Author Topic: Airco DH.9 (1/32, Wingnut Wings)  (Read 19217 times)
Re: Airco DH.9 (1/32, Wingnut Wings)
« Reply #30 on: March 07, 2014, 08:25:42 AM »
Bo, I meant no offence, just wanted to say I build almost OOB and you (and some others) reach the high level of modification. Just this. :-[
« Reply #31 on: March 07, 2014, 08:31:58 AM »
hehe, i understood what you meant, no offense taken!
carry on then :)
« Reply #32 on: March 07, 2014, 08:34:17 AM »
ufff, lucky me...
carry on then :)
I will, sir, I will  ;)
« Reply #33 on: March 07, 2014, 09:39:12 AM »
nice,my friend looking excellent
« Reply #34 on: March 07, 2014, 10:57:40 AM »
Dittos to the above, nice work so typical of your fine skills !
« Reply #35 on: March 08, 2014, 07:56:15 AM »
Thanks, oh kind people!
I have decided to divert from the WNW instructions sequence and put the fuselage halves together before the engine instalation. They are now taped to let the glue cure. But I could not resist to dry-fit the engine, the radiator and the top fuselage panel. The latter element is very tight-fit - some delicate sanding will be required to install it smoothly. Otherwise, no problems.
« Last Edit: March 14, 2014, 07:17:57 AM by PrzemoL »
« Reply #36 on: March 08, 2014, 12:26:24 PM »
Looks terrific! I assume fitting the engine later allows some advantage to painting or detailing?
« Reply #37 on: March 08, 2014, 08:42:14 PM »
Yes. No risk of damage to the engine during masking.
Offline Steven Robson
« Reply #38 on: March 08, 2014, 09:09:40 PM »
Beautiful cockpits PrzemoL  :)
Steven
Offline Graham t
« Reply #39 on: March 08, 2014, 09:18:39 PM »
This is going to be a stunner!
« Reply #40 on: March 09, 2014, 01:49:52 AM »
It is a pleasure watching your work, Prze.  The close tolerances of the Wingnut kits
do take a bit of getting used to.
Offline FokkerFodder
« Reply #41 on: March 09, 2014, 06:37:57 PM »
Lovely stuff - your leather, woodwork and wicker are supurb......
Sorry, but if you're going to post such lovely work, I'm going to have to ask for tips!
How do you get the two tones in the wood? Do you carefully handpaint the darker effects over once the lighter shade is dry, or simply blend in the darker colour at the same time using a brush to get the woodgrain effects?  And I'm not really satisified with my leather attempts, despite oil washes, attempted highlighting and so on ... I can't seem to get the rich depth of colour like yours.  Aside from talent  :), any other tips you have....?
cheers
FF
Offline Sean morgan
« Reply #42 on: March 09, 2014, 09:32:32 PM »
These wing nuts are like a drug !!! I have to get one of these it's just to much to resist after looking at your cockpit coming together, just beautiful PrzemoL!
« Reply #43 on: March 11, 2014, 12:22:44 AM »
Thank you, oh kind people!
FF, you are welcome to ask questions, my methods are not secrets.
Wood - I airbrush the base colour, a mix of Mid Stone (Pactra) and Beige Brown (Vallejo) depending on the final shade - darker or brighter. Then I paint with a thin brush a pattern using a darker mix. Sometimes I retouch with brigther again. Then follow thin layers of Clear Orange. I usually use Pactra but I have just ran out of it and in this model I used Tamiya. The number of layers depends on the depth of orange you wish to get. Finally I apply dark brown wash which also serves to add some more wood pattern, not just to emphasize the surface detail.
The leather is from the bas mix of Red Leather and Chocolate Brown (both Vallejo) with dark brown wash retouched numerous times to get the satisfactory result.
In both cases I use a water colour wash which has to be sealed with clear (gloss, satin or matt - or a combination to get the desired level of gloss/matt).
There is really nothing more to it. Although some testing on scrap plastic pieces is advisable.
« Reply #44 on: March 11, 2014, 04:53:58 PM »
cheers!!  I'll try experimenting with this approach for the next build.......  a non-oils approach to wood and leather.......
