Author Topic: Bleriot XI in 1:32 scale  (Read 37924 times)
Offline petrov27
Re: Bleriot XI in 1:32 scale
« Reply #15 on: December 05, 2013, 11:16:14 AM »
wow - super cool subject and fantastic start!
-Patrick
« Reply #16 on: December 05, 2013, 01:18:17 PM »
Wow out of the gate fast!! Great looking motor. Looking forward to more updates!!
« Reply #17 on: December 05, 2013, 06:30:54 PM »
Thanks guys for all your very nice comments, much appreciated.
Just a quickie update. I added the undercarriage suspension, just a simple matter of adding four small springs. I also fitted the two bracing belts to the frame work.
Offline Ian from Doncaster
« Reply #18 on: December 05, 2013, 08:36:20 PM »
 just a simple matter of adding four small springs...
Simple?  did you wind the springs from scratch or were suitable sized springs available?  Either way they look spot on!
« Reply #19 on: December 05, 2013, 08:38:59 PM »
Ready made springs Ian, I have a collection of very small springs of various sizes.
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #20 on: December 05, 2013, 10:41:34 PM »
Another incredible project to stun us all Des!
The springs looks spot on, but I have a question - I think I saw a version with bungee cords (is this the right word?) instead of the 2 springs and a bigger spring over the metal "leg" that is between the springs. Is this a matter of particular aircraft or an early - late version maybe?
Best regards,
Sasho
Think globally, act locally!
« Reply #21 on: December 05, 2013, 11:19:20 PM »
WOW!  That construct appears to be 1:1 Des!  ;)  Extraordinarily well done my friend. ;D
« Reply #22 on: December 06, 2013, 06:31:23 AM »
You are correct Sasho about the bungee cords, I have plenty of photos of this aeroplane and there was quite a variation of systems used for the suspension, I chose the springs because I have the springs on hand and I like the look of the springs, it is hard to simulate bungee cords. There is also a photo showing a large spring over the main undercarriage leg, so we had springs like I have used, bungee cords, single large springs.
Des
« Last Edit: December 06, 2013, 07:16:35 AM by Des »
Offline olfogey
  • Jim J. -- "Great Plains", U.S.A.
« Reply #23 on: December 06, 2013, 08:42:34 AM »
Looking great so far  :)
Every time I look at a "W.I.P." here, I get "performance anxiety" (LOL).
Jim J. -- "olfogey"
« Reply #24 on: December 06, 2013, 05:21:06 PM »
are those cylinders from the wnw re8 kit? i remember when i noticed the extras in the kit that i thought the exact same thing. i can use those to make an anzani if i want for a bleriot scratcher. i really cant wait to see this gal unfold. i love a bleriot.
« Reply #25 on: December 06, 2013, 05:56:29 PM »
Yes Scott, you are spot on with the cylinders, all the left overs from the WnW kits come in very handy when scratch building. The cylinders are not the correct style for the Anzani but if not examined too closely they are near enough.
« Reply #26 on: December 06, 2013, 06:41:35 PM »
Hello Des
I too wondered about the cylinders. This is all shaping up beautifully - exactly what we have come to expect from a master of the craft !
Offline IFF1418
« Reply #27 on: December 06, 2013, 07:32:28 PM »
Hello Des,
As always I wonder how you do it. I like this plane very much and will be following this build, which will be amazing as always.
Kind regards
Patrick
Offline Zabu
« Reply #28 on: December 07, 2013, 07:34:56 AM »
Excelence taking shape! More will follow just in a few moments! :P
« Reply #29 on: December 07, 2013, 12:18:11 PM »
I have made the fuselage frame from 1.0mm x 1.0mm styrene strips, it is a fairly basic design. I also added the front undercarriage/engine support frame work to the fuselage frame, it all fitted together reasonably well. Next job is to paint the frame a wood colour.
