Author Topic: Albatros D.V 1/32 WnW  (Read 43229 times)
Re: Albatros D.V 1/32 WnW
« Reply #105 on: September 19, 2013, 05:41:00 AM »
The wings look great, Jacek.  Good job!  I'm anxious to see your
next update.
Offline Jacek
« Reply #106 on: September 21, 2013, 12:52:38 AM »
My first "Wooden Wonders" , wish that I would have to cover it with green flecks :'(
I wonder how to impose tiny flecks on the fuselage  ::)
« Reply #107 on: September 21, 2013, 08:52:10 AM »
Jacek, if you want to have green mottling on the fuselage, you could dab it with
a sponge soaked in the proper green paint.  Wingnuts website has a tutorial for that exact
thing in the hints and tips section of the instuctions for the Albatros D.V.
  Hope that helps. :)
Offline stefanbuss
« Reply #108 on: September 22, 2013, 12:36:27 AM »
And of course you might be wise enough to test this sponge application on some kind of test fuselage first. Good luck!
Stefan
« Reply #109 on: September 22, 2013, 01:17:34 AM »
Another technique is the toothbrush flick method
Offline Jacek
« Reply #110 on: September 22, 2013, 01:56:12 AM »
  Hope that helps. :)
Thank you I'll check it out  8)
Stefan
The first test, surely .
About this method I have not heard  :o
Thank all you for your tips !
« Last Edit: September 22, 2013, 02:02:15 AM by Jacek »
« Reply #111 on: September 22, 2013, 12:11:27 PM »
Toothbrush flick method:
1) Dip old toothbrush in paint
2) move thumb backwards across toothbrush bristles, spraying paint randomly
Obviously, test on scrap to master technique
« Reply #112 on: September 22, 2013, 09:36:14 PM »
I've never used the toothbrush method, Bo.  Any tips as to how far from the model
you usually do it?  I worry about it looking splattery.
« Reply #113 on: September 22, 2013, 09:45:21 PM »
You simply must experiment as there are many variables including the paint's viscosity, the stiffness of the bristles as well as the effect you are trying to achieve. This technique is often used to simulate mud spatters and so forth...
Offline Jacek
« Reply #114 on: September 23, 2013, 12:52:47 AM »
I did test.
Bo technique:
My modification of technique Bo:
Sponge:
The result
1.-Technique Bo
2.-My modification of technique Bo
3.-Sponge
The most suitable to me technique Bo.  In my modification is too much of microscopic dots.
Sponge is very difficult to maintain equal emphasis !
Offline LindsayT
« Reply #115 on: September 23, 2013, 01:37:19 AM »
I love seeing a well documented experiment! Thanks for posting the results.
« Reply #116 on: September 23, 2013, 04:17:42 AM »
Thank you for going to the trouble of setting everything out so well, Jacek.
Very interesting and informative!
« Reply #117 on: September 23, 2013, 11:02:12 AM »
Comb = good idea. Nice Jacek.
« Reply #118 on: September 23, 2013, 05:10:43 PM »
So that's what people meant when they said  'don't forget our toothbrush' when I was younger!
« Reply #119 on: September 23, 2013, 05:56:33 PM »
Thanks, Jacek and Bo for this informative discussion. I have to remember that toothbrush technique, it seems to work perfectly.
BTW, very nice wings shading, Jacek!
