Author Topic: Roden 1/32 Albatros D-I Modified to Prototype  (Read 15703 times)
Re: Roden 1/32 Albatros D-I Modified to Prototype
« Reply #45 on: June 03, 2014, 07:55:23 AM »
An exellent wood paint Dan.
« Reply #46 on: June 03, 2014, 08:37:33 AM »
Hi Dan:
I like the contrast between the wood and the linen of the wings and control surfaces.  You have captured that look quite well.  I am looking forward to seeing you continue to post update and the progress.
« Reply #47 on: June 03, 2014, 08:49:48 AM »
Absolutely perfect wood work, Dan!
+1!  That's wood finish is very pleasing to the eye, Dan. ;D  Very nicely done.
« Reply #48 on: June 03, 2014, 09:34:35 AM »
I'm not sure how, but I seem to have overlooked this build up to now.
 She's looking VERY nice Dan, wonderful woodwork! Going back a stage or two, I find it helps with the underside "transparency" to give it a coat of white before marking the interior structure and crosses etc. - it helps the contrast.
« Reply #49 on: June 03, 2014, 12:30:58 PM »
Dan , following on Hyperscale and now I can view it here as well , Awesome !
Offline NinetythirdLiberator
« Reply #50 on: June 04, 2014, 03:45:25 AM »
Thanks Martin, Mark, Bob, Ian and Terri ("THE" Terri? :D)
I am very pleased how it's going so far...the wood looks much better than I expected!
And thanks for the tip, Ian.  I might still play around a bit with the transparency issues.  I can't decide if I like darker showing through, or taping off the tops of ribs and shading with pastels...hmmmm.  I did notice that my painting was a bit easier the second time since I already had my aborted first attempt over the primer.
We'll see how things go.  More work on it tonight!
Thanks again everyone.
Dan
« Reply #51 on: June 04, 2014, 09:52:14 PM »
Yes Dan , ( the Terri )  :)
« Reply #52 on: June 05, 2014, 02:27:56 AM »
Just a test fit of the upper wing and I painted the metal parts and cockpit coaming and added the radiators.  Next will be the fuselage and rudder markings!
Looking good...Dan  ;D
« Reply #53 on: June 05, 2014, 04:53:45 AM »
It looks wounderful Dan.
« Reply #54 on: June 05, 2014, 05:20:59 AM »
Looks great! That Pylon sure does make mounting the wing easy!
« Reply #55 on: June 16, 2014, 02:15:55 PM »
Tiny Update...Finally...
Here is a shot of the markings painted onto the rudder and fuselage based on prototype photos.  They are pretty small and also in different locations (slightly) than the production ships.
I'm just glad to finally get to do some modeling.   ;D
Thanks for looking.....Dan
« Reply #56 on: June 16, 2014, 02:36:55 PM »
Looking extremely good Dan, the wood is excellent.
« Reply #57 on: June 16, 2014, 08:48:02 PM »
Really well done, Dan.  I am completely taken with your fuselage "wood".
I wonder if you could give a bit of an explanation of your woodish technique?
Amazing stuff. :D  Looking forward to the next updates.
« Reply #58 on: June 16, 2014, 08:56:29 PM »
Excellent work on your crosses! Like the others I still Love your wood painting!
« Reply #59 on: June 16, 2014, 11:14:08 PM »
This is shaping up to be a beautiful piece of work, Dan. Like Ernie, I'm very much looking forward to the next updates.
