Author Topic: Wanted Eduard 1/32nd scale Etch set for Roden Spad VII C.I  (Read 7588 times)
Re: Wanted Eduard 1/32nd scale Etch set for Roden Spad VII C.I
« Reply #15 on: May 11, 2012, 01:43:22 AM »
  LOL or a free trip to the Loonie Bin. And of coarse a medal for steely determination and intestinal fortitude .
« Last Edit: May 11, 2012, 02:33:08 AM by GAJouette »
modelmaker
« Reply #16 on: May 11, 2012, 06:04:47 AM »
Oook Guys now your just plain Scaring me!! :-\
Sean
« Reply #17 on: May 11, 2012, 07:13:46 AM »
 Ohhhh no pay no attention to the giggling BOZO's behind the curtains  ;) . We're just cutting up a bit my friend.
« Reply #18 on: May 11, 2012, 12:14:31 PM »
Have an etchmate or a good steel straight edge etc and you will be fine. Just be patient and the results will be slick!!!
modelmaker
« Reply #19 on: May 11, 2012, 12:43:44 PM »
I endevour to use as much of the set as
I possibly can. But my main focus will be
on the areas of the model which are visible,
cant see the point in adding detail to areas
that can't be seen!
Sean
« Reply #20 on: May 11, 2012, 02:03:34 PM »
try using future or another clear coat to stick on your parts. ca drys so quick as soon as you place it its stuck. if you want to adjust you are s.o.l. the future allows you to adjust and is self leveling so theres no puddle. if you put too much on take a paper napkin and wick the excess away. after it drys i spray another finish clear coat to set it permanently. otherwise it is poss to flake off. ever since i started using future to glue on my pe bits i am very happy with the look. when i used ca as the instuctions suggest i ended up having slightly crooked parts or ca crust ooze peeking out around the edges sometimes. just a tip.
modelmaker
« Reply #21 on: May 11, 2012, 06:45:28 PM »
Great tip thankyou
Sean
