Author Topic: Fokker E. II Eduard Weekend 1/48  (Read 15454 times)
Offline xmald
Re: Fokker E. II Eduard Weekend 1/48
« Reply #15 on: December 03, 2013, 11:49:22 PM »
Thanks for all comments! Another update... some sanding and putty was required to close the fuselage. I`ve added the stitching - it`s wire and Tamiya tape. I hope the swirls are visible if not they are there believe me ;) I`ve tried to add some details to Eduard`s Oberursel: mostly scratch and beautiful Taurus`s sparkplugs. I still have to add wiring to them.
Best regards
Filip
« Reply #16 on: December 04, 2013, 02:28:37 AM »
Hi Filip,
I can certainly see the sworls, especially when I enlarge the photos, and very nice they are too! The engine is also looking very good.
« Reply #17 on: December 04, 2013, 03:00:09 AM »
Filip,
I am impressed with your progress. Your Eindecker is looking great!
Offline KONG
  • A day without sunshine is like...night
« Reply #18 on: December 04, 2013, 04:26:15 AM »
That is so awesome  8) How do you do it?
Really great work and so small, detail all
packed in . . . Great stuff . . . Well done  8)
"If I could only have brought him down alive..."
Offline Jacek
« Reply #19 on: December 04, 2013, 05:20:03 AM »
I really like the color of the canvas !
You can write what colors to use?
I always work out too much yellow  :-\
« Reply #20 on: December 04, 2013, 05:29:07 AM »
Excellent paint work, Filip, and the engine is superb.  Is that the Taurus engine?
Offline xmald
« Reply #21 on: December 04, 2013, 05:33:24 AM »
It`s Gunze C 45.
Now I`m really really flattered... ;D No it isn`t the Taurus engine - he only produces UR. I in 1/32 scale and this is 1/48.
I`ve modified the original Eduard`s engine a little bit.
Best regards
Filip
« Reply #22 on: December 04, 2013, 06:17:48 AM »
Wonderful work on the engine, Filip.  The sparkplugs are a great addition.
The swirls are delicate and very nice.  You are doing a great job of the
Eindecker.
« Reply #23 on: December 04, 2013, 07:02:41 AM »
Great work on the engine Filip, the spark plugs look perfect, and your fabric colour is really good, this is shaping up to be a wonderful model.
Offline xmald
« Reply #24 on: December 06, 2013, 03:13:22 AM »
Thanks Des and Ernie!
I`ve managed to put the cowling in place, but it wasn` t easy because I had to sand it a lot since the modified engine wasn`t feeling like fitting in...
I`ve fixed the rudder and elevator in place.
In order to make Eduard`s model look like E.II I had to modify the shape of the right side cowl - it was too small E.IIs had an ammunition storage there.
The most pleasant part of the job lately was the making of Taurus`s Spandau. It is an absolutely brilliant add on and a must have to anyone building an early WWI German plane.
I want to put somewhere a flare pistol I took from the Phoenix model but I have no idea where they were normally kept.
if you have any ideas, please let me know!
Best regards
Filip
« Reply #25 on: December 06, 2013, 04:16:20 AM »
looks great Filip.
The flare pistol could go almost anywhere, however somewhere there is a picture of Udet clowning around with a P08 in what is probably a flare pistol holder mounted to the side of the fuselage...
« Reply #26 on: December 06, 2013, 06:08:31 PM »
Your model is coming along beautifully, the machine gun looks great. I will go along with Bo, I have seen the flare pistols mounted on the outside of the fuselage.
Offline aviator01
« Reply #27 on: December 06, 2013, 07:33:58 PM »
Fantastic build Filip, stunning details in 1/48 and your paintjob is top notch. Thanks for sharing your pics.
Best regards, ro
On the bench: 1/48 Revell (Eduard) Bristol F.2B Fighter
Offline IFF1418
« Reply #28 on: December 06, 2013, 07:34:42 PM »
Wonderful detail Filip. You're doing a very great job.
Kind regards
Patrick
Offline xmald
« Reply #29 on: December 06, 2013, 07:54:53 PM »
Cheers Gents I`m glad that you like it. I must admit that I derive a lot of pleasure from building this one...
When it comes to the pistol WNW in their instructions to E.II state that flare pistol was usually stored internally but I like the option of having it installed like on von Crailsheim better. I think it won` t be a big mistake to do so since, I`ve seen only two pictures of Bruckman`s E.II in which the area around the cockpit isn`t visible due to the damage.
Best regards
Filip
