Author Topic: WNW Sopwith Triplane N533 Naval 10 Sqn. - Raymond Collishaw  (Read 25965 times)
Offline Jacek
Re: WNW Sopwith Triplane N533 Naval 10 Sqn. - Raymond Collishaw
« Reply #30 on: November 08, 2013, 06:37:31 PM »
The instrument panel is beautiful !
Looking forward to see more  :D
Jacek
« Reply #31 on: November 08, 2013, 09:15:52 PM »
Up to your usual superb standards, Lance.  Wonderful job on the instrument
panel.  The Pulseometer is perfect...great addition!  Your woodwork is spot-on.
  I look forward to the next installment.  Yours is a great build to follow, my friend!
Offline Pup Cam
« Reply #32 on: November 10, 2013, 07:18:24 AM »
Absolutely superb, the le Clerget is gorgeous, I could do with a 1/3 scale version!
Alan
Offline KONG
  • A day without sunshine is like...night
« Reply #33 on: November 11, 2013, 06:30:31 AM »
Just looked in mate  . . . Love that engine Lance  8)
Bloody awesome . . . . Looking forward to this one  ;)
Great stuff
All the best
"If I could only have brought him down alive..."
« Reply #34 on: November 12, 2013, 08:30:07 AM »
Hello Lance:
You are off to a great start with a great gallery of onlookers to provide encouragement alont the way.  I like the engine colors.  I know what you mean about the copper wire.  I use EZ line.  Drill a hole like you did, attaché the EZ line there then attach it to the plug, using a dollop of CA glue, snip it and voila, plug wire.  On the Tripe the plug wires will become almost invisible once the cowling is fitted.  Interior looks the business and the instrument panel a true testimony to your craftsmanship.  Looking forward to more.  We have had a smattering of snow, but no major snowfalls yet.  I am ready for it when it comes though.  Black Maria has always been one of my favorites.
« Reply #35 on: November 12, 2013, 01:55:21 PM »
Thanks Mark, as you say the plug wires are all but invisible so I will just live with it. I spent most of today clearing the snow which greeted me on return from my weekend visit, we got about a foot and my wonderful driveway in the country reminded me how much this is "no country for old men"!! I was able to get a little work done on her, prepped the fuselage for the inspection windows on the forward fuselage, took me over 2 hours of searching through the Refs to conclude they were on this particular airframe however the photos of 533 don't definitely say it was so. I guess that's one of the pleasures of this Hobby, or so I keep telling myself! :-\
« Reply #36 on: November 15, 2013, 05:04:27 AM »
Superb work on the engine and cockpit, Lance.  That instrument panel is brilliant.
« Reply #37 on: November 15, 2013, 06:18:22 AM »
This is inspirational stuff Lance and I feel privileged to see it.
Thank you.
Offline KONG
« Reply #38 on: November 15, 2013, 06:49:29 AM »
Lance you are a master . . . That radial is a masterpiece in its own right
Well done that man . . . Have a beer  ;)
« Reply #39 on: November 15, 2013, 08:32:16 AM »
   Coming from you Dave that's a compliment I'll not soon forget! As for the beer, it's 2 hours until my "Beer low light" starts to flicker, but I suspect my last Guinness will take a bit of a beating then!
   I'm hoping to post photos tomorrow; have the cockpit module completed and will probably mount it on the port side fuselage half before the day ends.
Did anyone else who has built this one  find a conflict getting the left shell ejector chute into place? I ended up cutting it off the Instrument panel/fuel tank assembly to be re-installed once the module is mounted to the fuselage half, couldn't get it around the frame bracing wires and throttle/spark advance push rods?!? Maybe I missed the obvious however it wasn't even a close thing, way too much conflict. :-\
mike in calif
« Reply #40 on: November 15, 2013, 02:03:04 PM »
Nice work. I see a lot I hope to use when I do one of my Tripes.
 I may have to borrow your idea of getting a swazzle of after-market all at one time too. Pretty handy when the building fever gets to you.
« Reply #41 on: November 15, 2013, 11:13:50 PM »
Mike,
  I tend to buy ahead or stockpile as I do with basic supplies. I'm 200 miles from the nearest Hobby Shop so even running out of glue is a show-stopper. It's sort of imposed a "hoarding" approach to my hobby shopping habits, I'll have cheek pouches next! ::)
« Reply #42 on: November 17, 2013, 10:58:46 AM »
   I've finally got some progress to enter here, things are starting to come together after a very slow start up. The cockpit module was completed finishing the flight control cables, adding HGW Laser Cut Seat Belts (a real pleasure to work with and I really like the results) and touching up the cables with Mr Metal Color "Stainless". The seat was done in Alclad "Steel" to match the steel seat in the Tripe.
   The side frame bracing wires were added using #9 Guitar Wire and Bob's Buckles tubes. These, as always, turned into a large pain in the posterior as I kept knocking them off during the fitting and assembly process. I also added a red portion to the fuel indicator glass on the starboard side frame (after these photos were taken) and rigged the Stab. adjusting pulley before final full assembly. I'm not entirely happy with the final varnish coat on the cabanes but it's too late to go back now..............
   At this point all of the flight control wires from the fuselage exits were pre-installed and on the dorsal deck I added fairleads from .5mm Brass Tubing for the twin elevator control cables. These will need to be filled in and smoothed out.
  Next the side frames and floor components were mated and the fuel and ammo containers with the instrument panel added. I had to cut the left gun's shell casing ejector chute off to get the latter assembly in place and then re-attach it later.
Once I was happy with the final steps on the cockpit the module was installed in the port fuselage half after carefully scraping all mating surfaces completely clean of paint and glue.
   Since that last step the fuselage has been "closed up" and the seams have been filled and sanded. The final fit was very tight but quite satisfactory. Like all WNW Kits a lot of care has to be taken to ensure all excess paint etc. is removed before assembly, the tolerances are basically zero!
   Next  comes some painting of the major components, and then I can add to the debate over the "real colour of PC12"! ::)
« Reply #43 on: November 17, 2013, 11:12:59 AM »
I don't know where to begin, Lance.  Your woodwork is to me, spot on. You have
captured the varnished look perfectly.  I can't get over the detail you have put
into the cockpit.  It is superb. I really like the seatbelts.  The HGW belts are just
the ticket.  Just wondering about the tubing for the control wires.  When they are
done, do they still protrude from the side?
  Thanks for the wonderful photos, my friend.  I'm looking forward to the next update.
« Reply #44 on: November 17, 2013, 11:34:17 AM »
That is one AWESOME COCKPIT! Perfectly executed details and paintwork!
