Author Topic: Glencoe 1:48 Oeffag D.III  (Read 18983 times)
Re: Glencoe 1:48 Oeffag D.III
« Reply #45 on: July 15, 2012, 10:40:13 PM »
   David,
On your SVA-5 project,I'm not certain whether I passed along this link to you before or not but in case I didn't. I believe you'll find this interesting and helpful. I'm really looking forward to a SVA-5 thread as she's one of my Italian favorite.
LINK:  http://www.stormomagazine.com/ModelArticles/Ansaldo/SVA5/DavideSplendore/SVA5_1a.html
Offline ta152c
  • My threads are doing iron man numbers
« Reply #46 on: July 15, 2012, 11:46:15 PM »
Thanks Gregory!
I like what he's done with his SVA.5, but I've made some modifications. The lower wing, which has the lower fuselage centre portion, has had that removed, leaving the wings separate. Remainder of the floor was cut in half, inverted and re-attached, giving a more correct underside (with gaps to fill).
Removed the rudder, sanded away all the interior, rebuilt with rod and plastic card (just the framing so far, bulkheads next). On the fuselage, rescribed engine upper cowling panel (I've considered removing the panels and adding an engine!, but don't know if one could be bought or converted), removed exhausts etc.
On the actual aircraft, the wing struts attach not to the teardrop fairings, but just above them, so I've filled in the circular holes and will think of some way to attach the struts (wire pin etc). Other attachment points are ok, the upper wing centre can be strengthened. I did see another SVA.5 made where the fellow added bits on top of the main struts, which then snapped/failed as the centre-section is weak on the kit. I do need a scale drawing of the rudder and rear fuselage/tailplanes, under the tailplanes there is a metal strip reinforcement that needs added.
As regards armament, I have some Roden Vickers mg's which will look very good, just need to fabricate the very unusual blast tubes/flash hiders that were often fitted. Fuselage bomb racks are simple enough to make. Also, under the floor some SVA.5 were fitted with two doors for cameras, another possibility.
Radiator front -the prop attachment will be drilled out, and I'll fit a spare centre from a Roden DH.4 frontal radiator. Will improve the kit no end, as will the circular fuselage access panels. I'll deflect the ailerons though. Kit prop is the wrong shape, but I'll have a spare one of similar shape somewhere. Wheels need replaced, but I'll worry about them later.
Regards :)
« Last Edit: July 26, 2012, 05:50:24 AM by ta152c »
"I hope he burned all the way down" - Mannock on hearing of the death of Manfred Von Richthofen, 1918.
Offline ta152c
« Reply #47 on: July 18, 2012, 09:29:57 AM »
Progress report :
There you go :)
Offline ta152c
« Reply #48 on: July 19, 2012, 06:45:44 PM »
I've been busy, have made both bulkheads/engine mounts for the ser.153/253 (which had to be raised) , added more to the SVA.5 (had to redo the bulkhead as it wasn't true in plan or elevation), and should get them primed and spray basecoated today. SVA.5 will have a richer coloured wood interior. Must remember to make the IP. Pic to follow.
There you go :)
« Reply #49 on: July 19, 2012, 10:01:09 PM »
The factory approach appeals to me. I would think it would moderate my more neurotic perfectionist tendencies.
Offline ta152c
« Reply #50 on: July 19, 2012, 10:22:27 PM »
I wouldn't say I was a perfectionist, but I've done very little 1:48 before so its a good method of building. There are 7 kits on the go, 4 are vacforms.
These kits are just 'test-beds' in a way, although I will do my best with them before moving onto more recent kits.
Been enjoyable, apart from some "****" moments that we all go through in this great hobby of ours. The Glencoe Albatros kits, with a few additions, are decent kits, if you get them cheap enough. Mind you, the Eduard ones are stunning. I probably won't build any more of the 'older kits' after these, although I'd still do a vac Hansa-Brandenburg C.I in 1:48, and I really fancy a Bristol Boxkite, could do one as used by the Russians. I think the PYRO kit is still available.
I wonder if I could make a camera fit for the SVA.5?
Anyway, back to work.
Regards :)
« Last Edit: July 19, 2012, 11:43:35 PM by ta152c »
Offline ta152c
« Reply #51 on: July 26, 2012, 05:31:37 AM »
Update time.
Wings got a blast of Tamiya Fine Primer (great for showing up defects, gaps etc), so they were filled and sanded smooth (again). Rib tapes from 0.5mm masking tape using the JaPo book plans on the Oeffag Albatri to get the spacing right. Sprayed with primer again, then a coat of Future floor wax (gloss varnish really) to keep the rib tapes from lifting. I was going to scribe in the rib tapes, but I think this method looks better. However, any comments or criticism are welcomed warmly.
In the last pic you can see the bulkheads in the two Oeffags as well, so now they'll get airbrushed with a sand yellow colour and then washed like the rest of the interior. SVA.5 cockpit parts are there too, Aviatik D.I wings too.
There you go :)
P.S. Quick quiz -which of the Albatros upperwings is for the ser.253? No prize, but a fun question!
P.P.S. Underside of the wings.
« Last Edit: July 26, 2012, 05:55:42 AM by ta152c »
« Reply #52 on: July 26, 2012, 05:51:18 AM »
I guess it's the one with the large cut-out (center) -- didn't the 253 have an enormous radiator?
Offline ta152c
« Reply #53 on: July 26, 2012, 05:59:22 AM »
No, its not to do with the radiator, have another guess :)
(cut-out is there because in the photos, the lower part of the radiator has a deeper section toward the rear which I'm trying to replicate). In some ways, these Glencoe kits do take me back to my early days of modelling, although in our village 1:48 WW1 stuff was too esoteric for the Scottish Highlands. Has been good fun so far though, as a newcomer to the scale. I hope they don't turn out bad, I'd be gutted.
Regards :)
« Last Edit: July 26, 2012, 06:22:22 AM by ta152c »
