Author Topic: Junker J1 WNW 1/32.  (Read 11478 times)
Offline LukasTheLight
  • Addicted to Wingnuts...
Re: Junker J1 WNW 1/32.
« Reply #15 on: September 12, 2014, 06:32:53 PM »
Your cockpit is truly inspiring!!!! Love your work!!!! And also love this plane!!!
Lukas
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« Reply #16 on: September 13, 2014, 07:49:36 AM »
Excellent worn finish on the seat. Looking forward to seeing more! Thanks for sharing Alain
Here is a contemporary postcard of the Junkers J1 to celebrate your build
James
Happy Modelling
James Fahey
Offline KitRookie37
« Reply #17 on: September 13, 2014, 04:23:37 PM »
Hello to all,
More thanks for your kind words, it's very motivating.
Fuselage is closed with a little mastic. Jonction between lower wing and fuselage is difficult. I had to sand down and use mastic too. If not, there was a gap which is not existing on the pictures of the J1. It's a very difficult place to work. I'll show with picture.
I worked on the upper wing (about 50 cm lenght !!) and there is the mistake of this kit, there's a 3 mm gap beetween central section and the (I don't know english word for "aileron"). I'll use a piece of alu to hide this gap.
I'll show all of that.  ;)
Best regards.
Alain.
Use the force, Luke.
« Reply #18 on: September 13, 2014, 11:21:34 PM »
The English word for "aileron" is........ "aileron"!!
Many English aircraft terms are borrowed directly from the French:
Empennage
Fuselage
Sesquiplane
Monocoque
Etc.
Offline KitRookie37
l
« Reply #19 on: September 14, 2014, 04:05:37 AM »
Good evening to all,
More thanks Bo.  ;)
An entire afternoon working on the bench, nothing better.  ;D
So, let me introduce Mister Bigwings:
As I said, there are about 3 mm between aileron and the central section. So I decided to hide it with an alu strip, exactly like the real plane (this is an idea of Wingmaster, a french magazine).
To flatten alu, copper etc, I use a piece of tiles and a wood roller:
Then, with a toothpeek, I copy corrugated alu:
And barbatruc !!!
So, the second point of "disagreament"  ;D
The gap between lower wing and fuselage:
No choice, I presented the..."instrument"... ;D
I worked...
Gap surrendered... ::)
On that way, I found that :
rather ugly.
Evergreen and mastic were my friends:
Tonight, I'm here:
Best regards.
 Alain.
« Reply #20 on: September 14, 2014, 04:17:29 AM »
Very impressive and well done corrections and added details! This build is not going as slow as you indicated  :D
« Reply #21 on: September 14, 2014, 04:44:23 AM »
Alain,
    Very nicely done work with the aluminum foil, and a beautiful job so far, it's definitely going to be a winner!
Keep up the great work.
Offline stefanbuss
« Reply #22 on: September 15, 2014, 05:45:14 PM »
Congratulations on the surrender of that joint!
Stefan
Offline KitRookie37
« Reply #23 on: September 19, 2014, 04:56:56 AM »
More thanks for your kind words.  :)
You know what ?.... ;D I'm reading for painting...
But..but...but... :o
What's wrong with KitRookie? (check the right answer  ;D)
    1 - He gets mad
    2 - He listens "Painted in black"
    3 - He's colorblind
    4 - There's no more green paint in the stock
So, I give you a clue:
To be continued.... 8) 8)
Best regards.
Alain.
Offline KitRookie37
« Reply #24 on: September 24, 2014, 11:35:52 PM »
Hello to all,
I started paint with the upper surfaces green (only on metallic part).
After Tamyia XF 71, I used lighter color (adding tan deck) for middle of surface and darker color (XF 67) on rivets line.
Of course, result is very contrasted. So, several voiles (curtains ?) of diluted XF 71.
Then, with tooth pick, scalpel and 120 buffer I did scuffing. And, the secret touch...I polishes paint with a smooth piece of cotton (truely, an old
underpants... ;D but clen of course....).
Look:
To compare:
Whole upper wing:
Now, I'll take care of the canvas parts.
Best regards.
Alain.
« Reply #25 on: September 25, 2014, 12:10:46 AM »
Beautiful pre shading and paintwork!
« Reply #26 on: September 25, 2014, 12:20:26 AM »
Those wings look superb! The corrugation and riveting just cries out for weathering and you've hit a home run with this.
Offline AndrewS
« Reply #27 on: September 25, 2014, 12:33:24 AM »
Excellent build!  :o
Très jolie  :D
« Reply #28 on: September 25, 2014, 01:56:56 AM »
I agree with my amigo 100%!
« Reply #29 on: September 25, 2014, 03:28:15 AM »
A very fine shading.
