Author Topic: Roden Nieuport 28 1/32nd Scale  (Read 53155 times)
Online RAGIII
Re: Roden Nieuport 28 1/32nd Scale
« Reply #90 on: August 07, 2013, 11:13:59 AM »
You're a model building machine Rick! Nice work my friend.
Thanks Chris, I appreciate your comments! As for the Modeling Machine, If/when I complete this one it will be the most models in 1 year since @ 1990  :-[ DVII, Sopwith  and 28. And I still have 4 months left  :-X
Online RAGIII
« Reply #91 on: August 07, 2013, 11:18:54 AM »
Rick, your paint and rib shading looks first rate!  I really like your colors and paintwork.  This is shaping up into a beautiful representation of a graceful aeroplane. ;D  I will use your log as a guide when I get around to my own Ni. 28.  Thanks!
Bob,
Thank you for your comments and interest in my build, they are appreciated!! I hope you continue to find my log useful, but remember there are a couple more logs on building this aircraft that certainly deserve attention!
Very nice it starts to look.
Thanks Jacek, Next up is the rib effect on the upper surfaces.
mike in calif
« Reply #92 on: August 07, 2013, 02:02:10 PM »
Rick, popped in for a peek, and you are giving me a first rate look at a very good build. This is a Roden kit I may buy, and your build is a great tutorial. Great job on the cammo with the putty.
Offline KONG
  • A day without sunshine is like...night
« Reply #93 on: August 08, 2013, 12:04:25 PM »
She's a wee cracker ;D
"If I could only have brought him down alive..."
Online RAGIII
« Reply #94 on: August 08, 2013, 12:27:25 PM »
Mike,
Thanks for dropping in! This kit and others by Roden are really not as bad as advertised! Yes , more work than WNW, No, Not Fatally Flawed!!!! The 28 is certainly one of the best in both 1/48th and 1/32nd! JMHO etc....
Online RAGIII
« Reply #95 on: August 08, 2013, 12:29:04 PM »
Thanks as I think "A WEE CRACKER" is a compliment  :D I appreciate your interest greatly!
Online RAGIII
« Reply #96 on: August 13, 2013, 08:47:56 AM »
The latest update from my days off: The Major markings have been applied. The upper wing rib tape effect done with pastels, and the fuselage ribbing for the light green and dark green has been picked out using a darker green oil between the ribs.
Online RAGIII
« Reply #97 on: August 13, 2013, 08:50:19 AM »
and a couple more:
« Reply #98 on: August 15, 2013, 03:33:39 AM »
Hello Rick:
Looking good.  I like the subtle rib shading.  I will have to try the silly putty method of painting.  As mentioned I have one of these in the stash and it doth beckon as do the rest.
Looking forward to seeing you progress to completion on this one.
Offline Zabu
« Reply #99 on: August 15, 2013, 07:37:33 AM »
Very nice progress.
Your rib shading it's quite convincing. Very nicely done.
You big scalers work is quite an inspiration for a brailler like me! Thank you!
Cheers.
Online RAGIII
« Reply #100 on: August 15, 2013, 11:09:21 AM »
Hello Rick:
Mark,
I appreciate your comments greatly! I have said before that these forums and build blogs are meant to inspire and be inspired! I am looking forward to the day you build yours and take this kit beyond my bounds!!!!
« Last Edit: August 15, 2013, 11:13:10 AM by RAGIII »
Online RAGIII
« Reply #101 on: August 15, 2013, 11:14:53 AM »
Very nice progress.
Cheers.
Zabu,
You Brailers inspire and amaze me with every build you do! Thank you for your comments!
Online RAGIII
« Reply #102 on: August 20, 2013, 11:23:35 AM »
A small update: The main gear is attached, the MGs are installed,(I hollowed out the ends and used the part PE, All main rigging is attached at the anchor points.
Online RAGIII
« Reply #103 on: August 20, 2013, 11:24:48 AM »
And a couple more:
« Reply #104 on: August 20, 2013, 11:34:47 AM »
You're making good progress, Rick.  Great attention to detail.
Looking forward to next update.
