109 on: November 02, 2014, 01:11:04 PM »
Great job of the undercarriage, Chris.  I really like the dirty bits around the
edges of the wheel covers.  Is that done with oils?
« Reply #110 on: November 02, 2014, 08:40:15 PM »
Your gear looks terrific Chris! I am glad to see that weighted tires don't equate to "FLAT" like in so many models!
« Reply #111 on: November 03, 2014, 12:58:03 AM »
It was Ernie. I used Raw Umber mixed to a watery consistency with cheap, run of the mill hardware store paint thinner. I always lay it over a satin finish with a wide brush and I use satin so it flows more evenly than if you used a flat sealer. If I apply too much, I soak it up with a clean brush and move the rest around until I'm happy with the result. Don't forget to always do wheels lying flat on the bench.
Here's a better shot with the undercart dry fitted Rick. I think these tires look exactly the way they should. Personally, I think WnW did an excellent job with them.
Offline BigBlue
« Reply #112 on: November 03, 2014, 01:51:17 AM »
I think those are some of the best "weighted" tires I've seen, including many resin aftermarket pieces.
Your build continues to impress.
Michael Scarborough
« Reply #113 on: November 03, 2014, 02:15:16 AM »
I'll up the ante on Chris' statement: it continues to impress and inspire. You've made me decide to drop "work" for the day, pour another cuppa, and get to the model bench.
Thanks!
Michael
Offline stefanbuss
« Reply #114 on: November 05, 2014, 07:24:27 PM »
Those weighted tyres look very realistic - i think they are valuable parts to achieve a certain level of "that is an aircraft, albeit a small one", instead of "that is a toy, but a painted toy".
Stefan
« Reply #115 on: November 06, 2014, 03:29:39 AM »
Hi Chris:
Just getting to this now, it is looking good.  The chipping, the weathering the decal and paint work all outstanding.  I especially like your rendering of the weighted tires and the subtle weathering bringing out the letters.  I wasn't going to use the weighted tires, but I have changed my mind.  Looking good!
« Reply #116 on: November 06, 2014, 06:37:01 AM »
Very nice update.
« Reply #117 on: November 09, 2014, 05:33:29 AM »
Thanks to one and all for dropping by and posting your comments. You guys are the best!
I finally managed to finish the wings, thanks to the replacement set of decals Rowan so graciously sent me. You may or may not remember earlier on where I mentioned that when I fouled up the original Pheon number '12' decal, I also pulled off one of the T.S.F decals from the WnW set. Rather than ordering a replacement sheet, I elected to make my own on the computer. I wasn't able to match the font exactly with the ones I have on my computer, but 'Times New Roman' is close enough for me. I printed them out on clear decal paper on my inkjet computer and after letting them fully dry overnight, I coated them with Microscale's 'Liquid Decal Film', and added them to the top wing.
After satin coating the wings and tailplane, I post-shaded them with Mig Productions 'Old Rust' pigment. I painted the rudder rather than using the decals provided and elected not to post shade it. With the post-shading completed, I treated everything to a couple of glazes of Burnt Umber oil paint to give them a grungy, mottled, well worn appearance.
Next step was to add all of the remaining small parts to the fuselage. In Step #6, WnW instructs the modeller to drill a 0.5 mm hole in part #F4 to receive the pilot's Gun Sight (#P3). The placement of this hole is rather vague and I recommend that you dry fit #A35 (Radiator Header Tank and Water Pipe) before drilling to prevent fouling the sight. If the hole isn't far enough to the right, placement of the sight will be either completely obstructed by #A35, or canted to the right, rather than perpendicular.
At this point, just for fun, I dry fit the various components to the fuselage and as you can see below, she's going to be a good sized model.
Thanks for looking!
« Reply #118 on: November 09, 2014, 06:49:23 AM »
Oh-my ,  now that is gorgeous  Chris ! :)
« Reply #119 on: November 09, 2014, 06:57:36 AM »
Wow!  Looking real good Chris.  That camo really pops! :D. Great finish!
