Author Topic: WNW Roland CII  (Read 20038 times)
Offline GrahamB
Re: WNW Roland CII
« Reply #15 on: April 17, 2014, 06:28:23 AM »
Thanks guys.
I've crept slowly towards a wood-effect technique that works for me but it's only the tried-and-true 'oils-over-acrylic'. On the instrument panel and lower floor I used Vallejo airbrush Wood as a base, on the main floor it was Vallejo Desert Yellow. I did the streaking in two layers of oil (burnt sienna and raw umber) separated by a layer of clear acrylic. I try and keep 'streaking' to a minimum and use only the smallest of my brushes and quite dilute oil - it's more changes in intensity and tone than actual 'grain'. Tried some light dry-brushing of MIG Black Smoke powder in places where there might be more wear - near rudder pedals, base of observer's position - very pleased with this!
WEM Light Slate Grey for the petrol tank etc - for some reason I've found this a really good and versatile colour for all sorts of purposes.
I'll try and keep up - but some will probably overtake soon.
GrahamB
Re: WNW Roland CII
« Reply #16 on: April 17, 2014, 11:10:05 AM »
i thought you meant the handles on the control panels of the wnw kits, mostly to control fuel on/off from different tanks on some kits they give you a handle on others they mold a long skinny bump and fashion notched decals around them ratherthan giving ya separate handle. small but irritating.
Offline IFF1418
Re: WNW Roland CII
« Reply #17 on: April 17, 2014, 07:01:53 PM »
Wonderful start Graham, I like your wood tones very much. Excellent work!
Kind regards
Patrick
Re: WNW Roland CII
« Reply #18 on: April 18, 2014, 01:53:38 AM »
Hello Graham:
Nice to see this on the Forum.  I like your wood tones.  Wood tones are something I am always toying with, each one is different and I like your approach to it.  I will be following this with interest as I am not sure I want one of these but..........they are neat.  I am thinking more along the Camo lines.   Looking forward to your next update.
Re: WNW Roland CII
« Reply #19 on: April 19, 2014, 02:04:12 AM »
It's exciting to see this one being built so soon and so well.  I've got one on the way and look forward to watching what you do with yours.  Your doing a brilliant job and I really like how you've represented the wickelrumpf.
Offline GrahamB
Re: WNW Roland CII
« Reply #20 on: April 19, 2014, 08:01:08 AM »
Hi,
some progress and I'll put more photos up later today or tomorrow - realised that I need the engine up and running before I can close the fuselage. I decided to have a go with the Taurus Merc III upgrades even though not much will be seen. I have a simple diorama in mind so could leave a panel off.
There is quite a complex but effective cockpit-frame setting up and a few things need some attention - and paint removal before fitting. Also I can see that I will need to fit the frame assembly into the port fuselage half first so that wiring can be added from part B3 (junction box?) to the voltmeter (B22) and the aerial cable from B82/90 to A34.
Will be doing the option E markings but with colour scheme more like that of B 'Meerkat' - more on this later.
Graham
Offline GrahamB
Re: WNW Roland CII
« Reply #21 on: April 21, 2014, 10:06:12 AM »
Hi,
some more progress over the Easter break. Most of the interior is completed now and I've taken shots before I mate the left and right sides together. For the interior I used Vallejo Modelcolor 990 Light Grey with a bit of 900 Mirage Blue to darken it (even though 990 is supposedly a match to WNW's suggestion of FS25237 - I find that Vallejo sprays out quite a bit lighter than brushed out swatches).
Some details added to the kit items (based on Datafile photos) are rudder foot rests (fusewire) and petrol and other switches on right of the instrument panel (fusewire and aluminium pie-dish). Added the cabling to the control column (UvR line) and a small slice of white(?) decal to the center-datum on top of the wheel itself.
The rudder cabling I used some Unithread (but thicker than their Caenis line) but then realised I couldn't pass it through the rear tubing later so terminated this on the fuselage frame behind pilot's seat. Remember that the cable goes right around the pedal assembly - this was grooved on the outer curved elements on the real thing so purists could attempt this. I managed one complete run from port side to starboard side with only four small anchor points of superglue. In the Datafile photos it can be seen that the rudder cables are partly protected with tubing in the rear cockpit and I used 0.3mm brass tube for this and attached it to the frame that fits behind the rear window - it should just clear the dynamo lever and rod.
I switched to the medium UvR thread as I could just insert it into the tube but on other side I had to use steel wire that passed through completely - this will have to be attached forward and aft after the right frame is added. I added a dynamo lever rod from the rear cockpit lever to the pilot's lever but this was actually bent around an upright - I would recommend drilling through or putting a proper dog-leg kink in the rod. The forward end from pilot level to dynamo will be added after the engine is inserted.
After my last post I realised I could add the cabling from the 'junction box' to the voltmeter before putting the frame assembly in the port fuselage half - lead wire is perfect for this (and colour) and will be just nudged into place later. It needs to bend around the dynamo lever behind the rudder cable and lever rod, then alongside the window frame - OK when the assembly is in place in the fuselage half. I will add some copper wire for the aerial lead in the same way.
My biggest bugbear at the moment is with fitting etched seat belts. I try and do a nice job with 'leather' etc on the seats, get decent 'fabric effect on the seat-belts themselves but then cover the former over with the seat-belts and also find that the bloody things are hard to stick in place without serious removal of paint - doh!
Also grappling with the engine, learning the hard way how to deal with the Taurus upgrades. I made the mistake of adding the valve springs first then the long assembly on top - of course the springs were almost all slightly out of alignment so I will have to redo these. Ugh.
Looking good now - next time engine will be in and ready to get fuselage up and ready for painting.
GrahamB
« Last Edit: April 21, 2014, 12:57:13 PM by GrahamB »
Offline treadhead1944
Re: WNW Roland CII
« Reply #22 on: April 21, 2014, 12:32:03 PM »
Looks,  excellent, and I am taking notes for technique. Thank you.
Re: WNW Roland CII
« Reply #23 on: April 21, 2014, 12:36:45 PM »
Fantastic Work! Your interior is beautiful and though I am not sure what a Dynamo lever is I am sure it is part of what makes your interior look so great  :o
Offline GrahamB
Re: WNW Roland CII
« Reply #24 on: April 21, 2014, 12:52:46 PM »
Hi,
Sorry, the 'dynamo levers' are those two on the port side and are 'wireless generator clutch' levers (parts A51 and A53) in the WNW instructions.
Forgot to say that WNW have kindly made small holes in parts D17 (rudder cable rollers) for rigging but I drilled completely through these so that the cable can be one piece. If I had been really clever to start off with I could have run it from the frame behind the observer's position port to starboard in one - but see foul-up with line thickness/tubing. Next time...............
GrahamB
Re: WNW Roland CII
« Reply #25 on: April 21, 2014, 01:44:00 PM »
You are doing a great job on the Roland, Graham. I'm enjoying your build
log and looking forward to the next updates.
Re: WNW Roland CII
« Reply #26 on: April 21, 2014, 01:56:28 PM »
Wonderful work Graham, one of the cleanest finishes I've seen on an interior. It's just, well, er, what else can I say, Great! Looking forward to following you through to completion.
Re: WNW Roland CII
« Reply #27 on: April 21, 2014, 03:22:22 PM »
Your build is coming along beautifully Graham, looking forward to more updates.
Offline jknaus
Re: WNW Roland CII
« Reply #28 on: April 21, 2014, 10:09:14 PM »
Very very nice.
James
Re: WNW Roland CII
« Reply #29 on: April 22, 2014, 02:55:49 AM »
Hello Graham:
I like the work and the extra detail you have provided in the cockpit.   Like Lance said, very clean and nice.
