Author Topic: Eduard Pfalz IIIa Dual Combo  (Read 15029 times)
Re: Eduard Pfalz IIIa Dual Combo
« Reply #15 on: January 14, 2014, 05:41:57 AM »
Right side is reddy and picturese from engine.
« Reply #16 on: January 14, 2014, 05:42:50 AM »
one more from engine, but it is not complete.
« Reply #17 on: January 16, 2014, 03:41:55 AM »
Now is the left side reddy.
« Reply #18 on: January 16, 2014, 03:44:48 AM »
Here is the complete engine.
Then I will glue the engine in the fuslage and the fuselage together.
The next step will be to build the other fuselage on the same way as this build.
« Last Edit: January 18, 2014, 02:47:42 AM by radio »
« Reply #19 on: January 16, 2014, 05:32:54 PM »
Great progress, Martin.  The cockpits look really good.  Very nice wood tones.
Offline Dal Gavan
« Reply #20 on: January 16, 2014, 10:01:12 PM »
Coming along nicely, Martin.  As the others said, the cockpit is very nicely done.
Cheers.
Dal.
« Reply #21 on: January 18, 2014, 02:55:52 AM »
After the fuselage is drying I see that I must putty and sand it. Here is the result.
Also I made the airscrew moveable.
I saw the left and right aileron on the upper wing.
See here the Pictures.
Offline IFF1418
« Reply #22 on: January 18, 2014, 03:06:14 AM »
Good progress Radio. Very nice cockpit and the look at the seatbelts. This is going to be a great bird!
Kind regards
Patrick
guitarlute101
« Reply #23 on: January 18, 2014, 03:23:09 AM »
Wow, you are really moving along with this one, great job.
Offline Dal Gavan
« Reply #24 on: January 18, 2014, 11:01:07 PM »
It's good to see the fuselage closed up, Martin, and that classic Pfalz shape appear.
Good stuff.
Dal.
« Reply #25 on: January 18, 2014, 11:11:16 PM »
Good progress, Martin.  The seatbelts look great.  Really starting
to take shape now.
« Reply #26 on: January 19, 2014, 02:44:02 AM »
Here are the making of the machine guns. Additional I cut two pices of brass tubing. Then will it glue and paint.
« Reply #27 on: January 19, 2014, 02:46:01 AM »
The next pictures from the MG.
« Reply #28 on: January 23, 2014, 05:02:47 AM »
Now I have painted the wings, fuselage, undercarriage and struts.
Then were the machineguns glue on the fuselage.
« Reply #29 on: January 23, 2014, 05:06:14 AM »
Here is the undercarriage glue to the fuselage.
