Author Topic: 1/32 WnW Pfalz D.IIIa  (Read 17505 times)
Re: 1/32 WnW Pfalz D.IIIa
« Reply #75 on: February 11, 2014, 06:06:24 AM »
Hello Ernie:
It is coming along nicely, troubles not withstanding.  If the problem of chipped lozenge is on the leading edge of the upper wing, why not take a small strip of the kit lozenge, and run a small section across the front of the wing, which is what was there on the actual a/c anyway.  A small strip of the kit loz may not seem so out of place it being narrow.  You could then go back and with prudent weathering, sort of blend it in.  Otherwise, due to the transluscent nature of the lozenge you are useing, you would have to almost cut exact shapes to repair.  Sometimes a small dab of paint will work as well.  Whatever you do or don't do, it is still a striking scheme and with the a/c completed those little blotches probably won't be noticed.
« Reply #76 on: February 11, 2014, 06:12:03 AM »
Thanks for the advice, Mark.  That sounds like a good fix.  Once I get the rest of the
rigging done, I will give it a try.  Much appreciated, my friend!
« Reply #77 on: February 11, 2014, 06:32:03 AM »
Looking good, Ernie.
You're nearly there my friend  ;)
VB
« Reply #78 on: February 11, 2014, 06:37:50 AM »
Hello Ernie
This build is such a source of interest and I was looking forward to this update. Your willingness to share issues and problems with us and show us how you've addressed is the very epitome of this wonderful site. Thank you.
« Reply #79 on: February 11, 2014, 06:41:29 AM »
Thank you so much for the encouragement and kindness Von Bob and Nigel.  Modellers
with your talents are such a motivation for me.
Offline IFF1418
« Reply #80 on: February 11, 2014, 06:54:11 AM »
Hi Ernie,
Wonderful job on the rigging. I'm sure you will overcome the small parts of chipped lozenge. Your Pfalz is really so nice to look at (I like the color) and I'm sure that it will be a real beauty when finished. Your log of progress was very learnful and I enjoyed it a lot. Well done my friend
Kind regards
Patrick
« Reply #81 on: February 11, 2014, 06:56:45 AM »
Thank you Patrick.  Your kind comments are always heartwarming and encouraging.
much appreciated, my friend.
Offline Dal Gavan
« Reply #82 on: February 11, 2014, 10:27:52 AM »
G'day, Ernie.
That's looking really good, and the scheme you chose is one of the best ones for that aircraft as it shows off the elegant lines very well.  It's lovely, mate!  I'm sure you'll sort out that strut, mate- it's just a bit of cosmetic repair now, you've done the hard bits.
Have you worked out why the lozenge is chipping?  I haven't played with lozenge yet, but large-area decals have given me problems before.  Mark's idea seems like a good one.
Cheers.
Dal.
« Reply #83 on: February 12, 2014, 02:13:30 AM »
Ernie,
Nice save on the strut! The rigging is coming along great! Looking forward to the finished product,
« Reply #84 on: February 12, 2014, 03:08:02 AM »
Thanks Dal and Rick for the kind comments.  They are much appreciated.
« Reply #85 on: February 22, 2014, 09:09:46 AM »
Well my friends, finally I have reached the end of the build.  It has taken longer than I
thought, mostly due to other goings on, but like they say "better late than never". ;)
  This has been my first Wingnut Wings kit and I am very impressed with the quality.  Even with
my limited abilities it has come out respectable and I have to say I'm quite pleased.  There is a
fair bit of rigging on the Pfalz, at least for me, but surprisingly presented no problems.
This my attempt at a laminated propeller using watercolour pencils.  It could be much better, but it
can be filed under helpful experience. The way I did mine was first a base coat of Tamiya Buff, a coat
of flat to make sure, then drawing the darker laminations.  After that, a coat of a mix of Tamiya clear
yellow and clear orange.
Finally a bit of a word about the lozenge.  I used the Wood & Wire five colour lozenge, which has
excellent texture representation but is very thin and fragile on wing edges, etc., and must be
coated with varnish as soon as possible.  Even so, I found they tended to peel and I had to do a bit
of patching here and there.
Well there you have it.  It has been a very enjoyable build and I look forward to my next...I am at
least so-far planning on the Sopwith Pup...subject to change, of course. ;) ;D
  I am very thankful for all your encouraging comments and helpful advice.  No wonder I love this
forum and the superb modelers here.  You have helped me a lot!
   I will post a few more photos in the completed section a little later. Until next time, thanks for looking.
« Reply #86 on: February 22, 2014, 09:41:16 AM »
Outstanding results Ernie!  The combination of the black fuselage, gold emblem and faded lozenge looks very sharp, and you have executed it very well indeed.  ;D.  You can be very proud of this beauty!
« Reply #87 on: February 22, 2014, 09:42:41 AM »
Very well done Ernie. That's one WnW under your belt and very nice too. Now, you know me, so you won't be surprised when I say don't let that lozenge success turn your head. Bring on the Pup and some good old PC 10!
« Reply #88 on: February 22, 2014, 11:25:28 AM »
Ernie,
As others have said, very well done! The black fuselage really goes well with the textured Lozenge. Your build was a joy to follow.
RAGII
« Reply #89 on: February 22, 2014, 11:32:07 AM »
Bob, Nigel and Rick, thank you so much for your kind comments!  You are all my
source of inspiration and never fail to do so.
