Author Topic: WNW Roland D.VIa with lot's of extra's finnished.  (Read 27165 times)
Offline DannyVM
Thank's guy's for the nice comment's. :D
Greetz
Danny
Offline DannyVM
Today i did some more work on the upper wing. Some painting had to be done, and also the balken crosses needed to placed on top of the upper wing
After the lower wing balken crosses weren't very succesfull, you guy's can imagin that i was not very eager to start on this.
But, all wen't very well, and at the moment it's a succes.
Radiator, on the upper and lower side is done. And the aileron control horn's are placed and painted.
That's all for now folks.
Greetz
Danny
Your tapes are looking great! Lovely work!!
Offline DannyVM
Quote
Thank's RAGIII.
The tapes are a bit to white, so they will be flatten off with Tamiya smoke to give them a worn appearance. This is allready done to the horizontal stabelizer and the lower wing.
Greetz
Danny
Your update is very nice. I look for the next Danny.
Offline DannyVM
Thank's Martin ;) ;)
Offline Vladimir Ziska
    • Nordland Models
Hello Danny,
very professional work.
Vladimir
Offline DannyVM
Thank's Vladimir for the kind comment's. ;)
Greetz
Danny
Nice job on the decal work  :)
Offline jknaus
Man that looks nice. Its work like this that makes it hard to not start every kit in my stash.
James
Danny,
   That is really superb decal work on the lozenge; clean, perfectly trimmed and comes off very realistically. Nicely done!
Offline DannyVM
Terri, James and Lance, thank's allot for the very nice comment's ;) ;).......but please guy's and girl's, iff there's something that i can do better, or simply iff you see mistakes in my build, please feel free to give comment's also, after all, whe learn from eachother. :)
Greetz
Danny
Offline DannyVM
Hi guy's,
time for the next update: taking care of the fuselage.;)
first i wanted to try the Ushi wooden decals onto the fuselage, but, due to the very tiny details that are scattered on the fuselage, and the fine wooden lamels, i was afraid that i couldn't do the job properly.
So i decided to change the strategie, and i went for a wooden structure with oil's.
First i needed a other base coat, so for this i used Tamiya XF-59 Dessert yellow.
A nice layer of Tamiya gloss coat finnished the fuselage, and it was ready to receive the oil paint.
I didn't wanted the same color as the cockpit so i my choice feld on another shade, Talens Van Gogh Raw Umber.
I started with the underside of the fuselage, and this is the result:
For this technique i used a fin round brush to put some dot's of oil paint onto the fuselage. Then i use three different sizes of flat brushes to get the wooden texture. Trick is, that how more brushes you use how finer the texture will be. This is a very pleasant technique that allows you to make change in the pattern, and iff mistakes are made then to solve them.
That's all for now, thank's for watching:)
Greetz
Danny
Danny,
   Your wood pattern is excellent, and very subtle, this is going to be spectacular when finished. Very nice work, keep it up!
The wooden fuselage is looking terrific! It is always great to see plastic turned into wood using oils! You have just the right touch,IMHO,
