Author Topic: Hansa-Brandenburg D.I scratch 1:144  (Read 8474 times)
Offline ondra
Re: Hansa-Brandenburg D.I scratch 1:144
« Reply #15 on: August 28, 2014, 04:58:53 AM »
Thank you all very much for your encouraging comments.
After removing paint from the wings I decided to make them new from scratch. I do not know how it happened, but the shape of the lower wings was totally wrong.
So after a few days of filing and sanding, I made an attempt on preshading for the CDP.
This does not seem the right way to go. :)
Anyway, I will see what a few layers of CDP Gunze will bring, there is always the option of starting the fourth try.
Offline ondra
« Reply #16 on: September 04, 2014, 03:58:11 AM »
Ok now, as I was not happy at all about the latest version of the wings, I went for another attempt trying a method invented by a very good friend of mine who also builds 1:144 scale. He used this procedure while making a resin kit of "Pou du ciel".
It is as simple as it is effective - stretched sprues simulating wing ribs glued on a sanded plastic sheet with Tamiya extra thin.
With respect to the fact that this is the first attempt using this method, I have to say that it is a much smarter way than I applied before. The result is not perfect but seems to be a way to go in the future.
« Reply #17 on: September 04, 2014, 12:12:12 PM »
Looks promising so far ondra .  :)
Offline ondra
« Reply #18 on: September 06, 2014, 02:59:53 PM »
Here some progress on the wings:
Attempt on pre-shading on upper and lower surface:
Offline ondra
« Reply #19 on: September 06, 2014, 03:01:18 PM »
And this is the result.
Not perfect but I can live with it. Now let's move on to the markings.
« Reply #20 on: September 07, 2014, 11:06:30 AM »
Your effect turned out pretty good , still hard to believe that this is 1/144 scale ..
« Reply #21 on: September 07, 2014, 02:05:39 PM »
Absolutely amazing work in such a tiny scale, Ondra.  Fascinating build.
« Reply #22 on: September 07, 2014, 04:47:11 PM »
I agree with terri, the work on the wings looks great!
Beautiful WIP , thanks!
« Reply #23 on: September 07, 2014, 10:55:53 PM »
I agree 100% ! Stunning work in such a TINY scale, or any scale for that matter!!
Offline ondra
« Reply #24 on: September 10, 2014, 02:13:03 AM »
Hi everybody,
I am back with some progress.
The wings are finished.
Offline ondra
« Reply #25 on: September 10, 2014, 02:14:37 AM »
And the rudder is in place as well with the iron crosses paintbrushed.
There will be a coat of satin varnish on the fuselage and I will have to correct several spots where the paint peeled off.
« Reply #26 on: September 10, 2014, 02:26:31 AM »
Beautiful, ondra, did you use something like masks to paint the crosses on the rudder in such a precise way?
Offline ondra
« Reply #27 on: September 10, 2014, 02:36:02 AM »
Hi Andonio,
correct, a friend of mine has a plotter, so I drew the crosses in Corel and sent them to him. After like four days I received the masks and I have to say they are much better for this purpose than decals in this small scale.
Ondra
« Reply #28 on: September 10, 2014, 08:02:06 AM »
Still looking just absolutely OUTSTANDING! Considering how much larger than life those photos are I am blown away by your work!
Offline ondra
« Reply #29 on: September 11, 2014, 01:58:35 AM »
The fuselage is basically finished and coated with Vallejo Satin Varnish, now I will let it dry and afterwards I can start assembly.
Hope all parts will fit together. ;)
