Author Topic: Parachutes  (Read 3514 times)
Parachutes
« on: September 20, 2013, 06:54:35 PM »
Hello All
On pages 30/31 in the latest edition of Windsock (29/4) there are two photographs showing Fokker D.VII pilots wearing  Heinicke parachute harnesses over their coveralls. Now, I naively thought that maybe the pilots sat on the parachute but I've just read in that font of all wisdom Wikipedia (sic) that on fixed wing German aircraft of the period they were stored in some sort of compartment behind the pilot. But where? There's certainly no space between the rear of the seat and it's supporting frame. Are there any implications for us as modellers?
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
Re: Parachutes
« Reply #1 on: September 20, 2013, 08:50:59 PM »
I have always understood the pilots sat on them and that as a consequence seat cushions were dispensed with progressively from about May 1918 onwards. Dan San Abbott wrote a paper titled "German Parachutes in the Great War" but I can no longer find it online. Perhaps someone else has a copy?
Have a look at this thread:
http://www.theaerodrome.com/forum/other-wwi-aviation/44676-question-about-parachute-harnesses-2.html
Happy Modelling
James Fahey
Re: Parachutes
« Reply #2 on: September 20, 2013, 11:09:18 PM »
Red Baron and James, thanks as ever for getting back, and James for the link to the discussion thread.
You've both hit on what lay at the root of my question. Ever mindful of the creature comforts which might make life more comfortable for the pilots, I've always made a small cushion for their seat. So, I was wondering what to do this time with an aircraft at the very end of the war. Should I not bother with a cushion? After all, if they're wearing thick clothing and sitting on a cushion as well as a parachute the whole geometry of their position changes. Which begs another question. Were the seats adjustable, up and down, backwards and forwards? I haven't noticed anything to suggest this on a model, but perhaps I haven't been looking hard or carefully enough.
Re: Parachutes
« Reply #3 on: September 20, 2013, 11:57:16 PM »
On German scouts anyway, generally there was minimal provision for fore and aft adjustment but not up and down -- I guess more cushions or phone books for that. There were some very diminutive pilots so somehow they made do. Albatros seats ran on rails and could be adjusted back and forth. That said, I think the plane was fitted to the pilot so to speak by the crew chief, and I'm not sure the word "ergonomics" existed then.
Re: Parachutes
« Reply #4 on: September 24, 2013, 11:42:34 AM »
I believe Max Meuller was "vertically challenged" and have seen references that follow Bo's logic in his case; his crews and / or Crew Chief modified seat/rudder arrangements to provide him with "ergonomic compatibility' as it was called when I flew. I recall a fellow Pilot on Voodoos who had a set of "blocks' similar to the bicycle ones we used as kids to allow his short legs to reach the rudder peddles! I suspect, in Meuller's case the additional bulk or spacing provided by a parachute would be a bonus!
Lance ;)
Re: Parachutes
« Reply #5 on: September 24, 2013, 02:02:18 PM »
Without fully adjustable seats, it must have made for some very uncomfortable flying positions. Given the varied heights of the pilots sitting on "something" would have to be a necessity for the short guys.
Re: Parachutes
« Reply #6 on: September 24, 2013, 05:10:01 PM »
Hello All
The problem with sitting on something - like one of these new-fangled parachutes - on a non-adjustable seat that is itself angled back (as in the EV) is that it will take your feet even further away from the rudder bar. No hope for me then!
Re: Parachutes
« Reply #7 on: September 26, 2013, 08:20:42 PM »
Thanks all for the info.
Bo Thanks for alerting me to the fact that Albatros fitted seats which were adjustable backward and forward (I wonder if there was a default setting in the middle or whether the delivered position just reflected the comfort of the last fitter to check things out?) Courtesy of the WingnutWings instructions for the DVa, I can see how the thing moved.
It raises a couple more questions in my mind. First, we sometimes lavish amazing attention to detail in finishing a cockpit and then decorating a model in the markings of a particular pilot. Obviously we lack hard evidence, but where we do know from period photographs that a particular pilot was small or tall should we be adjusting the seat position accordingly? Lance gives us the example of the very small Meuller but what about people like M. Richthofen? I've tended to think of him as being small, even by the standards of the early twentieth century.
Then, if a small pilot is in a DVa at the end of the war (?) with the seat pushed right forward, does that mean that there would be room to put a parachute behind the seat; or would the seat belts run the risk of things tangling up?
Offline kornbeef
Re: Parachutes
« Reply #8 on: September 26, 2013, 09:41:26 PM »
I think only the later Albi's D.v's & D.Va's had the adjustment Bo mentioned. before that the mounts ran side to side, whether there was holes to allow the seat or rails to be moved I don't know.
Fokker however had a tube on tube sliding clamp arrangement between seat frame & the fuselage tubing that allowed up and down movement, I was reliably informed..... laughs. as reliable as can be anyway. I think theres a sketch of it in the olde Windsock Dr1 datafile special. Rolands of course had the deckchair arrangement of adjustment... ;) ergonomics at play
Re: Parachutes
« Reply #9 on: September 26, 2013, 11:35:24 PM »
There seem to have been. Check the photos of Koloman's D.II & D.III repros; the fore/aft seat rails have multiple holes so it seems the seats could be at least crudely adjusted in that aspect. One really useful photo is on this page of the long "D.II D.III News" Areodrome thread. Somewhere in one of the Datafiles there is also a period drawing IIRC.
Offline kornbeef
Re: Parachutes
« Reply #10 on: September 27, 2013, 08:46:02 AM »
Nice spot Bo.
Of course anyone thinking of building a DIII should save these pics as this is how a DIII should look not as Roden, Eduard and even Windsock publications show the cockpit layout. Koloman is a stickler for detail so I think it must be so.  :) It was changed with the DIII to suit the new lower wing layout and it's single spar as opposed to the DI & DII's twin spar wing.
But getting back on track.
Still though I'd hate to think my parachute was stuffed behind my seat, kind of a recipe for disaster IMHO. I wonder if theres some mix up between balloon observers parachute arrangements and aircraft over time.
Keith.
Offline kornbeef
Re: Parachutes
« Reply #11 on: September 28, 2013, 05:18:07 AM »
I've just found a pic in a book of a D.VII pilot being readied for flight  by his attendant, He's having his chute harness fitted and its clearly attached to a seat cushion shaped bag under the attendants arm.
The books Fokker aircraft of world war one by Paul Leaman. Its the top right pic on page 131and is credited to Cross & Cockade International
Keith
Re: Parachutes
« Reply #12 on: September 28, 2013, 06:08:39 AM »
It's yet another big learning curve for me. Thanks Bo and Keith.
I love the imagery of the Roland 'deckchair' arrangement. The Fokker tube on tube arrangement sort of makes sense if I've understood it correctly. I'll have to scour my sources and see what the British manufacturers did.
I don't recall seeing a model in which the seat and internal controls have been adjusted to suit a particular pilot known to have been very tall or very short. It would be an interesting challenge.
Offline Zabu
Re: Parachutes
« Reply #13 on: September 29, 2013, 03:48:38 AM »
I'm I late or what?  :-\
You guys already said enough, so i just leave you with a couple of pics (they were missing weren't they? ;D).
Pilot getting ready
Bailing out
I guess that the Heinecke parachute started as a backpack (prototype) but then evolved to a seat cushion style.
Re: Parachutes
« Reply #14 on: September 29, 2013, 06:07:18 AM »
That's great thanks Zabu.
