Under Construction
Pegasus 1/72 Etrich Taube
Pages:
5
6
Topic: Pegasus 1/72 Etrich Taube (Read 20716 times)
xmald
Re: Pegasus 1/72 Etrich Taube
Reply #75 on:
August 28, 2014, 05:14:42 AM »
Great job on the rigging mate! It`s a very good looking Taube!!!
Best regards
Filip
lone modeller
Reply #76 on:
August 28, 2014, 06:31:06 AM »
Thank you for the compliment Filip.
radio
Reply #77 on:
August 28, 2014, 08:22:20 AM »
An exellent build on this little scale.
lone modeller
Reply #78 on:
August 29, 2014, 03:26:29 AM »
Thank you Martin. In my opinion the small scales are the best!
ondra
Reply #79 on:
August 29, 2014, 05:52:46 AM »
Well, this is just jaw-dropping!
A great job indeed, I admire your skills. Thumbs up and my hats off to you.
Ondra
lone modeller
Reply #80 on:
August 30, 2014, 03:14:03 AM »
Thank you for the kind remarks. Rigging this was not as difficult as some may think - just took a long time! However all of those wires do catch the eye.
lcarroll
Reply #81 on:
August 30, 2014, 04:55:34 AM »
LM,
You've done it again! Absolutely magnificent work and a tribute to your tremendous modelling skills; what else can I say?!
Dekenba
Guest
Reply #82 on:
August 30, 2014, 06:39:26 AM »
Stunning model. I think this explains why WNW have not released a Taube in 1/32, the rigging would simply be overwhelming for most modellers. It makes the Fee & DH.2 look simple in comparison!
lone modeller
Reply #83 on:
August 31, 2014, 05:22:59 AM »
Thanks Lance and Dekenba for the compliments. You are probably right about the rigging putting a lot of modellers off but some of the later Tauben had simplified schemes which can be realistically modelled and still give an authentic finish. It may surprise you to read that I found rigging the FE2 and DH 2 more difficult at times because they are biplanes and there is less room to move and at times more difficult to see. At least with a monoplane everything is relatively accessible - even the underwing spar was easy to get to. The only tricky bit was the warping wires but once I had devised the method even that was simpler than it looks.
Pages:
5
6
Under Construction
