Author Topic: WiP - Eduard 1/48 Fokker EV Weekend Edition  (Read 12602 times)
Re: WiP - Eduard 1/48 Fokker EV Weekend Edition
« Reply #15 on: July 11, 2014, 06:42:02 PM »
Coming along very nicely Brad, the engine and cockpit look great and the underwing painting is extremely well done.
« Reply #16 on: July 11, 2014, 09:40:38 PM »
Your build coming along very good Brad.
« Reply #17 on: July 12, 2014, 01:15:58 AM »
Excellent job on the cockpit and engine, Brad.  The wing underside colors and streaking look fantastic, as well.
« Reply #18 on: July 12, 2014, 09:06:08 AM »
Looking good so far Brad  :)
« Reply #19 on: July 12, 2014, 09:20:51 AM »
Beautiful work as always! I really like the color choice you have made. Going only from memory I think it is fairly close to the colors I ended up with. Yours of course looks better  ;D The interior is neat and the engine looks great!
Offline Brad Cancian
    • Brad's Models
« Reply #20 on: July 12, 2014, 08:53:09 PM »
Thanks as always folks!
The build is progressing speedily. Today I finished the fuselage clean up and had a play with the lozenge.  Given that the Aviattic lozenge is transluscent, I had a bit of a play with some pre-shading.  Some experiments on scraps showed that a black pre-shade under the decal was way too stark, so the trick was going to be to keep the pre-shading subtle.  Also, undercoat colour with these decals plays a big part. As I wanted more of a 'brown' lozenge to go with my 'brown' wing, I went with a 'brown" based undercoat of Gunze "sail colour" and pre-shaded with this colour plus a little bit of black mixed in, thus:
I then applied the decals straight over the top. These are the "faded" versions, so they essentially come pre-faded and textured.  Here's the result - instant weathering without the fear of tearing or wrecking decals!  ;D
I think that if I had another go I would lighten the base coat further as the overall effect is quite dark, but that said I was quite happy with the way the pre-shading showed through. I am getting used to the way that these decals react under decal softener, but they are quite forgiving decals due to their "stretch".  They don't stay colourfast under harsh thinners though, so a word of warning to clear coat them before doing any further weathering (don't ask me how I found this out.... ).  I did also think about rib tapes, but layering these decals doesn't really work too well as you get large variances in colour density (as noted in the instructions). I think the pre-shading gives the right effect anyways.
Now to let them dry while I work on some other components.
BC
« Reply #21 on: July 12, 2014, 09:50:55 PM »
Exellent Brad. ;D
« Reply #22 on: July 12, 2014, 10:34:41 PM »
Your lozenge looks superb. I'm approaching the time where I'll be appyling Aviattic decals to a fuselage for the first time so I'm interested to know how you did it. Did you cut the pieces to fit exactly or did you cut them oversize and trim to fit after they were dry? If the latter, my concern is just how well I'll be able to trim them.  :-[
« Reply #23 on: July 12, 2014, 10:52:13 PM »
   I'm very impressed with the effect produced by pre-shading these decals Brad. My one experience with them to date I elected post shading with dry pastels which produced a good effect but not as subtle as on yours. Very nice work so far and Thanks for the Pre-Shading trick; it's now in my bag of tricks for next time around.
Offline LindsayT
« Reply #24 on: July 13, 2014, 04:55:15 AM »
I never could quite picture the transparency that Richard described. This illustrates it perfectly. What an incredible effect you can achieve! Great work Brad, and great product, Richard!
Lindsay
« Reply #25 on: July 13, 2014, 05:40:51 AM »
Beautiful lozenge work, Brad!  The preshading is perfect.
« Reply #26 on: July 13, 2014, 11:09:12 AM »
I agree with my Amigo! Terrific pre shading!
    • Brad's Models
« Reply #27 on: July 13, 2014, 11:54:07 AM »
Thanks guys!
Chris - as the dried lozenge has some 'stretch' to it, trimming with a blade is tricky. Also, any layering of the decal over itself doubles the intensity of the colour and will be obvious.  As such with this lozenge the best thing to do is to try and cut the pieces to fit as closely as possible without trimming.  I made some paper templates initially and trimmed the templates to fit before I laid them over the lozenge decals and cut them out.  There was still some overlaps and some slight gaps but these were reasonably minimal and were able to be dealt with.
BC
« Reply #28 on: July 13, 2014, 11:57:25 AM »
Thanks guys!
BC
Brad,
Glad to hear that a modeler of your caliber has come to the same conclusion as I did. Careful Prep work in trimming and preparing is the best route to a great application! Having learned this lesson my next effort will be much better.
    • Brad's Models
« Reply #29 on: July 13, 2014, 09:49:05 PM »
She now has some legs (dry fitted only at this stage...):
As you can see I went with Fokker E.V 149/18 of Jasta 1, based on the profile of the late great Dan San Abbott (I was already halfway there having based the wing camo off his pattern).  Serial number was printed on my home printer.  I like this simple scheme with the splash of colour from the cowling.
BC
