Author Topic: Airfix 1:12th scale Blower Bentley  (Read 35739 times)
Offline pietro
  • What?! Are you kidding?!
Re: Airfix 1:12th scale Blower Bentley
« Reply #120 on: October 02, 2015, 05:34:28 PM »
Ian, do you have plans to make these available to the Common man?
Pietro
« Reply #121 on: October 02, 2015, 09:21:07 PM »
I do indeed, Pietro. As soon as I fit them to make absolutely sure they are OK I'll make them available on Shapeways. I want to finish the Short 184 first....
« Reply #122 on: December 24, 2015, 07:58:31 AM »
Hi folks,
 I haven't forgotten about this, I just have other builds that are priorities at the moment. Having said that, I got bored with rigging the Short so decided to tackle a little project on this one as a break.
 Airfix moulded the radiator badge too low so I needed to find a way to put that right. I tried making a mould of it a few months back and destroyed the badge, so I ordered a new rad shell from Airfix. After trying to mould it again I decided it wasn't going to work: I couldn't get the detail fine enough, or make it thin enough. I therefore bit the bullet and decided to graft it!
I first removed the badge from the replacement shell, then marked out where it should go and drilled out the centre line.
 I then slowly and carefully widened the hole until the badge fitted.
 The top of the shell is a little flatter than the front, so hot water came into play. I made sure I checked it constantly to see if it would bend and in the end I got it sufficiently flat to insert it into the hole in the shell.
The edges of the joints at the rear were filled with Mr Dissolved Putty to fill any gaps and give it a little more strength, and when it's dry I'll fill and smooth off the joins at the front.....
« Last Edit: July 17, 2017, 06:25:20 AM by IanB »
« Reply #123 on: December 24, 2015, 08:26:31 AM »
Very tricky work with the badge Ian but it appears you have pulled it off well.
mike in calif
« Reply #124 on: December 31, 2015, 01:12:05 AM »
Well done sir!
« Reply #125 on: March 02, 2016, 05:51:34 AM »
I have finally made the shock absorbers available on Shapeways:
https://www.shapeways.com/shops/ibdetails
 They are being made available simply because of the great feedback I've received. I hope they help bring some more of these old kits out of the woodwork!
Thanks Bo, for your assistance!
« Last Edit: March 04, 2016, 01:13:20 AM by IanB »
« Reply #126 on: March 02, 2016, 09:34:53 AM »
Very cool Ian, welcome to the club! :)
