Author Topic: Bleriot XI in 1:32 scale  (Read 37834 times)
Offline the great waldo
Re: Bleriot XI in 1:32 scale
« Reply #120 on: January 05, 2014, 08:57:17 AM »
Hi Des
Could you tell me which plan you are using for this build. I bought an Amati wooden kit of this aeroplane  and it has rectangular  fuel and oil tanks and something that is supposed to be a floatation bag where you have put the extra tank at the back end of the fuselage. I've held off starting this model until I got some accurate plans. Any pointers to the correct plans would be welcome.
Thanks very much guys for all the very kind comments, they are much appreciated.
I have added the bottom rigging frame, it was made from four lengths of 0.8mm brass tube. I also fitted the wing warping actuating arm and the two pulleys for the warping cables. Hard to see here but I fitted the two anti shimmy shock springs to the undercarriage. The paper wrapped around the fuselage is there to protect the paint while I man handle the model, stops the paint getting dirty.
« Reply #121 on: January 05, 2014, 09:32:55 AM »
Hi Andrew,
I sourced the plans for my Bleriot build from the net, once I found appropriate drawings I downlaoded them then scaled them to 1:32 scale to suit my purpose. As you probably realise there were many different variants of the Bleriot all being a little different to the previous one, also there are replica aircraft which have been build using different engines and fittings. All this adds to a lot of confusion when trying to build a particular model of the channel crossing Bleriot XI. The research I did shows a photo of the aircraft after it had crash landed in Dover, the main undercarriage had collapsed and the propeller was snapped, but it does show the rear fuel tank. I have read where there was a flotation device at the rear of the aircraft but I could not find any evidence of this. The main fuel tank on my model is cylindrical as per the plans I am using, it had rounded blunt ends, the rear fuel tank was also cylindrical but has pointed ends.
My model is probably not 100% accurate in the eyes of the rivet counters but as a representation of the channel crossing Bleriot it is pretty close. If you like I can send you copies of what plans and drawings I have, it may help you somewhat, if you feel you want to do this please send me your mailing (postal) address to my email at   [email protected]  I am only too happy to help.
This photo shows the damaged Bleriot with Louis Bleriot standing beside his aircraft, the guy with the flag is obscuring the view of the rear fuel tank but it is just visible to his right under his right arm, the pointed rear end is quite visible, I could not imagine any type of flotation device having pointed ends. The position and shape of the rear tank coincides with the drawings I have. (click the photo for a slighlty larger image)
Offline Whiteknuckles
« Reply #122 on: January 05, 2014, 10:56:35 AM »
Absolutely superb Des, beautifully realised and constructed :)
Eternal Apprentice
« Reply #123 on: January 07, 2014, 07:45:00 AM »
Just amazing! :o
« Reply #124 on: January 07, 2014, 12:10:44 PM »
guitarlute101
« Reply #125 on: January 08, 2014, 02:48:50 AM »
Another masterpiece in the making! Bravo Des!!
« Reply #126 on: January 08, 2014, 08:51:10 PM »
Thanks very much for all your kind words.
Andrew, the plans and photos are heading your way via airmail, hope they help.
I have the wings mostly made, just need to add the ribs to the port wing then painting will commence, hopefully I will have some photos in a few days.
« Reply #127 on: January 09, 2014, 06:11:27 PM »
Hi Des
Thanks very much for the heads up. I have attached a couple of pics to show you what I meant about the rectangular fuel and oil tank that comes with the Amati model.
« Reply #128 on: January 09, 2014, 06:13:50 PM »
Hi Des
Here's another photo.
« Reply #129 on: January 09, 2014, 06:40:13 PM »
Thanks for the photos Andrew, I have sent you an email with two photos showing the two different style fuel tanks, it is very confusing  :-\ :-\ :-\
« Reply #130 on: January 09, 2014, 07:21:02 PM »
Just the one photo this time. A trial fit of the unfinished wings, still need to add the ribs and paint. Paint is on order but will not be here until Monday  :(
« Reply #131 on: January 10, 2014, 12:04:23 AM »
Des,
This one is going to be ABSOLUTELY STUNNING! I am anxious to see your wings finished!
Offline IFF1418
« Reply #132 on: January 10, 2014, 12:49:35 AM »
Des,
I think this build will never be equalised. It's such a joy to look at. I find no words for my admiration.
Kind regards
Patrick
« Reply #133 on: January 11, 2014, 06:41:47 AM »
The wings are now ready for painting, the ribs are simulated using Bob's Buckles "strippers". I used the 0.5mm wide strips which are self adhesive, they stick really well and painting over them does not harm them in any way. I used an automotive primer then rubbed it back with 0000 steel wool. The wings are just sitting on the mounting pins at the moment, as you can see they are self supporting. I am expecting a delivery of paint on Monday so I will have a weekend of making turnbuckles.
« Reply #134 on: January 11, 2014, 07:40:44 AM »
Words fail me  :o
Beautiful craftsmanship, Des.
A retinal delight.
VB
